Gvie up on SD1? Pentax K-1/ar7ii? Need advice.
Started Mar 30, 2020 | Discussions
PTemple Junior Member • Posts: 31
Hey guys...
After 3 weeks of back and forth with Sigma, they can't resolve the color problems that the cam is having with wide angle lenses--even their own wide angles. They're offering me a refund and I'm considering it.
I love the Foveon concept, but is there a, iso 100 IQ advantage for Foveon versus say a Pentax K-1? I can get a refurb k-1 for 1200. What in your mind are some things the SD1 does better?
I've been looking at the test images on imageresource.com and comparing zoo tigers on Flickr from the Sigma and the Pentax..... zoo tigers and the sonoran desert because I grew up there. The sigma pics indeed look different and somewhat filmic, but it's hard to argue with nearly double the dynamic range on the K-1 (7 vs 14). Detail looks comparable to my eye, more detail on the Pentax, arguably more color info on the sigma....then again if 1/4 of the image has gone to black or white because of DR then there goes that advantage.
Bottom line: I miss MF film. No cartoony flat digital greens, no problems with flesh tones/reds, no problems with highlights provided you're careful. And very little editing.
FF Foveon may never happen or may be beyond my budget for the next 3-4 years. I have a wonderful old EF 100-400 4.5-5.6 L Canon lens with no current use as a sold my 7d for the Sigma... Would sell the lens to get money for better sigma lens, but not confident in the system given the issues I'm having. Film gear I can't afford to use.
I need something for the next couple years that won't be a total money pit while i wait for FF foveon to maybe pan out.
Sigma SD1
SigmaChrome Forum Pro • Posts: 15,728
Re: Gvie up on SD1? Pentax K-1/ar7ii? Need advice.
PTemple wrote:
Hey guys...
Sounds like your particular unit may be the problem. They are plenty of users here who don't have colour issues with WA lenses.
What model camera are you referring to? I'm guessing an sdQ(H)?
You simply have to work differently with Sigma cameras. You have to slow down and meter carefully - learn how to get the most out of your gear and post processing. The results are can be very rewarding.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
PTemple wrote:
Hey guys...
I love the Foveon concept, but is there a [100 ISO] IQ advantage for Foveon versus say a Pentax K-1? I can get a refurbished K-1 for 1200 [USD?]. What in your mind are some things the SD1 does better? <snip>
1) NO color aliasing:
http://kronometric.org/phot/sensor/fov/Color_Alias_White_Paper_FinalHiRes.pdf
2) The SD1 Merrill correctly processed in SPP is well-endowed with acutance, some say too much.
3) Just pop out the dust-cover, slap an IR filter on the lens - and IR photography is ready and waiting.
In your shoes, I would take the refund and get a K-1 ... or grab an SD15 - they're not noted for the kind of problems you've been describing.
"History continues to be made" Richard F Lyon 2006
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
xpatUSA
Re: Give up on SD1? Pentax K-1/ar7ii? Need advice.
SigmaChrome wrote:
PTemple wrote:
Hey guys...
What model camera are you referring to? I'm guessing an sd Quattro H? <>
Going by the thread title, I'm guessing an SD1?
Ted
mike earussi Veteran Member • Posts: 9,440
Points to consider:
I considered the K1 when it first came out as my second camera but the lack of high quality fixed lenses put me off. I do pano stitching and near perfect lenses are a requirement for high quality pano stitches. But they have recently announced a 85 f1.4 which hopefully is the start of a high quality lens series.
I've seen direct comparisons of the K1 to the SD1M and even though the K1 resolution is higher in pixel shift mode it still has the same Bayer difficulty of picking up subtle color and tonal variations that the SD1M can see and Bayer can't, and using the SD1M with pano stitching I can have both.
DR is something the K1 is much better with than any Foveon chip. Every camera system has its trade offs, ultimately you have to decide which features are the most important to you.
As for your wide angle lens problems, I've never had any using Sigma's 10-20 f3.5 and the 8-16.
 mike earussi's gear list:mike earussi's gear list
Sigma SD1 Merrill Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 DG HSM | A Sigma 24-35mm F2 DG HSM Art +2 more
xpatUSA wrote:
SigmaChrome wrote:
PTemple wrote:
Hey guys...
Yeah. Some days you look and don't see.
Vitée
jande9
jande9 Senior Member • Posts: 1,707
You could get the Sony with the Sigma adapter to use your Canon lens, and get a DP0 to scratch your Foveon itch.  I've never used a DP0 but it has an excellent reputation.
Jan
 jande9's gear list:jande9's gear list
Canon PowerShot A650 IS Sigma DP1s Sigma DP2 Merrill Panasonic FZ1000 Sony Alpha NEX-7 +4 more
D Cox Forum Pro • Posts: 32,979
Shots from the Pentax cameras that I have seen posted have had very nice colours, but of course look different from Foveon photos. Pentax make excellent lenses.
The great strength of the Sony A7rii is that it can be used with a very wide variety of adapted lenses. The more recent Sony models have very advanced (and complicated) focussing, so are ideal for wildlife photography.
Sigma fp
mike earussi wrote:
Points to consider:
It is the subtle hue variations that Bayer cameras don't record well. You can see an area of grass or a bush in a Bayer image which is the same hue of green all over.
Sigma fp
DMillier Forum Pro • Posts: 23,871
I can understand in principle why this may be the case for Bayer sensors. But in pixel shift mode? What could be the explanation in pixel shift mode - this effectively bypasses the Bayer pattern...
I'm on a bit of a journey at the moment - audio hifi. I'm doing an electronics course with the aim of learning how to design and build stereo amplifiers and I'm learning about loudspeaker design. I'm also learning about DSP and measurement techniques.
As part of this journey I'm doing a certain amount of experimentation and online research.  it is very evident (within minutes, really) that the hifi world is bereft of scepticism and full of lots of very passionate, sincere people just making sh*t up. it is extremely difficult to cut through the huge amount of made up beliefs to find out what is real.
This seems to be a common problem, especially amongst men (for some reason) in many technical fields that lend themselves to amateur hobbyist dabbling.  I put photography in that set.  i don't doubt the passion or the sincerity but filtering truth out of the noise is a struggle. Human beings  (no matter how well educated) seem to gravitate much more easily to rumour, religion and fantasy than fact, and science.  There is an almost total lackl of appreciation for the impact of bias and a lack of scepticism.  We are much more "believing engines", than engineers. I'm rapidly gaining an appreciation of Ted's "pedantry" - he has standards...
Pixel shift enables each pixel to be unique, but the Bayer color is also limited by the fixed color filters on the chip. Foveon doesn't have this limitation.
The Foveon colour filters (layers of silicon) are fixed too, but their more gentle slopes allow finer discrimination of hues than the narrow-band filters used in Bayer sensors.
Some say that the Foveon filters lead to increased noise.
Sigma fp
Do we have  sources for this?
xpatUSA
Here's one from a paper by AVC/Foveon:
"3.3 Color matrix effects
The overlap in the spectral response of the three channels, while providing robust information on the wavelength of narrow-band sources, leads to relatively large off-diagonal terms in the color transformation matrix needed to produce tristimulus values. As an example, it can be easily seen that the blue channel in the tristimulus function is much narrower than the blue photo-diode response. To narrow this channel, a large component of the green must be subtracted. The green is reduced by the blue and the red to narrow the peak and the red channel is augmented with the green to shift the peak to a slightly lower wavelength. Figure 7 shows a typical matrix10 that incorporates those features.
While large off-diagonal terms have a negative effect on signal-to-noise ratio, this is generally not more significant than the effect of the absorption losses in color filter arrays. For color filter arrays using yellow-magenta-cyan or other overlapping bands to increase light throughput, large off-diagonal color matrix terms are also needed, negating some of the sensitivity improvement. Those arrangements still absorb at least one-third of the light."
http://kronometric.org/phot/sensor/fov/SD9%20sensor%20in%20depth.pdf
While not exactly false, the last paragraph seems to be a bit like marketing-speak.
In that same paper, they claim an SNR of 61dB for the green layer, which is just over 10 EV, FWTW ...
Ted
...and the impact of all this on pixel shifted Bayer composite shots alleged failure to detect subtle hue changes?
xpatUSA
Zero. I was responding to "Some say that the Foveon filters lead to increased noise".
Pardon me for posting something longer than a line or two ...
Pardon any correct nomenclature or credible references in this post ...
Ted
danski0224 Senior Member • Posts: 1,465
There's these things mentioned by Ted:
xxxxxxxx end of "quote" xxxxxxxxx
I'll add that the Merrill sensor does monochrome very well (full spectrum or color > B&W).
If you are going to experiment with actual IR photography, the Merrill sensor will be better than a Quattro sensor. But, still not the same a IR with a Bayer camera.
To add to (3) above, it is possible to do full spectrum photography when the dust protector is removed, but no IR filter is on the lens. These images will be red, but Sigma Photo Pro takes care of that.
I have found camera metering to be spotty in full spectrum or IR mode unless the viewfinder is covered. Maybe it's just me or my camera.
The dust protector is still available new from Sigma.
The SD1/M can use most of, if not all of, Sigma lenses without issue.
The not so good?
No live view.
Limited number of AF points.
Besides the limited number of AF points, the AF capabilities of this camera do not match a Rebel Canon from the same era.
Focusing using the viewfinder? Good luck. Unless you have really excellent vision or are doing macro stuff on a tripod (besides the difficulty of manually focusing most lenses designed for auto focus with their limited focus throw).
If you happen to like full spectrum/IR and want to "go back" to color, nothing works as well as the OEM Sigma dust protector, making lens hot mirrors not a good choice.
I don't know anything about Pentax cameras, and only a little more about Sony.
There are a number of Quattro haters on this forum...
With the exception of a limited number of specific uses where a case can be made for a Merril or earlier Foveon sensor (mainly IR), the Quattro sensor, in my opinion, still delivers something that takes a 50mp+ Bayer based camera to equal. Foveon/Quattro can be enlarged more than Bayer because of Bayer edge detail losses- at least when comparing to Bayer sensor cameras at 50mp or lower.
I prefer the colors out of the box from a Quattro over Merrill.
Apparently, a Quattro camera can be set in low res mode to mimic a SD14/15 1:1:1 image.
The Quattro cameras have live view, with magnification for manual focusing. Custom white balance, monochrome viewfinder and more.
Many, many more autofocus points than any other Sigma camera with interchangeable lenses.
Super Fine Detail mode (as useful as Pixel Shift on a windy day).
The bad?
Poor to no autofocus outside of the Global Vision lens family. While autofocus accuracy is much better than the SD1/M, it still is not fast in acquiring lock and then attaining focus compared to many other cameras.
Battery life- a penalty of live view and tiny batteries.
If you do not want to exchange your SD1/M for another one, I'd suggest looking at the replacement model if you want to stay with Sigma cameras, a sdQ or sdH model.
Otherwise, many more lenses can be adapted to Sony.
Moments in Time, a work in progress.... https://www.flickr.com/gp/142423236@N08/965cs3
LasseS
LasseS Contributing Member • Posts: 778
This is very interesting. There are things that can't be measured or scientifically proved when passion and emotion come into the picture. I use a lot of "junk" that I love and wouldn't change for newer, more expensive and "better produkts".
 LasseS's gear list:LasseS's gear list
Sigma DP1 Sigma DP3 Merrill Canon EOS-1Ds Mark III Sigma SD14 Sigma SD15 +2 more
Fotoni Senior Member • Posts: 1,091
Foveon alternatives
Foveon is unique design, others just rely on traditional Bayer color filter and few offer monochrome without the filter, but from some reason no filter is more expensive.
K-1 is the cheapest one with pixel shift which can come closer to Foveon, but only works for subjects which remain static until four photos have been shot. More expensive choice would be higher megapixel number which is then downsampled to have more color resolution for smaller image. Basically you need quite a big difference to have obvious differences. I'm afraid you would have to get something like Fuji GFX 100 to have pixel shift look with non-static subjects when downsized to more typical resolutions like 8K.
 Fotoni's gear list:Fotoni's gear list
Pentax K-1 Pentax FA* 50mm F1.4 SDM AW Canon PowerShot SD4000 IS
paulawd Regular Member • Posts: 406
The capacity to see minor difference in hue is due to the nature of the filters.  Pixel shifting will not alter the filter characteristics.
Assume the RGB filters to be bandpass with very abrupt cutoffs, no overlap in response by the R, G or B filter. Assume two monochromatic lights of different frequency but both falling within the G band. There will be no response from the R or B sites. There will be no way to tell the lights apart.
With the filter characteristics of the Foveon sensor there would be a response in all layers. The response from the two lights will be different. In theory one would be able to notice the difference.
In practice, in my 19 years of digital photography, with a Nikon coolpix990, Canon DSLRs and Panasonic m43s and all of the Sigma camera's, sd14 and later, I have had more problems getting the colours right (pleasing) from the Sigma's than from any of the others. But that may be due to my eyesight, monitor or printer...
Paula
 paulawd's gear list:paulawd's gear list
Sigma DP2 Merrill Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7
