55-200: Great lens for good light
Started Apr 30, 2020 | Discussions
rz64 Regular Member • Posts: 454
6
In winter, my 55-200 was almost unused. But now, with better light, it becomes obvious that it can produce very good results. Only downside (beside the small apertures, which is a tribute so size, weight and costs) is the minimum distance of 100 cm. Sometimes I'd like to have a little smaller distance.
Here are some shots with different subjects and different focals lengths. To my mind, it is great fun shooting with this lens.
 rz64's gear list:rz64's gear list
Canon EOS M6 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
Greg Edwards Regular Member • Posts: 487
Re: 55-200: Great lens for good light
Nice images, I like that lens too. It's great for wandering around a zoo too!  Thanks for sharing.
You could try extension tubes or close up lenses if you want to reduce that minimum focus distance.
 Greg Edwards's gear list:Greg Edwards's gear list
Canon EOS M5 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM HP Photosmart B110 +3 more
adventurer69
adventurer69 Senior Member • Posts: 1,938
Oh yes it is .Great photos .
 adventurer69's gear list:adventurer69's gear list
Canon PowerShot A590 IS Canon PowerShot SD880 IS Canon PowerShot SX50 HS Canon EOS M Canon EOS M50 +11 more
Passrider Forum Member • Posts: 61
Nice potos! I am really enjoying this lens, too. I have used both extension tubes and an old screw on macro filter to good effect.
OP rz64 Regular Member • Posts: 454
Thanks to all feedbacks. I will try to follow your hints to reduce minimum distance for this lens.
Good luck and enjoy shooting.
Ralf
Persizi
Persizi Regular Member • Posts: 100
You can use Canon 500D 52mm Close-Up Lens, as I do. It is perfect combination.
 Persizi's gear list:Persizi's gear list
Canon EOS M50 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 32mm F1.4
Alexis
Alexis Senior Member • Posts: 1,998
It's a great lens and so light that I take it with me when I go mountain biking mounted on my M50 and attached to a quick release buckle on the strap of my back-pack.
Here are a couple of examples from my collection:
 Alexis's gear list:Alexis's gear list
Canon EOS 50D Canon EOS M50 II GoPro Hero9 Black Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-M 11-22mm f/4-5.6 IS STM +12 more
JRET
JRET Contributing Member • Posts: 840
Really like your images. What style settings are you using on the M50?
 JRET's gear list:JRET's gear list
Canon EOS M6 II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4 +7 more
Alexis
Thanks. As I have never looked at style settings I am guessing "default". These are lightly post-processed in Photoshop using a "wedding" Action that I have developed and fine-tuned through the years but it's not too evasive - these are all close to the originals..
