GRIII: Turn off exposure adjustments in live view?
Started Apr 3, 2020 | Discussions
jjcha Regular Member • Posts: 216
Apologies, but I couldn't find it in the manual.
I often shoot with flash at night, with the lens stopped down to F8 or F11, the shutter speed at 1/125th or faster, with ISO locked at 1600.
So the LCD is basically black since the camera thinks I'm insane and it's not adjusting for the fact I have a fully manual flash ready to go.
Is there some way to have the screen show the scene without the adjustments for the shutter speed, aperture, ISO?  I.e., like as if I had the camera wide open at F2.8 for example?
Thank you.
-Jason
Ricoh GR III
maltmoose Senior Member • Posts: 2,761
Re: GRIII: Turn off exposure adjustments in live view?
Thank you.
-Jason
There is a work around which i think should work but i dont have a flash for my GRIII to test.
go into manual mode which i presume you are already in.
Turn off auto EV compensation in the menu.
I know you want fixed 1600 iso but you should set it to auto iso.
Then go into the auto iso settings and change it to say 1250 min iso to 1600 max iso or whatever works for you. (it wiill always choose the highest due to the settings you choose)
You can even set minimum 1/125 shutter if you need.
You will then be able to see the LCD but with the iso warning as it cant obtain proper exposure, but when you use flash you should get the desired exposure.
Please report back and let me know if this works.
OP jjcha Regular Member • Posts: 216
Awesome, this appears to have done the trick perfectly.  Thank you so much!
iseeu Contributing Member • Posts: 919
Thank you.
-Jason
Sorry for reply on the old thread, I just got the GRIII 2 weeks ago, today I try to use an external flash but with all manual settings the screen come out so dark and I found this thread, I tried to turn off the auto EV compensation in the menu but the screen still looks dark. I still don't understand what this features for. Kindly someone who has experience help me here. Thank you.
 iseeu's gear list:iseeu's gear list
Sony a7 IV Sony FE 24mm F1.4 GM Tamron 28-200mm F2.8-5.6 Sigma 85mm F1.4 DG GN Sony FE 28-60mm F4-5.6 +3 more
Hi, I no longer have my GRIII but the technique described here worked perfectly for me.
I think setting the Auto-ISO, but forcing it to manually always "auto" to 1600 was pretty key.
What settings are you exactly trying to use?
I am usin all manual, aperture f2.8, shutter speed 1/125, ISO 400, the screen still look dark. I am wondering what is the mistake. Thanks for your info.
If you have a dark screen with those settings then you are in a dark environment so you dont have enough light.
You will need to be in auto iso to see the screen if you dont have enough light when in manual mode. Use the settings i posted above but instead of iso auto upper limit 1600 use 400. You will then see the screen.
You are correct, after I changed to auto ISO limit to 400 and I can see the screen now. I really appreciate your input so helpful to shoot with flash.
Sjak
Sjak Veteran Member • Posts: 6,923
Bumping this again.... today on a shoot I ran into OP's issue (had the GR3x with me for trying out in studio-environment)
This thread came up on top in google-results, and the solution works. Thanks!
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
