Finding Polaris?
Started 9 months ago | Questions
landscaper1
landscaper1 Veteran Member • Posts: 4,899
Finding Polaris?
I've owned an iOptron SkyTracker Pro for some time and would like to be able to use it.
When I last made the effort (some time ago) I gave up because I found it all but impossible to locate Polaris through the optical sight in the SkyTracker.  To begin with, because of light and air pollution I rarely can see Polaris even though I know the approximate area in the sky where it's located.
Does anyone have a suggestion on how to get around this obstacle?  Or am I doomed to forego using a tracker anywhere other than exceptionally clear night skies?
Landscaper
"Draw me a picture of an island without any seas;
show me a map of the whole world without boundaries."
 landscaper1's gear list:landscaper1's gear list
Canon EOS 5DS R Canon EOS R Canon EF 50mm F1.8 II Canon Extender EF 1.4x II Samyang 35mm F1.4 +6 more
hha1 Junior Member • Posts: 27
Re: Finding Polaris?
I have the same problem, that I can't see Polaris with the unaided eye from my backyard, and I have the Skytracker with the pole finder scope. First I make sure  my tripod is level. Then I set the Skytracker to approximately the right declination using the declination scale. Then I use a magnetic compass to turn the Skytracker horizontal axis to  approximately N. Polaris is then typically visible  in the 6 degree FOV of the pole finder scope. Center and you are done.  In California the local declination is about 15 degrees, so N is 345 degree magnetic.
hha
myb17 Junior Member • Posts: 26
I use an app
My favorite, on the iphone, is Redshift.
It will follow the sky.
landscaper1
OP landscaper1 Veteran Member • Posts: 4,899
Re: I use an app
And how does that help me to aim the tracker's optical sight?
Landscaper
mermaidkiller Senior Member • Posts: 1,088
Re: I use an app
It is damn simple when you are in the northern hemisphere. Polaris has about magnitude +2, so it is easy to spot, even in well light polluted cities.
It is always above the northern horizon, the further north, the higher, its altitude in degrees equals your latitude.
Ricoh KR-5 ... Pentax ME Super ... Canon T90 ... ... ... 40d ... 7d ... 6d
 mermaidkiller's gear list:mermaidkiller's gear list
Canon G7 X II Sony RX100 VI Canon EOS 6D GoPro Hero7 Black Canon EF 85mm F1.8 USM +5 more
landscaper1
Re: I use an app
Maybe it's damn simple for you, and maybe you assume too much.  I'm 74 and my eyes aren't what they used to be.  Oh, and I'm well acquainted with the constellations and how to locate the approximate area where Polaris is located, but approximate is good enough for a tracker.
Landscaper
swimswithtrout Veteran Member • Posts: 3,774
Re: I use an app
I have to agree with Mermaid killer...
Polaris is mag 2.0. Unless you live in a Bortle 9+ zone, it is easily visible. I had no problem at all in a Bortle 8 zone. In, fact a bit of LP makes it easier to find, compared to the multitude of stars visible at my Bortle 2 dark site.
DLutzer
DLutzer Regular Member • Posts: 261
Re: I use an app
It may help to light acclimate your eyes first. Make sure you are in the dark with no lights or just close at least one eye for 5-10 minutes. This will help you see better. If you need light to see where you are going use red it helps preserve your night vision
once you know the degree Polaris should set up your tripod, ensure that it is level, and point north. Keep in mind it is the tail end of the Little Dipper and Cassiopeia will be on the other side of it. You can also try to use the mid point of Cassiopeia. Should be a straight line from there.
another trick is to use the Big Dipper:
To locate Polaris, all you have to do is to findthe Big Dipper pointer stars Dubhe and Merak. These two stars outline the outer part of the Big Dipper's bowl. Simply draw a line from Merak through Dubhe, and go about five times the Merak/Dubhe distance to Polaris. If you can find the Big Dipper, you can find Polaris.
 DLutzer's gear list:DLutzer's gear list
Sony Alpha NEX-7 Tamron SP AF 90mm F/2.8 Di Macro Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +14 more
Allen Moss Regular Member • Posts: 229
Get to the site before dark.  Get the tracker pointed as best you can to where Polaris should be.  As twilight approaches Polaris will be visible first since it’s very bright.  You should have your best chance for alignment.  Good luck!
 Allen Moss's gear list:Allen Moss's gear list
Nikon Z7 Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon 500mm F5.6E PF Nikon Z 24-70mm F2.8 Nikon Z 85mm F1.8 +2 more
Here an image, showing the method like DLutzer says.
landscaper1
Thanks, but I've known this since I was a kid.
Landscaper
bmike
bmike Senior Member • Posts: 2,332
How long or wide of a lens are you using?
When I haven't been able to see Polaris with wider lenses I did the following:
1. Level tripod.
2. Adjust declination based on your latitude.
3. Point North with compass (adjust for magnetic declination). My tracker has a declination / compass mount for it.
Then, if using a long lens, or needing really long exposures, once it gets dark sight through the scope... but if you are in heavily light polluted areas a long exposure might just blow out your image.
I'm using a Vixen Polarie - so I also open SkyWalk2, search for Polaris, then put the phone on the back of the mount, and tweak (if needed). Now that I have a polar scope for it I do steps 1-3 and sight through (assuming I can see Polaris...)
You might have to wait until you can travel a bit and get out of the city though, if you are having trouble seeing.
landscaper1
1. Level tripod.
Mike,my problem is with the SkyTracker Pro's own optical (1x) sight.  It has a fairly narrow field of view.
Landscaper
stargazer ch Forum Member • Posts: 60
Following on from bmike‘s suggestions:
  • level the tripod
  • set the angle on your tracker to your geographical latitude.
  • at Night, Point your tracker roughly towards north.
  • while looking through the finder scope, Turn the tracker left/right around the vertical axis until you see a reasonably bright star. Chancen are high this is Polaris.
  • fir fine-tuning, use an app (I use the native app from ioptron) to put Polaris at the right place in the circle you may see in your finder scope.
That‘s at least how I manage to find Polaris with my skytracker.
Lastly - don’t overdo polar alignment if you only want to image at small focal lengths(say <85mm). And as long as exposure time is small (<30 sec) a rough alignment is more than enough to produce good results.
Just my 50c,
Michael.
 stargazer ch's gear list:stargazer ch's gear list
Fujifilm X-T1 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR
landscaper1
Just my 50c,
Michael.
Now that's something I haven't read before.  Interesting, inasmuch as I'm extremely unlikely to be shooting anything longer than 35mm, and then never more than 50mm.
Landscaper
bmike
landscaper1 wrote:
Just my 50c,
Michael.
Polar scope is good for long lenses, less helpful for wide. Certainly you want to get it as good as you can - but with light pollution likely to lead to shorter exposure and a wider lens - just point it properly north, set the declination and take some test shots.
I managed 120s exposure at a dark site only using latitude and compass, and eventually the eye peephole (not a scope) on my tracker to produce this image, which is a mosaic - shot @ 22mm on a crop. I couldn't site Polaris when setting up - daylight + tree - I did eventually use the peephole when it got dark enough - which is about a 1cm diameter hole you sort of one eye sight through on my tracker...
Muti image mosaic - tracked, stacked, stitched
30s exposures @ 85mm on my 6dmk2 - (I would have shot longer but I left the intervalometer at home). Same process for alignment - angle, north, and in this case sighting through the peephole.
stacked exposures
BlackgumNate Contributing Member • Posts: 634
Can you see Polaris then? Assuming you can, point a green laser at it (I have a little clamp that i clip on a tripod leg) and then look for the laser in your polar scope. As soon as you see it in your polarscope it'll stand out from there.
Depending on how far off your alignment is starting out, and brightness or darkness of skies, it can be maddening to find polaris through the scope.
Nate
Bill Ferris
Bill Ferris Veteran Member • Posts: 6,066
If you're able to see the Big Dipper, you can use the front "bowl" stars as pointers to Polaris.
Courtesy: Earth and Sky
If the local night sky is too bright to see the Big Dipper, there are mechanical approaches you can apply to get close.
Polaris is about 0.9 degree from the celestial north pole. You can dial-in the approximate angle of Polaris above your horizon by setting the finder at an angle equal to your local latitude. If you're at 40° N latitude, set the finder's tilt angle to 40°. Set it to 60°, if you're at that northerly latitude.
To finish an approximate alignment, look up the magnetic offset of North on a compass from true North for your location. With this number, you can use a compass as a reference to rotate the finder around your horizon until it's pointing toward magnetic North. Then rotate the finder according to your local magnetic offset for a more accurate alignment.
You should be roughly aligned and, unless you're using very long focal lengths, should be able to make tracking exposures up to some reasonable length of time.
If you need or want a more precise alignment and are unable to see Polaris, Google "declination drift" method of polar alignment. The rough alignment I've described is a good start to that process.
Bill Ferris Photography
Flagstaff, AZ
http://www.billferris.photoshelter.com
 Bill Ferris's gear list:Bill Ferris's gear list
Nikon D610 Fujifilm X-T20 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tamron SP 24-70mm F2.8 Di VC USD +3 more
nick lamendola Regular Member • Posts: 261
Can you see Polaris by the naked eye, but are having a problem finding it it the polar scope?
This has happens to me occasionally, especially if I'm at a different location than I normally use or if I'm at a darker site where there are more star visible than I'm used to.  When this happens I remove the tracker from the tripod and hold the tracker in my hands and use finder scope like a telescope and scan around the sky to find Polaris that way first. This lets me get an idea of how bright Polaris will be in the finder scope and what it looks like, and makes it easier to find Polaris after I put the tracker back on the tripod.  It works for me anyway.
Good luck,
Nick
If the OP can't even see Polaris, than this won't make any difference, because all of the stars are the same brightness as Polaris or fainter, which would equate to a Bortle 11 zone
