Switch from X-E3 to X-Pro2 just for EVF (MF)
Started Apr 11, 2020 | Questions
Caleido Forum Member • Posts: 96
I'm currently contemplating selling my X-E3 - which is nice & compact and does about 90% as the X-Pro does. But currently I'm heading into 100% manual lenses, with no communication & AF. Possibly M39 lenses... Currently a 35 F1.2 third party old style lens.
So I'm wondering if somebody has both bodies or did the same switch and could point out whether the EVF is really better in the X-Pro2 - especially for manual focus.
The OVF is no priority for me. But, I have not used it yet, so I'm open for it.
Most internal MF aids are the same (except for yellow peaking, I believe) with both cameras, so it would be more about size, resolution and refreshrate of the EVF.
I realize that the SLR type Fuji's have bigger EVF's, but because my pro system is SLR type, I would prefer to have another form factor for my "fun" kit. In this case: "range finder-esk"
Any thoughts?
Fujifilm X-E3 Fujifilm X-Pro2
Aoi Usagi Veteran Member • Posts: 3,222
Re: Switch from X-E3 to X-Pro2 just for EVF (MF)
8
The Hybrid viewfinder is useless for manual focus lenses and only becomes a burden because the viewfinder curtain opens and closes (it gets annoying), and the ERF is very difficult to focus with. The X-Pro2 EVF's main advantage seems to be the refresh rate. The slightly larger display panel is neglectable since the X-E3's magnification is higher. So if you plan to shoot fast moving subjects, than the faster refresh rate might be important. Overwise, I think its a waste of money to buy a X-Pro2 when the X-E3 is fully capable of using manual focus lenses without the OVF fuss.
a_c_skinner Forum Pro • Posts: 13,047
5
Despite tempting pricing lately I'm not an X-Pro user but I really, really cannot see this being a worthwhile switch.  MF works well with the X-E3.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Threaded Veteran Member • Posts: 4,180
Erm, don’t agree with this at all.  The curtain is only a “burden” if you’re hypersensitive to it as you seem to be, I doubt most people give it a second thought, I certainly haven’t in four years of using x-pros.
Purely as an EVF I don’t think the X-pro2 has any great advantage, but the ERF option actually works well and allows you to manually focus lenses in an optical view very well.  You can also go to fully optical and just zone focus of course.
Aside from that the XP2 has a lot of finer points - weather sealing, dual card slots, faster shutter, more function buttons etc.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
DarnGoodPhotos Forum Pro • Posts: 11,881
I have both cameras but wouldn't say that the X-Pro2's EVF is noticeably better.
That being said, I still prefer my X-Pro2.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
OP Caleido Forum Member • Posts: 96
How useful is the small LCD that pops up in the OVF to check focus?
Also, I was surprised how small the actual image frame is in the OVF. I thought a 20-35 ish lens would cover the whole view of the OVF, but it's really a tiny box in the middle.
It looks like I'll be sticking with my X-E3, based on the replies. Just a shame the EVF is not a tiny bit bigger or smoother. Or offers more finetuning in the peaking options - I've read that the color yellow is the best option though only available on the X-Pro2.
I don't use MF lenses and I rarely use the EVF patch to check focus because I have no reason to believe my X-Pro2 won't auto-focus correctly. When I do use it, I find it useful for telling me where the focus will be instead of estimating between the two boxes (which I know how to do).
The 23 does cover most of the OVF view, maybe you are on the wide magnification level. The X-Pro1 and X-Pro2 have two magnification levels int he OVF, you hold the lever in the opposite direction of toggling the EVF patch.
The X-Pro2's EVF is smoother and a bit better; I just don't jump between he two cameras frequently enough to really notice the difference. I personally use white heavy for focus peaking, but if you shoot Raw you can use red peaking with a B&W sim.
"The (X-Pro2) EVF is a 0.48-inch TFT panel with 2.36 million dots, a 16mm eyepoint, a refresh rate of max. 85fps and a magnification of 0.59x.
On the X-E3, you only get an electronic viewfinder with slightly better magnification (0.62x) and an eye point of 17.5mm but it is smaller (0.39-inch) and the refresh rate is around 54fps."
https://mirrorlesscomparison.com/preview/fuji-xe3-and-xpro2/
deednets Forum Pro • Posts: 13,887
Any thoughts?
An X-T1 or T2 might fit the bill for you then as the EVFs are substantially larger than the E3's.
Different form factor though but as a tool? 🙄
Deed
 deednets's gear list:deednets's gear list
Leica Q2 Fujifilm X-Pro3 Sony a7 IV Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
I guess its personal preference.  I have been using the X-Pro with manual focus lenses for few years now and I don't understand why the curtain needs to open every time you take your eye off the viewfinder.   For quick snaps, pressing the shutter while the curtain is moving disables the half press to focus.  Its a rare occurrence, but it happens. And it probably uses a small amount of battery power every time it opens and closes which can possibly add up over time.
Also the ERF isn't exactly accurate regarding focus point and the magnified view in the ERF on close up shots.  And as for non-native lenses, you need to input the lens focal length into the menu or the frame lines wont line up (in OVF/ERF mode).  That's why I said its a burden and the EVF-only X-E3 is probably a better choice.
Inukim Regular Member • Posts: 328
Zone focusing it going to be difficult with a 35mm f/1.2 @f/1.2, like the OP wants.
It is a very nice camera that I actually like more than the XP3.
