Looking for a cheap wide angle for my D600
24thWanderer
24thWanderer Regular Member • Posts: 208
Hey there. Much like the title suggests, I am seeking a cheap (~$300 USD or less) wide angle for my recently acquired D600. When I say wide, I mean like ~18mm but I don't have a preference here; the widest lens I own is my 50mm 1.8 lol. So it can be more narrow. ~24 is probably enough for my purposes. I have wide angle lens on my M43 kit, but I'd like to be able to use the stronger sensor and higher resolution to practice landscapes. Greatly prefer the lens be fitted for the FX circle. Open to manual focus only lenses also given the intended use of the lens. There's so many lenses out there, and I am not sure where to begin. Thanks for any insight you might have!
 24thWanderer's gear list:24thWanderer's gear list
Panasonic G85 Canon EOS RP Canon EF 17-40mm f/4.0L USM Olympus 12-40mm F2.8 Pro Tamron SP 45mm F1.8 Di VC USD +2 more
Nikon D600
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 15,752
Re: Looking for a cheap wide angle for my D600
https://www.adorama.com/l/Used/Photography/Lenses/Nikon~SLR-Lenses?sf=Price&sel=Fixed-Focal-Length_24mm_28mm%7cCondition_E-plus_E_E-hyphen_V_G
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +2 more
Chuck Yadmark
Chuck Yadmark Veteran Member • Posts: 4,573
Nikon 18-35mm 3.5-4.5 AFD is okay for the price.  can find for under 300.
Ann Arbor, MI USA
www.sportsshooter.com/cyadmark
 Chuck Yadmark's gear list:Chuck Yadmark's gear list
Nikon D4 Nikon Df Nikon D4S Nikon D750 Nikkor AF-S 300mm f/4E PF ED VR +19 more
Timotis77
Timotis77 Regular Member • Posts: 382
For under $300 US i think you'd find a used 18-35mm G for this....
way better than the D and a brilliant lens for the price....
 Timotis77's gear list:Timotis77's gear list
Pentax 645Z Pentax K-S1 Tokina AT-X Pro 100mm f/2.8 Macro Tamron SP AF 180mm F/3.5 Di LD (IF) Macro Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +11 more
Geoliebert Regular Member • Posts: 120
I bought a Nikon 24f2.8 AF-D for about $120. Many are for sale, ususally a bit more than that but if you're not in a hurry you can get a good deal on one. Great lens,
pforsell
pforsell Veteran Member • Posts: 3,673
I suggest you take a good look on the wide zoom of the "original" trinity, the AF 20-35 f/2.8. The other members were AF 35-70 f/2.8 and AF 80-200 f/2.8.
It is a constant f/2.8 zoom when wide apertures are needed and pretty sharp when stopped down a bit. It has a solid full metal construction.
The weak part is the mechanical AF/MF switch collar. It may get stiff if gunk gets under it and applying too much force when turning the ring will break it. Make sure the ring moves smoothly without too much resistance, and you're golden.
There seems to be a few in ebay priced in the 200-300 range.
Peter
 pforsell's gear list:pforsell's gear list
Nikon D1X Nikon D2X Nikon D3X Nikon D3S Nikon D4S +25 more
Chuck Yadmark
better, most certainly, under 300, most certainly not or I'd have one myself
I did however forget about the 20-35 2.8 AFD which I had 15 years ago and I think I'd still have had I peered into the future and foreseen how much my 17-35 would cost me over the years (600 in repairs and counting)
Ann Arbor, MI USA
Timotis77
I got mine last year for $350 AU - thats about 250 US - they always come up on ebay here in Australia for well under $400 AU - G version..... D are more line 200-300 AU
