What is the impact on using EF mount adapters on the M and RP?
Started Apr 22, 2020 | Questions
speed1268 New Member • Posts: 18
Hi, After recently asking about an upgrade to my M5 and Thanks for all who gave advise.
A question came up regarding the effects of using the EF adapter I guess it would be similar on both the M and RP.
What should one take into consideration when using the adapter?
Thanks again speed.
Alan Sh Senior Member • Posts: 2,758
Re: What is the impact on using EF mount adapters on the M and RP?
Nothing really.
Some clone adapters have matt black inside to stop/reduce reflections.
But otherwise, it's just electrical connections.
Alan
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
M Stewart Contributing Member • Posts: 985
I notice the weight of the adapter!
Particularly on my otherwise very compact M.  On my M5 it's less noticeable...  But it opens the way to using my stock of EF and EF-S lenses.
M. Stewart
Milton Keynes, UK
 M Stewart's gear list:M Stewart's gear list
Canon EOS M Canon EF 15mm f/2.8 Fisheye Canon EF 20mm f/2.8 USM Canon EF 24mm f/2.8 Canon EF 35mm F2.0 +15 more
ken_in_nh Senior Member • Posts: 2,399
The lens seems longer.  Oh wait, it is, since you need to make up for the shorter camera body depth.
More seriously, the balance of some lens camera combinations will change, both due to the lighter weight of the camera, and because the lens weight (center of gravity of the lens) is further away from the camera.  So holding the camera alone can be harder.
AshleyMC Senior Member • Posts: 2,228
I have zero problems using adapted Canon EF lenses on my M and R. I suppose the same can be said regarding the RP, which I don’t own.
On my M, I tend to use native EF-M lenses as I find them to be smaller and match well with the compact body.
BTW, I like the 3 Canon versions of the EF-RF mount adapter.
OP speed1268 New Member • Posts: 18
Hi, I was actually meaning IQ and focusing type things with the distance between the sensor and the lens.
As I said: no problems -- regarding AF performance and IQ, both of which also depend on the camera body's sensor, AF subsystem, and processor.
I have experienced no AF degradation using Canon EF lenses on my 80D, 5D Mark III and 6D Mark II versus using them with a Canon RF-EF adapter on my R. (A mirrorless body removes an inherent DSLR challenge: AFMA.) IQ, in particular, is always better coming out of the R.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
No difference at all. The IQ is identical to using them on a DSLR with same sensor. So, any EF or EF-S lens on the M6II will have identical IQ to what it would have on the 90D (same sensor). As for AF, I've found that all my EF and EF-S lenses AF better on the M6II than on any DSLR I've used them on.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Hi, Thanks for that, nice to here from someone with lots of cameras!
The more I look into things perhaps staying with a crop sensor is the way to stay!
Either m6ii or new M5ii when available.
Cheers
PhotosByHall Contributing Member • Posts: 600
Cheers
It might be controversial - but I use a speedbooster.
You get the best of both worlds and it lets you carry less lenses.
Use with the M adaptor to get aps-c crop when you need reach - such as getting a 300mm lens to 480mm.
Speedboost when you need wide or more speed. Mount my 17-40mm f4 Canon L and it becomes a 19-45mm lens at f2.8.
(The DOF doesn't change, but the exposure is 1 stop faster).
I use the Viltrox at the minute, which has some poor corner sharpness wide open, but I will buy the metabones once it gets to a decent price 2nd hand.
Reviews and some pixel peeping indicates there is practically no loss of sharpness on the MB speedbooster.
This will give me a small full frame camera with reach from 19mm all the way to 480mm (and I use a TC, so I get to 672mm) with 2 lenses.
I also carry a nifty fifty, which is practically full frame 50mm (56) on the booster, but now lets in f1.4 worth of light.
I find the M system with a Speedbooster gives access to a phenomenal ecosystem of using top grade Canon glass. Once the R system comes down in price as well, there's an upgrade path on to R as well, for the sake of a £50 adapter.
If you want thin and light as well, the Canon M kit lens (18-55) is a good enough boring kit lens and there is a decent 300mm small zoom (but that's not enough for me )
 PhotosByHall's gear list:PhotosByHall's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS M50 Canon EF 50mm F1.8 II Canon EF 17-40mm f/4.0L USM +4 more
grovep Forum Member • Posts: 59
There have been some comments in this forum regarding internal reflections with some of the lower priced adaptors resulting in image issues. So you may wish to research this before buying any specific adaptor. See previous threads below
https://www.dpreview.com/forums/thread/4455311#forum-post-63482499
https://www.dpreview.com/forums/thread/4324738#forum-post-61722909
danblondell
danblondell Forum Member • Posts: 78
A bunch of people have said this already, but I want to highlight the weight and size difference with an adapter. For me it's significant on the M100. It's a tiny camera, so the adapter is a significant portion of its total weight. Maybe less noticeable on an RP or larger M camera, but for me my enthusiasm in using an adapted lens is lower.
In all other respects my cheap $40 adapter has performed as well as a native lens.
 danblondell's gear list:danblondell's gear list
Canon EOS M100 Canon EF-M 22mm f/2 STM Canon EF 50mm F1.8 STM Kamlan 28mm F1.4
CQui
CQui Senior Member • Posts: 1,738
We've heard a lot of bad things about adapters ad failing AF, and I still hear those but it comes from peoples that use cross brand adaptors like EF glass on Sony bodies,
Canon is not stupid, EF and Ef-S lenses work like native lenses on EOS M bodies,
Now we still hear about weight... The adapter is a high precision tube with contacts, the lightest lens there is is still heavier than the adapter, may be not the all plastic 50mm about the same weight and body plus adapter is still lighter than DSLR
The only impact would be that you use lenses designed for bodies with quite larger grip than the EOS M bodies so you need to adapt the way you carry the camera and hold lenses you would not hold on a DSLR
If this is an issue you can get a larger grip,
Claude
 CQui's gear list:CQui's gear list
Canon EF 50mm F1.8 II Canon EF-M 22mm f/2 STM Canon EF-M 18-150mm F3.5-6.3 IS STM Venus Laowa 9mm F2.8 Canon EOS M6 II +6 more
