Konica C35 EFP flange distance?????
Started Apr 20, 2020 | Questions
Viernes Regular Member • Posts: 109
I found a crappy Konica C35 EFP in a drawer. The camera is far beyond repair (and is definitely not worth the trouble) but, to my surprise, the lens is in perfect condition.
I've decided to tear it apart and use that lens for a DIY tilt-shift experiment for my m4/3 camera.
If it works out as expected and I like shooting that kind of thing I'll build another one with a better lens.
So, the question is: what's the flange distance of the Konica C35 EFP?
I've been looking all over the web but couldn't find the answer.
Thank you!!!!!!!
Crappy iPhone picture of and old crappy camera
Tom Axford Forum Pro • Posts: 10,067
Re: Konica C35 EFP flange distance?????
If you are pulling the camera to pieces anyway, it should be fairly easy to measure the flange distance yourself.
E Dinkla Senior Member • Posts: 2,613
+1
Measuring from the film plane to the rim that holds the rear element is quite easy. Set the lens to infinity and use a piece of glass or metal on the frame window near center and subtract its thickness of the measurement you get. It's not a flange film distance as there is no "flange" in that sense in a compact 135 camera. Conversion design should allow some tweaking for infinity calibration.
Met vriendelijke groet, Ernst
No photographer's gear list is complete without the printer mentioned !
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
E Dinkla wrote:
+1
+1 again.  There is NO FLANGE. The lens is an integral part of the body, so where the flange ends up is a function of how you slice it....
I suspect it's too short for tilt/shift on MFT, but maybe not?
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
ProfHankD wrote:
E Dinkla wrote:
+1
On MFT it will be hard for tilt/shift I estimate, too short distance from the lens rear to the sensor to suit the MFT register distance of 19.25mm. Probably at most 5mm to fit a shift/tilt mechanism. The lens is sort of a Tessar design, fixed focus, aperture probably primitive as well as it is linked to two ISO settings.  Fixed 1/125 sec shutter time. No real exposure measuring but a low light warning.
http://camera-wiki.org/wiki/Konica_C35_EFP
It seems Andy Warhol was fond of a sister camera model, that usually says enough for me about the technical aspects.
ProfHankD
E Dinkla wrote:
ProfHankD wrote:
E Dinkla wrote:
+1
The camera that really got me started was a Konica C35. Great camera. In fact, I won my first photo contest with a rather cliched shot of a sailboat that I took with my C35....
Unfortunately, mine was stolen decades ago. However, I bought one a couple of years ago thinking that maybe it could be adapted in some way -- hopefully not as challenging a conversion as this . I was actually thinking about using it with a LED array as both a low-res sensor and a projector... I even had an undergraduate senior project team work on doing that, but they ended-up targeting a 6x6cm TLR and didn't get very far with the project....
Yes, I recall that Konica hybrid. Really fine tinkering. More as a challenge than going for a usable solution, like so many DIY projects.
Some years ago I salvaged the lens of a Ricoh FF!, the Color Rikenon 35mm 2.8.   3D printed parts to clamp it with and glued that to a reverse Sony FE adapter.  Today  I measured the distance of the rear element rim to the Sony A7RII body mount flange. Given that the register distance of the Sony is 18mm and that of an MFT body 19.25mm there is about 9mm to get a tilt/shift mechanism in between that also has to include the adapter flange thickness of say 1 to 1.5mm.
Older version of that lens adaption:
https://www.dpreview.com/forums/post/59847761
