XE series, favorite lens pairings and thoughts
Started Apr 28, 2020 | Discussions
Robmas4229
Robmas4229 Senior Member • Posts: 1,272
There's another poll/discussion regarding how may of us have an XE camera, and which one(s) we have. Some interesting comments there.
https://www.dpreview.com/forums/thread/4484796
I'd like to ask those who use XE bodies, to elaborate and tell us what is your favorite lens pairing with your XE?
Thanks in advance for entertaining my SAQ.
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm X-T30 II Fujifilm XF 23mm F2 R WR Fujifilm XF 18-55mm F2.8-4 R LM OIS +7 more
John Gellings
John Gellings Veteran Member • Posts: 9,741
Re: XE series, favorite lens pairings and thoughts
My favorite is the 35mm F2.  I also really like the 56mm 1.2 and 16-80mm while using a wrist strap.  Weird, I know.  The 27mm is great when I want the absolute smallest lens for portability.  I prefer the 35mm F2 though.
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-Pro3 Fujifilm GFX 50R Fujifilm X-E4 Leica M Typ 240 +6 more
Robmas4229
OP Robmas4229 Senior Member • Posts: 1,272
I guess I should've started out with my own favorite.
Although the 18-55 is mounted most of the time for flexibility, it's the 35 f1.4 that I have the most fun pairing it up with. If I'm traveling with a two lens kit it's usually those two. They both bring something different to the table.
Doug MacMillan Veteran Member • Posts: 3,695
Fuji X-E2s, Leitz DR Summicron f2 at close range and f2. RAW file converted in SilkyPix, the PS.
I've hung everything from a vintage Nikkor 35mm f3.5 circa 1953 to a Canon EF 70-200 f2.8 on my X-E2 and X-E3 cameras.
Like you, I like the 18-55 for versatility and OIS. It's really a great lens. There are three lenses I've been shooting with a lot lately. They are the 16mm f1.4, the recently released XC 35mm f2 and a vintage Leitz Summicron Dual Range 50mm f2.
The 16mm is the lens that sold me on Fuji. I rented it for a week when looking into going Fuji. I also rented the 18-55 and the 23mm f2. While the others are fine lenses, the 16mm was the standout.
After reading positive reviews, I decided to try the XC 35mm. It's a great little lens - very lightweight with comparable sharpness and AF performance to its older XF 35mm sibling. The lack of an aperture ring and the plastic construction don't bother me.
My Leitz DR 50mm has always been a special lens, one of my all time favorites. Some of my all time favorite photos have been taken with it and my Leica M3. I've actually had a photo published internationally that was taken with that kit.
More modern lenses are sharper and more contrasty, but nothing compares with the Walter Mandler designed Summicrons for bokeh and "character". The new Summicrons are technically better but don't have that magical look of the Mandler Summicrons.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E3 Fujifilm X-H1 Fujifilm X-E1 Fujifilm X-E2S +10 more
MartinNorfolk
MartinNorfolk Regular Member • Posts: 483
For me either the 35 f2 or the 23 f2.
I am very tempted right now to also get either the 18 f2 or the 27 f2.8 as it would then just slide into a pocket.
AUMRJ New Member • Posts: 13
More often than not my X-E3 has the Touit 32 1.8 on it.
a_c_skinner Forum Pro • Posts: 13,047
The 23/2. The 27/2.8 makes more sense though.  I use the Zeiss 50/2.8 too.
The 16-55/2.8 works well too.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 80mm F2.8 Macro +7 more
Escaping Senior Member • Posts: 1,405
XE series, most used is 18/2.0
While the 18/2.0 is not the top lens as IQ goes, I find that it is the one I have used the most with my XE2S.  The combo is small, light, fast enough for street and for casual events (like family reunions).
Just FYI, to have a context, here are my "default" pairings for my Fuji X:
- XE2S:  18/2.0 (as mentioned above)
- XE3:  23/2.0
- XT1: 50/2.0
- XT10:  Viltrox 85/1.8
- XT2:  10-24/4.0 (or 16/1.4 + 56/1.2)
- XT20:  23/1.4 (or 10-24 when the XT2 has the primes because I also pair the XT2 with the XT20)
so there you go, my combo's
Esc (CT, USA) www.pbase.com/cvanlang
 Escaping's gear list:Escaping's gear list
Fujifilm X20 Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LF1 Panasonic LX100 Fujifilm X30 +102 more
LASwede
LASwede New Member • Posts: 24
For my X-E1 I normally use the 35mm f/1.4, 14mm f/2.8, and 60mm f/2.4. The optical quality, and light weight of these lenses, works well with the X-E1 body. I have also used the 55-200mm frequently with really good results.
 LASwede's gear list:LASwede's gear list
Fujifilm X-T2 Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +3 more
jslade797 Regular Member • Posts: 326
My street photography kit is an X100 series around my neck and an X-E3 with a choice of either the 18mm f2 or 35mm F1.4. Love the rendering on both these lenses.
I also own the 35mm f2 and it's an absolutely exceptional lens - just find myself reaching for the look and extra stop of the f1. 4 these days.
Instagram - @jontyslade
 jslade797's gear list:jslade797's gear list
Fujifilm X100V Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R
(unknown member) Senior Member • Posts: 2,057
27mm. Makes it super lightweight and jacket pocketable. Even squeezed in jeans pockets.
I also like the 18-55 (or previously the 16-50).
The 27 is too slow to focus on my XE2 sometimes so will be adding the Viltrox 33mm very soon, which looks similar in size to the 18-55. Wouldn't want to go bigger.
All the Fujicrons fit nicely. But doubt I will go back to them in favour of the Viltrox newies.
The Davinator
The Davinator Forum Pro • Posts: 24,707
The 18 is great for street.  And I agree about the 35 f/1.4.  I prefer the extra light and the nicer rendering compared to the f/2 version
