Thinking about the Sigma fp
Started May 3, 2020 | Discussions
FDecker Senior Member • Posts: 2,344
6
To check what I have to expect IQ wise, I checked the sample pictures on Imaging Resource (so, all screen shots I show are based on images they provide on their web page) . I developed the X3F of the SD1 and the dp 2 Quattro in SPP as well as the DNG from the fp. The Phase One XF 100 was developed in Affinity and down-scaled to 50% to make a better fit.
I have to say that the Sigma fp is quite good and on par with the Panasonic S1 or the Sony A7 III. But It is a Bayer type camera and in very specific areas demosaicing raises its ugly head. Here is what I mean:
Good old SD1 Merrill
The fp. My reaction is uuuups....
The dp2 Quattro. So much better than the fp but worse than the SD1 despite the slightly higher resolution.
The Phase One down-scaled to 50%. Still a Bayer but the 100MP resolution comes to rescue.
Now, I still think about the fp in oder to have a high ISO companion for my sd Qauttro H. But it makes me sad about having sold my SD1 and makes me wanting the coming FF Foveon even more.
Just to make ist clear, in most other areas of the sample pictures, the differences are much less pronounced and you will for sure find areas there judgement may be different.
FinePix S1 Sigma dp2 Quattro Sigma SD1 Sigma SD1 Merrill Sony a7 III
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: Thinking about the Sigma fp
Very good comparison set, Frank.
At 200%
In the red cloth, an excellent illustration of:
a) Merrill v. Bayer and Merrill v. Quattro
b) Horrible moire from the fp.
c) The opinion that a big Bayer image downsized can equal the Foveon.
The Quattro colors are quite different to the other three - surprisingly so!
There is more than one way to skin a cat ...
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
OP FDecker Senior Member • Posts: 2,344
An unexpected solution !!
At 200%
Thank you Ted. I can make it more confusing. Playing around with the samples from Imaging Resource, I came across this observation:
Hope you can read the camera names. Please look at full resolution.
All modern 24MP cameras have problems with that red cloth. The Panasonic S1, the Fuji X-Pro3 (despite of the X-Trans sensor, but it is also the only APS-C in this comparison), the Nikon Z6 and the Leica SL. Interestingly, the Leica SL is clearly better in this respect. Leica Magic? But... don't ask why, I also checked older cameras, the Sony A900 and the Nikon D700. Both about 12 years old. The D700 with only 12 MP. And wow, not as good as the SD1 Merrill but way better than the modern cameras. Both have an AA filter. So, I checked out the Nikon D800 and D800E. The closest I can get to a camera in both variants, with and without an AA filter. But unfortunately with 36 MP, so not quite the same as the 24 MP. Anyway:
D800 with AA filter. Not bad.
D800E , no AA filter. Also not bad. Slightly worse??
Ok, so, it is the AA filter or better, the absence of an AA filter? Doesn't seem so.
Any ideas? It was easy to understand for me why the Merrill beats the Quattro in this respect and why both beat the Bayer sensors by a large margin. But what to say about the old Sony A900?
One thing come to my mind: can it be that this red cloth is loosing its color (the black one) over time? So, maybe, today it really has much less contrast and my whole research was in vain...? OK, I checked out the latest and highest MP camera I could find, the Fuji GFX100.
Here, I don't believe that we loose the contrast due to Bayer color aliasing and interpolation. And it seems indeed as if the red cloth lost the contrast. I mean, as good as I can judge from this picture. Still no perfect proof, we need to see the real cloth....
The pictures are from:
Sony A900 and Nikon D700 : 2008
Nikon D800, D800E : 2012
Sigma SD1 Merrill : 2012
Sigma dp2 Quattro : 2014
Leica SL : 2015
Phase One XF 100 : 2016
Panasonic S1, Fuji X-Pro3, Fuji GFX100, Nikon D780, Sigma fp : 2019/2020
What does this comparison shows: it is easy to get tricked by assumptions. In this case, that the red cloth is always the same and that a loss of contrast in the image of that red cloth is due to sensor technology.
A fail? In some sense yes, but a "fail forward".
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Thanks for showing that....Anxiously awaiting the next camera. fp looks pretty ugly in that shot. My feeling is that if Sigma never came out with another camera I would be happy with current options.
allineedislight Senior Member • Posts: 1,309
Re: An unexpected solution !!
Leica SL : 2015
maybe the pattern on the red cloth is indeed fading?
In any case I found that the Fuji X Pro 2 and the X100F (from 2016/17 with 3rd generation X-trans sensor) both perform quite well (in contrast to the X Pro 3).
And the humble Sigma DP1 from 2007 is truly stellar indeed:
https://www.imaging-resource.com/IMCOMP/COMPS01.HTM
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
SigmaForums
SigmaForums New Member • Posts: 5
The red/gold contrast in the other red fabric is interesting though. The fp seems to do better with some of the other fabrics.
 SigmaForums's gear list:SigmaForums's gear list
Sigma sd Quattro H Sigma fp Sigma 35mm F1.4 DG HSM Art +5 more
