Capture One 20...supports Prophoto RGB for exports?
chupacabra1 Regular Member • Posts: 286
Hi, I'm just wondering if Capture One 20 decided to drop the Prophoto RGB export option on this version. I was able to export in Prophoto RGB with Capture One 12.
 chupacabra1's gear list:chupacabra1's gear list
Fujifilm X100V Sony a7R IV Zeiss Batis 18mm F2.8 Sony FE 16-35mm F2.8 Sony FE 24mm F1.4 GM
Ysarex
Ysarex Senior Member • Posts: 2,729
Re: Capture One 20...supports Prophoto RGB for exports?
I have the latest version and it exports to ProPhoto RGB.
OP chupacabra1 Regular Member • Posts: 286
Really? I couldn't see it on my version. Did you have to do anything or was part of the option already? Thanks.
Ysarex
Didn't have to do anything. It's always been there.
SatoriGFX Regular Member • Posts: 123
It’s there on my MacBook but it’s called ROMM RGB. Not sure why they don’t have it listed as ProPhoto RGB. But they are the same profile.
 SatoriGFX's gear list:SatoriGFX's gear list
Fujifilm X100S
flyinglentris
flyinglentris Senior Member • Posts: 1,345
Many Colorspace/Color Profiles are part of the Operating System's cadre and may not be specific to C1, but C1 will find them with Show All.
"If you are among those who believe that it has all been done already and nothing new can be achieved, you've murdered your own artistry before ever letting it live. You abort it in its fetal state. There is much that has yet to be spoken in art and composition and it grows with the passage of time. Evolving technologies, world environments and ideologies all drive change in thoughts, passion and expression. There is no way that it can all ever be done already. And therein lies the venue for the creative artist, a venue that is as diverse as the universe is unmapped and unexplored." - Quote from FlyingLentris
flyinglentris in LLOMA
Absolutely. On my MacBook ColorSync shows only ROMM RGB as being installed, not ProPhoto RGB. One could certainly install ProPhoto RGB if they want it to display as such.
Fujifilm X100S
flyinglentris
Consider also that ProPhotoRGB is usually used as a translation go-between because of its large Color Gamut. It would likely rarely, if ever, be used to output for device compatibility or print. So, that being said, why is the OP wanting to use it, to see Colors that are being clipped by the Colorspace Gamut currently in use?
[Edit]  He does refer to his concern with regard to not seeing it for Export.
It’s a good working space so I guess if you are outputting a file to edit in another application that has the same working colour space or a similarly large colour space it may be beneficial. But I wouldn’t choose it for final output.
Fujifilm X100S
