Disassembly – Fujinon XF 60mm F2.4 Macro (part II)
Started Apr 12, 2020 | User reviews
yukosteel
yukosteel Regular Member • Posts: 362
7
One of my reader contacted recently asking for help with Fujinon XF 60mm F2.4 fallen down and not focusing anymore. Initial disassembly article of XF 60mm didn't have details on focusing mechanics, so today I decided to give it a try.
This time I found way to get into front lens area and it opened path to completely disassembly of XF 60mm.I was able to additionally clean out few large dust (or factory glue) particles from aperture chamber.
Unfortunately, after assembly I've got camera error "Turn camera off and on" : ((( Typically it means problems with lens electronics and I was thinking that accidentally damaged one of ribbon cable connector (hate touching electronics because of that). A bit depressed I anyway posted article with Fujinon XF 60mm F2.4 lens complete disassembly steps.
Half day later I decided to disassemble lens again and scan every cable with circuit tester. It didn't show any cut line. Though during assembly process I noticed that lens core position sensor can be misaligned, which actually happened during previous assembly. Putting sensor in correct position helped - lens works like it should again, and now it's completely clean from any dust.
Fuji XF 60mm F2.4 - removing focusing ring.
Fujinon XF 60mm F2.4 - opening aperture chamber.
 yukosteel's gear list:yukosteel's gear list
Fujifilm X70 Fujifilm X100V Fujifilm X-E2S Leica M10-P Fujifilm X-Pro3 +18 more
Fujifilm XF 60mm F2.4 R Macro
Telephoto macro prime lens • Fujifilm X • 16240767
Announced: Jan 9, 2012
yukosteel's score
5.0
Average community score
4.4
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Re: Disassembly – Fujinon XF 60mm F2.4 Macro (part II)
Thanks for sharing this!
Only few people on this planet would dare to go that far.
Happy Easter!
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
yukosteel
OP yukosteel Regular Member • Posts: 362
Happy Easter! : )
Yes it may look so, however if you check number of articles on iFixit where people successfully repair things and post guides - that number would turn to thousands or more : )
RobertMachin Contributing Member • Posts: 531
Many thanks for sharing this and your work in general.  THIS is the useful internet.
 RobertMachin's gear list:RobertMachin's gear list
Sony RX100 III Canon EOS RP Fujifilm X-H2S Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +17 more
