prolonged time lapse summer garden cam
Started Mar 21, 2020 | Discussions
mforrest Junior Member • Posts: 41
greetings and forgive me if this is the wrong forum to ask these questions.
i'm trying to secure a spring/summer/fall time lapse of my garden from an overhead frame of view - a small camera mounted at the peak of my garage under the eaves with a complete view of the garden.  i need a camera that can take single shots continuously day after day.
i have so far been unable to find a camera to do this. accessing the cam everyday to retrieve images is out of the question. however if they could be retrieved weekly it would be doable. i'm trying to locate a small cam that equals gopro image quality and uses electric to usb power (always on) and a large enough storage capacity that i can retrieve the images weekly or monthly. a cam with the ability to  download the images via wifi would be the best of all.
I hope someone can suggest a device that will do this well and is reasonably priced.
thanks for a great forum,
tws
colin pithers
colin pithers Regular Member • Posts: 174
Re: prolonged time lapse summer garden cam
any camera is limited by three things
1,, power
2,, heat generated
3,, storage capacity
as you know power can be by a dc supply and any heat can be dissipated by cooling
storage capacity is the main factor even the biggest card will not do what you require
this link will give you an estimate of the requirments.https://cam-do.com/pages/photography-time-lapse-calculator
hope this helps you out
 colin pithers's gear list:colin pithers's gear list
Fujifilm FinePix S9100
Bernard Delley Senior Member • Posts: 2,041
how many images, tethered or not
1,, power
2,, heat generated
The OP mentioned retrieving data data weekly.
If the interval between shots is not too short the this could be done by many types of cameras. For example a Nikon D7100 can do interval shooting up to  999 shots. Its battery holds up for a week running, especially if AF and other not needed  is turned off. (Tested running for 12 days continuously on a spring outing).  With the 999 shots 5/hour can be done for a week. A 64 GB chip should be enough for that many RAW captures. The chip and battery need to be replaced and interval shooting restarted. Other DSLR may perform similarly. This simple set up may be enough for the purpose.
With tethered camera much more is possible, even without connection to the grid. For example a std DSLR with solar power is used by USGS at a remote location up on Mount St Helens. With a tethered camera on the power grid + internet, images could be pulled off and sent over the net.
 Bernard Delley's gear list:Bernard Delley's gear list
Olympus TG-6 Nikon D7200 Nikon D500 Nikon D850 Nikon Z7 II +17 more
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Lots of DIY options, but the easiest is one of the wildlife cameras, which is already waterproof, designed for unattended use, and many have timelapse settings. Another alternative would be a waterproof wifi network camera with a script running on a PC to timelapse sample.
Personally, if I wanted really high quality, I'd use a waterproof-enclosed, sub-$100, Canon PowerShot, powered by a battery-replacement AC adapter, and running a CHDK script. The 16-20MP stills from these cameras blow away a GoPro. For example, here's one straightforward raw->JPEG from an $80 (new) ELPH 160:
Notice the level of detail is really good, and DR is within a stop or so of what you'd get from one of the older MFT bodies (about 10 stops).
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
elIvarz Regular Member • Posts: 125
Sure, the best option for this is:
Brinno
 elIvarz's gear list:elIvarz's gear list
Pentax K-50 Pentax smc D-FA 100mm F2.8 Macro WR Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax 55-300mm F4.5-6.3 ED PLM WR RE
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,599
Re: how many images, tethered or not
1,, power
2,, heat generated
I'm with Bernard - use the big fella - DLSR - its a great idea and the RAW format gives you max video PP capacity. You can have a macro slide show of what's growing in your garden, or inset macro videos of the individual plant types growing. A cell phone can take beautiful flower images - if you do not have 2 bodies As the honorable gentleman says, due attention to power management and card swaps and there should be no issues. Use a reasonably flat field lens, check the hyper focals and everything will be razor sharp beyond  dhf1 - baddaboombaddabing - cooks all day while the cooks away... or all week. Post the Oscar winner when you do it,.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
