Loss of sharpness on Canon 100-400
Started May 4, 2020 | Discussions
Cporosus1 New Member • Posts: 6
Hello everyone,
I have a question to ask- is it possible for a lens (in my case, the Canon 100-400) to lose sharpness? I have been using this lens since 2008 (it is the "dust pump" model not the newer one) and I have traveled all over the world with it (Australia, Belize, Brazil, Costa Rica, Indonesia, Singapore, South Africa, Sri Lanka, etc. some multiple times). Despite a few superficial blemishes from years of wear, there does not appear to be anything mechanically wrong with it. However, over the last couple of years, I've noticed it just doesnt "nail" some of the shots that it would have before. It seems I need to be almost entirely still to get a sharp wildlife shot, whereas before I could be moving or on a boat, etc. and still get the shot. Should I give up and get a new lens or do you think a cleaning may help? Can accumulation of dust inside the lens cause this? I don't think it is the camera itself. I have a Canon 7D Mark II and I purchased it much more recently (November 2016) and my smaller lens doesn't have the same problem.
Thanks!
WindwardHaole Senior Member • Posts: 1,550
Re: Loss of sharpness on Canon 100-400
I don't think the problem is caused by dust. Twelve years on a zoom will result in some internal wear and misalignment, in what manner and if it is noticeable depends on the user.
Andy01 Veteran Member • Posts: 5,191
In addition to the above comment about wear and tear, is it possible that after 12 years your hand might not be as steady as it was back then
Seriously though, have you checked that the IS is actually working as it should (or at all) ?
I owned one from 2009 to 2017 and it was a great lens. The only signs of wear and tear on mine was the zoom creep got worse, and the tension ring had to be tightened all the up to stop it.
Worth noting that the IS on the 100-400L ii is significantly better - 4 stops vs 2 stops.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
John Sheehy Forum Pro • Posts: 26,698
Cporosus1 wrote:
Hello everyone,
Thanks!
Maybe the IS switch is dirty, or the IS module is dead.
If IS is working, you will see the view get more stable after you half-press the shutter button, and become less stable a couple of seconds after you release the shutter button.  You should also feel a small kick when it kicks in and out.
If the switch is on, and there is no IS, try moving the switch through its range several times to wear away any oxidation.
CameraCarl Veteran Member • Posts: 9,204
Have you adjusted the microfocus recently? That might help.
OP Cporosus1 New Member • Posts: 6
Hi everyone, sorry for the delay. Here are some photos of my settings. Also attached a recent snake closeup...it looks fine but its not tack sharp. Settings were- f/14, 1/640 sec., iso400, 100-400mm lens Does everything look right for wildlife?
I am not familiar with a 7D ii so I cannot comment of specific settings.
Was the snake moving a little or perfectly still (I would guess moving a little) ?
How far away was the snake from the camera (ie. the subject distance) ?
Were you in Servo AF ?
Were you using BBF (Back Button Focusing) ?
I seldom use spot AF point because I find that usually just the normal single AF point gives a better result.
At f14 you are not going to get the sharpest result from the lens as diffraction is becoming evident.
The white scales under the rear end of the head appear to be quite sharp, which makes me think that perhaps the snake moved a little between you locking AF (presumably on the eye ?) and the shot being taken ?
Colin
maiaibing Veteran Member • Posts: 5,139
Cporosus1 wrote:
Hello everyone,
You can have been unlucky and it got a bump somewhere along the way misaligning the lens elements. Try sending it in for adjustment.
 maiaibing's gear list:maiaibing's gear list
Canon EOS 5DS R Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM Canon Extender EF 1.4x III Canon Extender EF 2x III +5 more
