"rumour" 70-300 4-5.6
Started Apr 22, 2020 | Discussions
John Gellings
John Gellings Veteran Member • Posts: 7,379
Re: "rumour" 70-300 4-5.6
jonikon wrote:
I would like to see an XC 18-135mm with similar optical performance as the inexpensive Canon EF-S 18-135mm ƒ/3.5-5.6 IS STM, ( Which the current more expensive Fujinon XF lens can not match, BTW).
The XF can’t match it but you expect an XC lens to match it?
 John Gellings's gear list:John Gellings's gear list
Fujifilm X100V Fujifilm X-E3 Fujifilm X-Pro3 Sony a7C Fujifilm XF 35mm F1.4 R +6 more
CAcreeks
CAcreeks Forum Pro • Posts: 16,331
That might have been a slip of his left index finger. 'Twouldn't make any sense to have an XC lens in that zoom range.
Here is a comparison of the XF 18-135 and EF-S 18-135, perhaps showing why the XF 18-135 is less than fully beloved on this forum.
https://www.imaging-resource.com/lenses/fujinon/xf-18-135mm-f3.5-5.6-r-lm-ois-wr/blur/fuji-x-e1/
https://www.imaging-resource.com/lenses/canon/ef-s-18-135mm-f3.5-5.6-is/blur/canon-7d/
John Gellings
No, he said XC and then referred to the current more expensive XF. Seems clear.
Mebyon K
Mebyon K Contributing Member • Posts: 842
I would buy a 70-300 (105-450) f4.0-5.6 if it had the image quality of my 55-200, I wouldn't buy it if were as weak at the long end as the 16-80.
I honestly believe that Fuji produced the 16-80 to quell the clamour for such a lens, particularly from a well known Fuji rumour site, as their optical designers knew full well that a zoom ratio of 5:1 and high optical quality are mutually exclusive.
Mebyon K
 Mebyon K's gear list:Mebyon K's gear list
Fujifilm XF 56mm F1.2 R
HatWearingFool
OP HatWearingFool Senior Member • Posts: 2,540
If it’s mutually exclusive how did other brands manage it?
To be fair the Fuji is cheaper. I got worried as soon as I saw the price. My old Zeiss 16-80 cost considerably more, but was a great lens. I was hoping that the Fuji would manage to at least match if not surpass a lens released in 2007, but sadly not.
But the Zeiss was 998$ in 2007 which equals $1242 in today’s money while the Fuji is $800. I really wish Fuji had gone for quality over cheapness. And the Nikon is $1066... that’s why so many of us were so worried when we saw the price of the Fuji, it didn’t bode well for its optical quality.
 HatWearingFool's gear list:HatWearingFool's gear list
Olympus PEN E-PM1 Fujifilm X-T20 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Fujifilm XF 18mm F2 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Mebyon K
When Optical Limits and LensTip tested the two lenses you mention their summaries highlighted the same problems, although with different strengths and weaknesses, as those of the Fujifilm 16-80. As I stated in my original post, the fact is that a 5x zoom ratio  and high optical quality are mutually exclusive. If you doubt that ask any high end optical design engineer.
Mebyon K
CAcreeks
Is this the Nikon lens you two are talking about? It looks excellent at 85mm though only f/5.6.
https://www.imaging-resource.com/lenses/nikon/16-85mm-f3.5-5.6g-ed-vr-dx-af-s-nikkor/blur/sub-frame/
Maybe constant f/4 was an ill-advised design goal for the XF 16-80.
HatWearingFool
Do this look like they are on the same level?
Fuji 16-80
"You can immediately notice high consistency for all focal length range and a very good performance at maximum relative aperture, which is slightly worse for the maximum results by f/5.6. These maximum results, reaching 43 lpmm, are worth the praise in themselves. The best primes reach 45-46 lpmm, and here we deal with a 5x zoom lens after all. "
The Zeiss was very consistent across the board.
Mebyon K
Fuji 16-80
Which test site are these taken from?
Mebyon K
georgehudetz Veteran Member • Posts: 4,953
Lenstip.
 georgehudetz's gear list:georgehudetz's gear list
Fujifilm X-T2 Panasonic Lumix DC-S1R Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +10 more
HatWearingFool
Fuji 16-80
Lens tip
CAcreeks
Lens tip
Does not look so good in this lab test.
https://www.imaging-resource.com/lenses/sony/16-80mm-f3.5-4.5-dt-carl-zeiss-vario-sonnar-t-sal-1680z/review/
HatWearingFool
Lens tip
Looking at their blur chart it looks like their copy was decentered.
optical limits got similar results to lenstip
“The Zeiss produced very good to excellent resolution figures in the MTF lab. The center resolution is nothing short of stunning at all focal lengths and apertures.”
https://www.opticallimits.com/sony-alpha-aps-c-lens-tests/141-zeiss-za-16-80mm-f35-45-dt--sony-alpha--review--test-report?start=1
From their conclusion:
”Assuming a good sample the Zeiss 16-80mm f/3.5-4.5 ZA DT is surely a desirable lens. The primary design objective was obviously to maximize resolution because this is where the lens shines with generally stunning MTF figures matching or beating many standard zooms out there.”
the Panasonic 12-60 2.8-4 is also a better lens than the Fuji in many respects but again it’s more expensive.
Fuji made the cheapest 24-120 equivalent lens and I think it shows. Nothing wrong with design towards cost. The problem is a lot of Fuji users claim the lens performs no worse than other systems 24-120 equivalents and that all 5x lenses are poor performers. Yes they won’t equal a prime or shorter range zoom but they can be built to work well.
DocetLector Contributing Member • Posts: 774
I don`t know if one can compare the 2 graphs as there are different numbers on the LH side of the charts. Either the Fuji lens is sharper at peak peformance or the Fuji chart is more spreaded.
Or do I miss something?
 DocetLector's gear list:DocetLector's gear list
Fujifilm X-T1 Fujifilm X-E2S Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Wezre Contributing Member • Posts: 779
No, I think they’re referring to the Nikon 16-80 f/2.8-4: https://www.imaging-resource.com/lenses/nikon/16-80mm-f2.8-4e-ed-vr-dx-af-s-nikkor/review/
 Wezre's gear list:Wezre's gear list
Fujifilm X-H1 Fujifilm XF 35mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR
CAcreeks
Different cameras, probably 16 Mp vs 24 Mp.
Hat Wearer, thanks for your theory about decentered Zeiss lens. You would think Sony could give them a replacement lens but NOOOOOOOOOO.
9VIII Senior Member • Posts: 1,185
LarsRost wrote:
johnbandry wrote:
Apparently the 70-300 will be F4-F5.6
Fuji Rumours
So that's 1 of the three unknown lenses.... 2 more to go.
Please, a premium, but not enormous 12mm f/2 with nice sunstars, and/or a premium and fast 18mm - not a pancake.
Don't be greedy: I'd like one of them to be a 300mm f/4 prime, that can take a teleconverter. Pretty please, Fujifilm.
Yes, a 300/4 and a 500/5.6! Even though I own the 100-400/4.5-5.6 it would still be great to a have a telephoto prime.
If you look at filter thread sizes, the two main selections for large lenses are 86mm and 95mm. If you're not going to hit an 85mm front element size it may as well be just over 90mm.
Of course the 75mm front element of a 300f4.0 is even more common, but that also gives it more overlap with other lenses and makes it less special.
At 375mm f4.0 the front element is 93mm, I'd say that's the longest you can affordably go at f4.0 and would be nearly ideal for a sports and wildlife lens. You get the field of view equivalent of Full Frame 560mm, plenty long, decent aperture (important for AF), I'd probably prefer it over my Canon 400f5.6.
If there were such a thing as a 400f4.3 that would be just as good but I think people would concentrate more on the aperture speed than the focal length.
 9VIII's gear list:9VIII's gear list
Canon EOS 1100D Fujifilm X-E2S Fujifilm X-E3 Canon EF 400mm f/5.6L USM Sigma 150mm F2.8 EX DG Macro HSM +7 more
HatWearingFool
Most testing sites claim they get the lenses themselves so that companies can't cherry pick. Optical Limits says if they get one with obvious flaws (like decentering) they will try to get another.
HatWearingFool
The Sony was tested on a 10.2 megapixel camera. You can't compare absolute numbers across megapixels, but the overall trends will stay the same as the megapixel goes up. This is why sites like optical limits usually tell you what good, avg, great, or amazing scores would be for a lens. Because newer cameras are expected to resolve much higher than old ones which means you can't directly compare old reviews with new ones.
oscarvdvelde Senior Member • Posts: 1,365
Fuji Rumours
It looks nice, but then you realize that for 1/2 stop, 30% narrower and an aperture ring you will lug around something 2.5x the size and weight of the XC 50-230mm, and because of that leave at home 2.5 times as often.
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
