Video and Binaural Audio
Started May 1, 2020 | Discussions
Markr041 Forum Pro • Posts: 10,078
8
A lot of videos have the purpose of providing the viewer the experience of visiting an interesting setting, recreating the experience of being there. Ambient sound is of course an important part of that experience.
Binaural audio provides, if the viewer uses headphones, a three-dimensional out-of-head sound field that realistically reproduces what the scene sounded like if one were there. It is superior to stereo - which provides some sense of space, but with headphones it is all in one's head, and thus very artificial. Binaural surrounds you with sounds - you hear sounds behind you, above you, to the right and left, just like in the real world.
What is great about recording binaural audio is that one only needs two mics, so any camera with a stereo mic input can be used (no need for any external audio recorder, leaving aside the quality of preamps etc.). And any listener can experience it with no special equipment (unlike VR or 3D video).
They key aspect for recording binaural is that it simulates how you hear - you hear with two ears (so two mics) that are separated by your head. So, binaural recording puts the two mics in your ears (or the ears of a dummy head). That's it.
Roland makes a cheap (omnidirectional) mic/earbud combo (CS-10EM) with excellent fidelity properties - you put it your ears, just like any earbuds (it looks just the same). It has wires with two plugs - for the mic-in and for the headphone out (the latter is not required). So if you have a headphone jack in the camera or recorder you can monitor exactly what the mics are picking up, which of course is exactly what you would hear without them! So, the rig adds nothing to weight and is inconspicuous.
For editing, no special decoder is needed and for listening, again, no special equipment is needed - just any headphones or earplugs. For $99 and no cumbersome rigging you record better surround sound than DTS or Dolby Atmos or any artificial attempts at reproducing how you hear.
So, you see I have recently begun to explore this very old technology. And here is my first attempt at using it - in a rainstorm:
Put on your headphones if you want to experience the surround - what I heard when I shot the video. And, btw, if you listen with speakers you still get stereo; it sounds perfectly fine, just you lose the true spatial nature of the sounds, like sounds literally behind or above you!
I will be shooting using this rig in other environments to further test it out. The mics come with wind shields, which are very important - you can hear wind without distortion too.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 16,109
Re: Video and Binaural Audio
That sounds very cool, a far cheaper option than the fancy binaural dummy head microphones which are supposed to reproduce the delay and shaping of sound that reaches each ear through the mass of your head. Using your actual head do to it - well now that's using your head!
It's something I would have loved to try out, except that my left ear is now kaput, which means I've totally lost my ability to perceive stereo sound or indeed even tell which direction a sound is coming from.
OP Markr041 Forum Pro • Posts: 10,078
Trains, Subway and Stions in Binaural Audio and 4K
Headphones for the full experience, but even without them you get a lifelike spatial audio and video experience.
Stations, train ride, subway ride, trains and subways enter and exit.
AZMario Regular Member • Posts: 259
That is too cool! Thinking I should get a pair.  At the moment is is pretty quiet in the neighborhoods in AZ but that will change eventually.
 AZMario's gear list:AZMario's gear list
Nikon D7200 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +3 more
Pov2 Senior Member • Posts: 1,192
I fail to understand how this binaural is different from stereo. Can anyone explain? Both have two channels for audio. There is no additional information provided like additional channels. Only two channels...
Sean Nelson
The idea is that your brain learns to differentiate sound direction not just by the sound that arrives via the air into your ears but also through the mass of your head.   So you heard sound off to your right in your left ear because it arrives via air into the left ear canal, but it also goes through your head.  And there's a difference in the timing of those two arrivals.
So you experience live sound differently than if you merely record two channels with mics pointing in opposite directions.
Binaural audio tries to recreate the sound experience by recording with two microphones embedded in a dummy head with similar characteristics to the human head to try to recreate this.  By putting the mics in a pair of earbuds, you replace the dummy head with your own actual head.
See Wikipedia article on Binaural Recording
More Video and Binaural Audio Music
PhilPreston3072 Senior Member • Posts: 2,660
That is so cool!  I first heard this 3D effect from a friend who shared the Cetera effect "Barber shop" demonstration.  I'd thought they'd used special high tech computer processing to get the amazing 3D sound to work with regular headphones.  But after seeing your demo and digging around online a bit, I can't believe all that they did was stick a pair of mics in a dummy head where the ears are.
These Roland in ear mics are an awesome idea, wish I'd known of these sooner.
Thanks Mark
 PhilPreston3072's gear list:PhilPreston3072's gear list
Canon EOS 450D Canon EF-S 18-200mm f/3.5-5.6 IS +1 more
Tom899 Senior Member • Posts: 1,241
All good info. I’m now retired, but what I did for a living was record sound and vibration for Ford Motor Company. My equipment for sound usually was an Aachen Head by Head Acoustics. This device looks like a human head and shoulders and has a mic in each ear. This is a global recognized company that most all auto manufacturers use. The Aachen Head usually is placed in the front passenger seat. The data is recorded and analyzed. And of coarse listened to with high quality electrostatic headphones. Head Acoustics also has the in-ear mics. So, I’m very familiar with binaural recordings, great stuff! Nice to see this brought up.
-Tom
 Tom899's gear list:Tom899's gear list
OM-1 Sony RX100 VII Panasonic Lumix G Fisheye 8mm F3.5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +18 more
Great info. I have always been tempted to try electrostatic headphones.
Here's what it looks like, minus the fixture. As you've experienced, once you listen to binaural recordings there's nothing else like it, hard to explain.
Brief description from their website.
"The artificial head geometry offers you:
a mathematically describable reproduction of the human head and shoulder geometry with an award-winning design
an accurate reproduction of all acoustically relevant parts of the human outer ear
Turn it on - Record - Done!
The HEAD Measurement System IV is a stand-alone, mobile measuring device that is ready to perform aurally accurate binaural recordings immediately after powering up.
The recordings can be saved directly to a CompactFlash card, allowing stand-alone operation without a notebook or PC. Via the integrated headphone output, the recordings can be played back immediately with aurally accurate equalization."
Artificial head measurement systems like the HMS IV are compatible with conventional measurement technology and are necessary for an authentic hearing impression during playback.
-Tom
LSHorwitz1 Senior Member • Posts: 2,524
5
I have stopped posting actively in this forum years ago, but occasionally browse here
This thread energized me to post, since I spent a considerable period of my earlier engineering employment directly engaged in binaural systems.
The ability to do an accurate localization of sound sources has particular importance for use in certain military applications, where pilots can react more quickly and reliably when their headset provide them with accurate localization of impending missles or other weapon attacks. Being able to reliably locate these threats using sound sources above, below, behind, and in front of the aircraft is of paramount importance in choosing evasive maneuvers.
In addition, binaural audio for entertainment purposes was quite popular starting in the 1970s by the release of certain commercial equipment which capitalized on this binaural effect . Bob Carver, who started several important audiophile companies including Phase Linear Corporation, Sunfire, and Carver Corporation, introduced his patented "Sonic Hologram" equipment to generate a unique variant of binaural sound fields with previously captured specially recorded vinyl disks and other media. Several competing systems were also introduced, along with a wonderful assortment of binaural recordings, many of which were released in Germany and elsewhere for sale here in the US. Some were recorded with the Aachen head, others with a similar manikin head and microphones made by Shure Corporation.
Key to the technical achievement of binaural sound are a couple very important facts which nobody in the above discussions in this thread appear to be aware of. I will include this information below for those who have a technical interest in how the binaural process actually works.
The fundamental mechanism relies on the fact that the brain can measure the so-called "Inter-Aural Time Delay" time, sometimes referred to as Ithe ITD. With the exception of sound sources which lie precisely equidistant from the left and right ear, every other sound source has a difference in arrival time between the sound arriving at one year versus the sound arriving at the opposite ear. The actual time difference is merely a result of the actual size of the human head for the individual, which notably differs from one person to another, but also differs as we age from infancy to adulthood.
In addition to this ITD which our brain learns to correlate with the angle of arrival of the sound, there is also masking and shading effects caused by the acoustic opacity of the head, making a sound coming to our left ear directly but heavily shadowed by our head when it arrives later at the other ear to hear frequency response differences. Again, our brain over tme learns to calibrate this filtering to allow us to distinguish sources in front of versus sources behind our head, along with vertical discrimination.
To make this even more interesting and complex, the fine details of our exterior ear anatomy, essentially the shape and spacing of the convolutions of the earflaps which are found on the sides of our head cause a time
filtering effect which is known as 'comb filtering' which gives us fine angle discrimination ability. These folds and hills and valleys of the outer ear are called "pinnae", and further refine our positional estimates.
There are many general articles in the audio engineering literature which document all of this anfmore, including decades of university research and corporate investment to understand and capitalize on this mechanism of human hearing which can be exploited for both entertainment as well as things like pilot workload reduction as I mentioned earlier.
I hope this lengthy but not too technical post provides some enlightenment for those who have an interest in this topic.
Larry
burkek
burkek New Member • Posts: 7
Released my first 4K video with binaural sound. Made a binaural head with silicone ears and highly sensitive mics at the bottom of the ear canals. Recorded 48KHz 24bit to a Tascam DR-60DMkII.
Soundbar 059 - Incredible BINAURAL 3D SOUND - Nature - Stream
You will hear sound in a 360 degree arc around you and can pinpoint planes flying over your head. Wear headphones.
 burkek's gear list:burkek's gear list
Nikon Coolpix AW110 Panasonic Lumix DMC-ZS40 (TZ60) Nikon D80 Nikon D610 Nikon AF-S Nikkor 50mm F1.8G +2 more
You Can Even Record Binaural Audio with a GoPro - and Move Around
Perfectly nice for music too,
burkek
Re: You Can Even Record Binaural Audio with a GoPro - and Move Around
The Roland CS-10EM binaural earbuds - which I believe is what was used for this video - are far from ideal in representing binaural sound. The mics are outside the ear instead of at the bottom of an ear canal, which is where they should be. Also, the mic preamp on the Hero 11 is, well, consumer. This Hero + Roland solution is portable, yes, but you get what you pay for. The audio is basically stereo, and the video is akin to smartphone video.
You seem to have missed the point about video - it should be interesting. Action cams open up possibilities for interesting shots that cannot be produced by even the best professional cameras. Congratulations on having posted the most boring video probably ever in this forum - 15 minutes of flowing water!
Relatedly, you criticize not how a video looks or sounds but criticize the equipment used as not being ideal. Nevermind the content.
Let us not equate what is not ideal for what is not good. And not mistake what is ideal for what is actually valuable. As you seem to have.
burkek
The easiest way to think about stereo vs, binaural: stereo sounds like it's coming from inside your head. Binaural sounds like it's coming from outside your head - 360 degrees + from above you.
Flickr: https://www.flickr.com/photos/burkek/albums
Sony A1, Sony A6500, DJI Osmo Pocket
sludge21017
sludge21017 Veteran Member • Posts: 3,813
Maybe my headphones are better than what you are listening on.
I don't hear it in my head. Its definitely outside my ears (the rain drops, the car splash ).
They are claimed to be "3D". Works great on Xbox - I can tell depth.
https://www.bestbuy.com/site/rig-400hx-3d-audio-gaming-headset-for-xbox-series-xs-and-xbox-one-black/5923414.p?skuId=5923414
burkek
I'm listening on AKG K141 studio headphones + Bose QuietComfort 35's.
The Roland binaural earbuds are a simple, budget way to get into "binaural" sound though they leave MUCH to be desired in terms of effect and sound quality. I didn't say to anyone that there is NO binaural effect, but it is comparatively minimal compared to authentic capture devices witch replicate human ears with ear canals and mics placed where our eardrums would be. Authentic binaural sound needs the reflections provided by the shape of the ear, the shape of the ear canal and the density of the material between the left and right "ears".
Hear the astounding difference between a 3dio device (still not ideal) and the Roland solution:
https://www.youtube.com/watch?v=jGNGSgxUzX4
Most of the commentors of that "video" preferred the Roland. Fidelity matters too.
Carrying around a dummy head is not practical for almost any video applications that anyone would want to watch, as your posted video clearly exemplifies.
Bose headphones are horrible; no sound professional would use them for gaging audio fidelity. Your AKG is a decent budget headphone, but nobody would use it seriously for professional monitoring. Try Sennheiser 650 and come back with comments about audio.
Comments on all of my Roland-miced videos suggest that viewers were able to discern the advantages of binaural stereo, some even going on to to try it themselves. If you actually were an enthusiast for this type of recording you should be grateful, rather than a grouch pushing a wholly impractical method for videography.
There are other practical in-ear kits, from Sound Professionals, which mount the mics in the ear pinna.
