K1ii contrast detection AF question
Started Apr 11, 2020 | Questions
Phil_Rose
Phil_Rose Senior Member • Posts: 1,044
Hi all, is there really no quick way to change the contrast detection AF? I mean to change the mode from center to Select and so on. Do I have to go into the menus? The wee button above the four way doesn't seem to do anything when in live View.
Thanks,
Phil
I like turtles.
www.philrosephoto.com
miles green
miles green Veteran Member • Posts: 7,827
Re: K1ii contrast detection AF question
You can press the AF mode button on the side of the camera with your left thumb, and then change the mode with the right hand index and thumb dials.
If you encounter a certain situation often, you can save a user mode where you can also taylor other things to your liking.
I hope that's what you were asking..
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
Phil_Rose
OP Phil_Rose Senior Member • Posts: 1,044
Oh, f course. My brain doesn't work sometimes! Thanks.
I like turtles.
