Olympus TG-6. Clicks when shaking the camera in any state
Started Apr 16, 2020 | Questions
NikVladi New Member • Posts: 11
Hello everybody!
I bought a new camera and noticed that when I shake the camera, something clicks inside. This is audible without video. This is very audible in the video. There are clicks with the camera turned off as well. Can someone check if there are such clicks when shaking the Olympus TG-6 camera.
https://yadi.sk/i/MjK_cCFT9TLw1w
(unknown member) Contributing Member • Posts: 602
Re: Olympus TG-6. Clicks when shaking the camera in any state
Yea, my TG-6 DEFINITELY does NOT have that clicking sound. I would return this immediately.
__________________________________________________________
“A little bit of this town goes a very long way.” - Hunter S. Thompson http://www.robertbaker.photography
https://www.flickr.com/people/vegasphotog/
geejay101 Regular Member • Posts: 473
NikVladi wrote:
Hello everybody!
It clicks when the lens ring is off. Is your lens ring on and locked?
 geejay101's gear list:geejay101's gear list
Sigma DP1x Panasonic Lumix DMC-GX1 Olympus E-M5 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +4 more
smithaa02 Regular Member • Posts: 252
NikVladi wrote:
Hello everybody!
Contact Olympus if you haven't before.
Note...the TG-6 uses image stabilization.  It is possible what you are hearing is the sensor itself.  On the EM series, when the camera is off you can actually shake them and hear the floating sensor make noises.
Christian305 New Member • Posts: 3
Hi. I tried to shake and there was a clicking sound, but i discovered thet it was due to the button in the front of the camera to extract the ring. If you press a little (just to avoid its moving) that botton and shake your camera, the sound dissapear. Try to do that. If the sound is still evident when you shake your camera, i dont knok the reason.
I posted yesterday about audio quality in video, could you read it? Thanks!
