Patents related to photo lenses
Dibyendu Majumdar Contributing Member • Posts: 787
Hi,
Starting a new thread - not specific to Nikon lenses unlike the previous threads here and elsewhere (see https://www.dpreview.com/forums/post/63122995).
OP Dibyendu Majumdar Contributing Member • Posts: 787
Leica SL 50mm f1.4 by Konica Minolta?
The famous Noctilux 50mm f1.2
This was world's first 35mm lens with aspherical elements - two of them!
https://patents.google.com/patent/US3459468A/en
Also see:
https://www.pacificrimcamera.com/rl/00307/00307.pdf
Leitz 800mm f6.3
I think this one is for the Leica 800mm f6.3 which was one of the earliest 35mm lenses to feature ED like glass.
https://patents.google.com/patent/US3536379A/en
Sonnar® T* FE 55 mm F1.8 ZA Designed by Sony not Zeiss?
Canon RF 50mm f1.2
Sigma ART 35mm f1.2 for mirrorless
Sigma ART 70mm f2.8 Macro
Sigma ART 105mm f1.4
Sigma ART 50mm f1.4
Sigma ART 35mm f1.4
Canon EF 50mm f1.0L
Leica Summicron Mandler 1976
bclaff Forum Pro • Posts: 10,952
Re: Leica SL 50mm f1.4 by Konica Minolta?
Dibyendu Majumdar wrote:
https://uk.leica-camera.com/Photography/Leica-SL/SL-Lenses/Prime-Lenses/SUMMILUX-SL-50
This patent by Konica Minolta appears to be related if not an exact match:
https://patents.google.com/patent/US10302898B2/en
Definitely no.
Or maybe this one:
https://patents.google.com/patent/EP3136147A1/en
Not perfect but close enough From the PhotonsToPhotos Optical Bench:
Best viewed "original size"
Patent optical prescription (Example 1) over the Leica lens construction diagram.
Here the link: Leica Summilux-SL 50 f/1.4 ASPH
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Re: Leitz 800mm f6.3
FWIW, the patent specifies f/5.9 but they certain could have reduced the element sizes slight for f/6.3
Play with it here . You can change 01 to 01U to see the unscaled version.
Nice - the link may be incorrect?
I am attaching some info that might help fine tune:
Alsop this link:
https://www.l-camera-forum.com/leica-wiki.en/index.php/800mm_f/6.3_Telyt-S
My bad. I forgot to hand edit the link. It should be this .
Alsop this link:
Thanks. I used that construction diagram to make a 'P' version for publication.
Re: Sigma ART 35mm f1.4
https://patents.google.com/patent/JP2014048488A/en
I already had this one, which is a perfect fit:
link
Re: Sigma ART 50mm f1.4
https://patents.google.com/patent/JP2015114366A/en
This fit was no so good as most:
Link .
I've decided this is not a fit for my purposes.
In addition to not matching the construction diagram the patent has an aspherical element whereas the lens does not.
