Astrophotography - starlink
Started Apr 24, 2020 | Discussions
markyboy81 Veteran Member • Posts: 4,778
I'm going to attempt to take photos of this tonight.
What equipment would be best do you think? I have the NX1 and nx500 and most of the lenses - I'm thinking 12-24mm?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Samsung NX1 Samsung NX5 Samsung NX500
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
Re: Astrophotography - starlink
Suggest using this source to help pick the best lens in your collection
https://www.lonelyspeck.com/milky-way-exposure-calculator/
>I'm thinking {Samsung] 12-24mm
Used the above source, I selected APSC, 12mm, F4, and here are the results:
1. Shutter Speed: 28 seconds
2. ISO: 3200
Others valuable sources:
https://astrobackyard.com/the-500-rule/
https://youtu.be/7avrjSOX7hs
"What gets us into trouble is not what we don't know. It's what we know for sure that just ain't so." -Mark Twain
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
flip 21
flip 21 Senior Member • Posts: 1,439
2. ISO: 3200
I agree with TuVu. The man knows what he is speaking about I love the 12-24mm, so wide, and sharp... nice photo shooting Marky
flip 21
Does Astrophotography proves the earth is flat?
How is your astrophotgraphy going? Have you came to the conclusion that the earth is indeed flat
Can you explain me if these video makes sense?
https://www.youtube.com/watch?v=X-w8acuxF6w
https://www.youtube.com/watch?v=hdNFo5eWf9g
Barple Regular Member • Posts: 263
Samyang/Rokinon 12mm f2 for sure
 Barple's gear list:Barple's gear list
Samsung NX300 Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +6 more
Lawrence Norman
The OP's question based on OP's Samsung Lenses via OP's gear list.
I own the Samyang/Rokinon 12mm f2 for Astrophotography
Lawrence Norman
Yes when viewed from 'trip' on on LSD
OP markyboy81 Veteran Member • Posts: 4,778
I did own that lens for a short while but didn't really get on with it - not used to manual focus!
As an update I used the NX1 plus 16-50 s.
Turned the OIS and focused to infinity but the resulting stars were blurry? Realised that I made the schoolboy error of pressing the shutter button rather than using a self - timer so perhaps that was why.
Also, maybe the tripod wasn't stable enough.
Also also I didn't see the starlink so all in all it was a bit of a waste of time. Maybe astrophotography isn't for me.
Lawrence Norman
When shooting on tripod one must disable OIS.
"Image Stabilization (and vibration reduction) lenses look for vibrations in your camera in order to reduce it – however if they don’t find any (like when you are using a Tripod) they actually can cause it – and as a result actually cause camera shake."
Source: https://digital-photography-school.com/image-stabilization-on-tripods/
One of many 'Sources' regarding OIS with Tripod.
Sorry, I meant to put that I turned it off.
flip 21
Martin Luther King Jr. on Why Jesus Called a Man a Fool Speech (Transcript)
Martin Luther King Jr. on Why Jesus Called a Man a Fool Speech (Transcript):
"... And oh yes, I prayed a prayer and I prayed out loud that night. I said, “Lord, I’m down here trying to do what’s right. I think I’m right; I think the cause that we represent is right. But Lord, I must confess that I’m weak now; I’m faltering; I’m losing my courage. And I can’t let the people see me like this because if they see me weak and losing my courage, they will begin to get weak.”
And it seemed at that moment that I could hear an inner voice saying to me, “Martin Luther, stand up for righteousness, stand up for justice, stand up for truth. And lo, I will be with you, even until the end of the world.”
And I’ll tell you, I’ve seen the lightning flash. I’ve heard the thunder roll. I felt sin- breakers dashing, trying to conquer my soul. But I heard the voice of Jesus saying still to fight on. He promised never to leave me, never to leave me alone. No, never alone. No, never alone. He promised never to leave me, never to leave me alone.
And I’m going on in believing in him. You’d better know him, and know his name, and know how to call his name. Don’t be a fool. Recognize your dependence on God."
https://www.youtube.com/watch?v=Ia-RSTHW0lY
More about the stars on a flat earth, Is this all a lie? Does it makes any sense? Is it an heresy, is the Globe earth a religious dogma? I'm just curious about it.. THis is what happens when you're stuck in home, in quarantine
https://www.youtube.com/watch?v=C7VfTo6BX1o
When you say "focused to infinity" do you mean that you focused the lens all the way to the right on the camera focus distance scale?
Yes, all the way to the infinity symbol. Is that right?
That'll explain why your photos were blurry.  They were actually out of focus!  The Samsung 16-50mm S, pretty like much all focus by wire lenses, can focus PAST infinity.  Even the lovely Samyang 12mm does that and that's a manual focus lens.
Infinity focus is actually around about 1 bar away from the right (hard to explain) and it's a matter of trial and error to get the focus spot on.  You will you need to take a test shot, review it, adjust the focus a little bit closer or further and test again.  Repeat until you're happy with how sharp the stars look.
If you happen to find a bright enough star you can try pointing the camera directly at the star, bump up the ISO and use the x8 manual focus assist to help find the focus sweet spot.  I've never succeeded with this method on my NX1 or NX500 though because once the ISO reaches a certain point it's too noisy to see the stars on the LCD screen.  (This method works on my Sony A7r4 and saves me A LOT of time).
Now here's the other thing - once you have found the perfect focus, don't turn off your camera until you're completely finished!  This will reset the lens back to it's default focus position and you'll have to do it all over again.
With all that said, the 16-50mm is a wonderful lens for astro because i find it quite sharp at 16mm and f2 is just excellent for astro.
The stars are actually sharper than this but I tried stacking and couldn't get it perfectly aligned.
Past infinity? Like Buzz lightyear said, 'to infinity and beyond!'
Actually, I do recall this being the case now but I wonder what actually would be in focus when it's in that position? Does it start to come back again? I will perhaps give it another go at some point, although I don't think astrophotography is for me. That's a great shot you got there - mighty impressive!
