DIY Precision Reference for DVM Calibration
Started May 3, 2020 | Discussions
mawyatt2002
mawyatt2002 Contributing Member • Posts: 502
If you have a home lab with electronics like DVMs this might be of interest. Check details out here at Photomacrography.
https://www.photomacrography.net/forum/viewtopic.php?p=261783#261783
Quick test circuit for LM399
A pair of HP/Agilent  34401A DVMs
Custom PCB 3D Models
Best,
Research is like a treasure hunt, you don't know where to look or what you'll find!
~Mike
Johannes Zander Regular Member • Posts: 467
Re: DIY Precision Reference for DVM Calibration
Nice design.
I just use a LT 1021 CCN8-10. Maybe not as precise as your design.
 Johannes Zander's gear list:Johannes Zander's gear list
Nikon 1 V1 Nikon D4S Nikon Z6 II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 24mm f/1.4G ED +21 more
mawyatt2002
OP mawyatt2002 Contributing Member • Posts: 502
Hi Johannes,
Very nice looking reference assembly, well done!!! Is that a custom 3D printed case, looks really nice and create a nice overall package. Something (3D printing) I wish I had and may consider getting involved with.
How is the long term drift with the LT reference?
I've been running the LM399 for about a week now continuous to let it stabilize, so far only about 100uv change.
There is a LT reference diode similar to the LM399 called the LTZ1000 that's even better than the LM399, but these are very expensive whereas the LM399 is still under $10.
Wanted to include reference resistors and currents in the design, voltage, currents and resistances could be compared. So 100, 1K, 10K, 100K, 1M ohm precision resistors and 100ma, 10ma, 1ma, 100ua and 10ua currents are supported.
BTW still waiting on the precision components to arrive, then will decide if the PCB should be fabricated, there is a minimum build quantity of 5, so a few "extras' will be available.
Best,
~Mike
Bernard Delley Senior Member • Posts: 2,041
connection to SI standard ?
This Zener Diode with a built in temperature controller makes a very nice key component in a precision regulated voltage supply. It comes with a voltage guaranteed to 2% accuracy. But, how do you calibrate it with respect to the fundamental standard, a derived SI unit ?
The two reputed voltmeters in your image provide such a connection. The small difference in their displayed voltage gives a hint at their present accuracy - provided nobody has tampered with the calibration trimmer in their internal reference to make them show a closer voltage reading.
 Bernard Delley's gear list:Bernard Delley's gear list
Olympus TG-6 Nikon D7200 Nikon D500 Nikon D850 Nikon Z7 II +17 more
Hi Mike,
thanks for your nice comment.
I am not so scientific. I didn't do an long term drift test. I observed that it drifts between 9.9992 and 9.9995. This is precise enough for me.
I searched a bit about burn in for aging electronic devices and found this forum:
https://www.eevblog.com/forum/metrology/lm399-based-10-v-reference/250/
They talk about paralleling LM399 for reduced noice.
Good look with your research.
Regards
mawyatt2002
Re: connection to SI standard ?
Bernard,
Agree these are very nice parts, they are the references used in the HP/Agilent 34401A DVMs shown, but special selected versions. Initial accuracy isn't that good, but drift with temperature and time is exceptional.
I also have lower resolution Fluke 77 and 87, they all agree well. The HP & Agilent DVMs calibration is a complex process and not just adjusting a pot, the calibration coefficients are stored in NVMemory. Soon I may get these DVMs calibrated, then use the LM399 reference calibration so I'll have a secondary standard on hand.
Best,
~Mike
mawyatt2002
Johannes Zander wrote:
Hi Mike,
Regards
Hi Johannes,
I've observed the LM399 random drift over the past few days, it's now below ~30uv. So seems to be "settling in". The reading is centered around 6.85498 volts at ~1ma. This part may be an "outsider" since the norm is 6.95 volts for the LM399, and thus may not be a good representation of the LM399 (maybe a reject that I got off eBay??).
Thanks for the link. Paralleling devices not only improves low frequency noise but also drift.  If one wanted to create a serious standard voltage reference then paralleling devices seems like a good approach, but the LTZ1000A is a better device for this. These are expensive tho (why I don't have one).
BTW what DVM are you using?
Best,
~Mike
