800mm for flowers
Started Mar 18, 2020 | Photos
richj20 Veteran Member • Posts: 8,889
800mm for flowers
5
Butterflies are starting to appear around here in southern California, so I dusted off my wildlife setup which uses a Panasonic 100-400mm, f/4-6.3 (=200-800mm FF effective focal length).
It is a useful lens for flowers that I encounter while out looking for wildlife.
I believe this is a Painted Lady butterfly, Vanessa cardui on a common Lantana, Lantana camara, member of the Verbena family.
Closer in. This is the only time I've been able to photograph a butterfly from the front displaying its proboscis. Usually it is blocked by a leaf or flower stalk.
California golden poppy, Eschscholzia californica. There are several species of poppies. This one has the most pronounced ring, or collar (torus) around the base of the petals
Pink Rock Purslane, Calandrinia spectabilis
Tidy Tips, Layia platyglossa
Water drops on Mexican Honeysuckle, Justicia spicigera
The minimum working distance of this lens is about 4 feet. I carry an Achromat for tiny flowers, and the MWD is reduced to about 1 foot or less for magnifying closer in.
Verbena lilacena, similar looking to the Lantana. Uncropped. This cluster is 2cm across. Nikon 6T 2.9 dioptre Achromat mounted. A bit more than 1:1 here.
Well, it is a fun lens to use for flowers, but its size and weight make it not so practical for me for every day flower work, especially when hiking up in the Sierras!
- Richard
John Koerner
John Koerner Contributing Member • Posts: 664
Re: 800mm for flowers
richj20 wrote:
Butterflies are starting to appear around here in southern California, so I dusted off my wildlife setup which uses a Panasonic 100-400mm, f/4-6.3 (=200-400mm FF effective focal length).
Closeup in.. This is the only time I've been able to photograph a butterfly from the front displaying its proboscis. Usually it is blocked by a leaf or flower stalk.
- Richard
Nice images.
I just used an 800mm lens for a flower yesterday ... a 10 lb behemoth
Nikon D5 + 800mm f/5.6 FL ED + 1.25x TC = 1,000mm
Honestly, though, for me, the 300 PF + TC (1.6 lb) on a DX gives me ~630mm ...
And the reproduction ratio (.36x) is much better which is ideal for most flowers.
The thing I like about using telephotos for (some) flowers, is the compression that smaller lenses don't afford. Blurs out the backgrounds better.
 John Koerner's gear list:John Koerner's gear list
Nikon D500 Nikon D5 Nikon D850 Nikon Z7 Nikon Z6 +19 more
OP richj20 Veteran Member • Posts: 8,889
John Koerner wrote:
Nice images.
Thanks.
What a beast!
On paper, the specs would seem to suggest that. However, I've been able to get nice backgrounds with 50mm.
Stink-net, Oncosiphon piluliferum, invasive. Riverside is working to eradicate this!
Telegraph weed
California Golden Poppy, Eschscholzia californica
White Clover, Trifolium repens
Remaining seeds of a common dandelion, Taraxacum officinale
Arroyo Lupine. I include this because it illustrates a lot of what I photograph, low to the ground; very cumbersome to use a large lens in these situations
Nonetheless, if my goal were to have these types of backgrounds for everything, I suppose I would carry several lenses!
- Richard
John Koerner
richj20 wrote:
Thanks.
You bet.
What a beast!
Try carrying a 400 f/2.8 FL ED and an 800 f/5.6 FL ED together:
Depends on your definition of what "a nice background" is ...
- Richard
Which is pretty much exactly what I do:
Last Friday ... captured by my Girlfriend's D5600 ..
No matter how much gear your bring, it's never enough.
Everybody's budget is different, I get this, but pardon me when I laugh about the idea of anyone complaining about "lens weight" ... while they're holding "nothing heavy"
IMO, it's just an excuse to embrace mediocrity and lack of commitment ...
To each his own ...
stevendillonphoto Senior Member • Posts: 1,259
Nice series.  The Golden Poppy is very nice.  Lovely bokeh.
Steven Dillon - Capturing Nature's Art - http://www.stevendillonphoto.com
preferredfault Regular Member • Posts: 370
I can see the draw, you do get a decent depth of field from the long focal length (I've done 85mm-1500mm shots). But something else to try out is to use very weak macro filters on a lens. Just something that will ever so slightly shorten your minimum focusing distance, and that will cream out the background even with a shorter lens (or cream it out the same or more from a closer distance with that lens).
Having used a 1500mm lens, even then, the distance the background is from the subject is still important to getting things creamy. So really, you can achieve this effect with a shorter lens and a weak macro filter, possibly with a few benefits. Obviously your depth of field will suffer a bit (but not necessarily enough to be an issue), but even if you need stop up to f/14 or so to compensate to get more in focus, you'll still have a creamier background than without the filter at f/6.
"I can explain it for you, but I can't understand it for you."
(unknown member) Forum Pro • Posts: 19,317
- Richard
Nice images.
f.95 25mm prime
"When the debate is lost, slander becomes the tool of the losers." - Socrates
Olympus EM5mk2 ,EM1mk2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1
D Cox Forum Pro • Posts: 29,902
Interesting. I never thought of using a lens that long on flowers and insects.
You got good results.
Sigma fp
