Fujifilm 16-55mm Lens Mount Issue No Longer Connects to Camera
Started Apr 30, 2020 | Questions
philburgess New Member • Posts: 2
This might seem either a simple or crazy question, but I was wondering if anyone has had a problem where the lens can be connected to the camera one day, but won't connect the next. All the screws have been checked and are tight and OK, it has never been dropped or treated roughly and I have tried the lens on 3 different bodies - XH1, XE3, XPRO1 and XT1.
The lens can be placed into the mount but win't turn. It's almost like the lens has warped or there is a ridge stopping it turning to engage. I did notice that from new this lens was very tight in the mount, but it just stopped connecting.
i was thinking about filing the leading edge in case of a tiny burr, but I thought I would see if anyone here has had a similar experience.
I don't fancy sending it back to Fuji (I live in the UAE and there is only a distributor who is not the greatest)
Any similar experiences and your eventual solutions would be much appreciated
 philburgess's gear list:philburgess's gear list
Canon PowerShot G1 Sony RX100 II Canon EOS 5D Mark III Fujifilm X-E2 Fujifilm X-T1 +20 more
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-Pro1 Fujifilm X-T1
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
Re: Fujifilm 16-55mm Lens Mount Issue No Longer Connects to Camera
My first thought, to verify whether you ARE crazy or not [g], involves close scrutiny of the lens locking pin on the body (could it be catching a screw?). There are 7 screws to tighten at the back of the lens, but only one on the mount itself, I think, could interact with the pin. Try mounting with the lens release pressed.
The next thought is to request photos of the lens' mount from various angles, as well as the mount on the camera, to help assess what you're encountering.   In lieu of that, you might closely scrutinize that lens' mount to compare with another that mounts with no issue.
...Bob, Bovina NY
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
a_c_skinner Forum Pro • Posts: 13,047
As Bob says "Try mounting with the lens release pressed."  I've had occasional problems with a lens and this worked with seemingly no problems.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
