nnowak
Re: M6ii power through USB
Hoka Hey wrote:
JRET wrote:
Joe,
Assuming that you need uninterrupted power longer than the battery provides it is possible to use a power adapter kit. I believe the M6ii battery is LP-E17 and that the camera has a trap door on the battery compartment door. If that is correct check this LINK . Using the power adapter opens up all kinds of possibilities for extended shooting but does require 110v. If the shooting location is not convenient to 110v the solution is to use an INVERTER .
Using a Canon M2 on a tripod I used this setup with each of these components plus a 12v lawn tractor battery to shoot the solar eclipse a couple years ago. My goal was to shoot a 6 hour time lapse and, even with the smaller lawn tractor battery, I estimated that I had at least 24 hours battery capacity. This setup worked flawlessly.
There are other adapters and inverters available but the two units listed above worked quite well for me. This might work for your needs or at least point to a suitable solution for your needs.
Thanks JRET. Very helpful!
I have the power adapter for the LP-E6 battery and used it last night with my 5D4 on the back deck plugged into power.
However, I want to be able to carry a battery with me to remote sites when things go back to "normal". So, weight is a big factor. I'm OK with a camera pack and R + lens + LP-E6N batteries for Milky Way and M6ii + lens for star trails and tripods, but not much more.
Do you think that I could use thisadapter and the batterymentioned in the original post? Is there a simple way to calculate how much battery I need to last 8 hours? It's been 45 years since I had calculus and basic physics. So, please go easy on me here.
For what it's worth, last night, the LP-E17 lasted about 4.5 hours shooting 30 sec exposures with a second or two between each exposure.
Good news/bad news. The LP-E17 battery has a capacity of 7.5 watt hours. The battery bank you linked has a 100 watt hour capacity. If the LP-E17 last 4.5 hours, the bank would last 60 hours
Here is the problem... the M6 II is expecting 7.2 volts in the battery compartment. 7.4 or 7.6 are fine too. This is the voltage you get with 2 lithium cells wired in series.
The bank you linked can not output 7.2V as that is not a standard PD voltage. The USB port on the M6 II communicates with the bank to request a suitable PD voltage (probably 9V). The battery compartment lacks this communication ability.
How are your soldering skills? You will need a LP-E17 dummy battery and mating cable. Find, or build, a high capacity 7.2/7.4V battery bank. Some examples would be "2S" RC vehicle batteries or a bank made of 18650 cells. Cut apart the Canon cable and solder on a mating connector for your battery bank. Whatever you use, make sure it has a protection circuit. Over charging and over discharging lithium batteries is dangerous.
If this all sounds overwhelming, the other option is to switch to almost any other camera brand for this use case. Almost all other brands support powering the camera over USB and would easily work with the bank you linked and a standard USB cable.
