Olympus EM5 freezing with 20mm 1.7 II
Started Apr 13, 2020 | Questions
Wrengale New Member • Posts: 6
I've had a problem recently with my Em5 mark I freezing completely when using my Panny 20mm 1.7 mark II. Every time I brush against the shutter, even half press, it takes a shot and then the camera just locks up, no buttons responding at all. Starts working again when turning the camera off and on, but then as soon as I touch the shutter, same problem. I've noticed the aperture on the lens stays locked open when this happens too, so I think it's a miscommunication between body and lens. I've cleaned all the contacts, updated all the firmware, even done a full reset, no joy.
This body+lens combo is my go to for discreet street shooting, so this is annoying to say the least. Wondering whether to sell on the lens and switch to the Oly 17mm if this keeps up (better AF but I would really miss the size and IQ of the Panny...)
Anyone else had this issue?
 Wrengale's gear list:Wrengale's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro +2 more
bluevellet Veteran Member • Posts: 4,172
What about the firmware?
Both lens and body?
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
James Stirling
James Stirling Veteran Member • Posts: 9,282
Re: Olympus EM5 freezing with 20mm 1.7 II
Don't switch the lens switch the camera Joking aside { sorry!} have you tried other lenses  , changed anything recently , new sd card etc
Jim Stirling:
It is not reason which is the guide of life, but custom. David Hume
 James Stirling's gear list:James Stirling's gear list
Sony RX100 IV Panasonic Lumix DMC-GX8 Nikon Z7 Olympus E-M5 III Nikon Z7 II +10 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
definitely not normal with this combo
The 20mm f/1.7 was my favorite lens on the E-M5 (from 2012) until the 12-40 came out. So I used it a lot and never had such a lockup problem. Maybe cleaning contacts may help?
Getting to know the Olympus OM-D E-M5 II.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
OP Wrengale New Member • Posts: 6
Re: What about the firmware?
bluevellet wrote:
Both lens and body?
Yes, sadly both
Re: definitely not normal with this combo
One of the first things I tried, no luck!
Have tried other lenses, this is the only one that does this.
No new SD or anything. The camera just started playing up about two months back and this has been happening on and off since (again, only with this lens, no others)
Skeeterbytes Forum Pro • Posts: 23,186
Problem seems to rest with the lens itself. Unless you can test on another body you can probably assume it's in need of repair.
Good luck!
Rick
Paul De Bra
Agree. Must be a lens defect.
Maybe some internal contact or cable is loose. The 20mm isn't known for that but many other lenses are. Something inside that moves while focusing may cause some electrical connection to fail, and that might cause the camera to freeze due to lost communication.
That's the really weird bit: lens works fine on my EM-1!
Okay, even weirder.
My sole incompatibility experience was the four-thirds EC20 teleconverter. It would communicate with every lens except the 150/2.0. The camera didn't matter, the lens attached did not matter, just the one combo. Firmware was up to date.
Olympus exchanged it and the replacement worked perfectly. My idle speculation is something occurred to your 20/1.7 that prevents it from recognizing the camera. It could be the on-board chip failing.
One other item: make sure the lens lock pin is extending fully when the lens is mounted. 3rd part adapters are infamous for not aligning correctly and preventing a connection.
FWIW the 20 was my first m4/3 prime, bought while I was wait-listed for the EM-5. Knew I'd want lenses faster than the 12-50 kit zoom. The sole issue is the notorious high-ISO banding; it has never failed to work on that or any other body.
Good luck!
Rick
Paul De Bra
Maybe it's something with the mark II then?
I initially missed that you have the mark II of the lens. My combination of the E-M5 with the 20mm f/1.7 (mark I) has never locked up. The mark II may have slightly different firmware than the mark I.
Olympus EM5 freezing - not 20mm 1.7 II
Update: no longer just this lens. Froze up with my Oly 25mm too, must have just been chance that it had only happened with the 20mm previously.
Thanks to everyone that's responded
Leen51 New Member • Posts: 5
Re: Olympus EM5 freezing - not 20mm 1.7 II
A few years ago my PL 25mm f1.4 strangely rattled on the E-M5. Then I found this somewhere on the internet:
"The PL 25 is a wonderful lens and well-balanced on my E-M5ii, but its rattle snaking was both annoying and embarrassing until someone showed me how to eliminate it on Olympus bodies.
Under the gear menu D, Disp/Sound/PC, select flicker reduction and turn it to 'off.' Problem solved!"
OK, I admit yours is an entirely different problem, but it's always worth a try.
Leen.
 Leen51's gear list:Leen51's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus 12-40mm F2.8 Pro Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus 14-150 F4-5.6 II
