GX80 battery on G3/GF2 charger: works!
Started Mar 17, 2020 | Discussions
seboseba
seboseba Forum Member • Posts: 58
Hello,
To those of you who have a GX80 (or GF3/5/6 or GX7) and have kept their G3 (or GF2, same battery), if you were thinking of buying a charger for the GX80, have a look at this.
Lumix BLG10E (GX80/85) battery charging on Lumix G3/GF2 dedicated charger. All you need to do is place a stop at the rear so the contacts gently meet (I used a felt tip cap here).
Voltage and amperage are practically identical on both cameras' batteries so no issues there. No overheating neither. It simply works!
Surely someone has thought of this before, wouldn't you think?
 seboseba's gear list:seboseba's gear list
Pentax K200D Pentax K10D
Panasonic Lumix DMC-G3 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85
bradevans
bradevans Senior Member • Posts: 1,029
Re: GX80 battery on G3/GF2 charger: works!
I've done similar (using a rubber band to keep contact pins touching the charging pins)
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
seboseba
OP seboseba Forum Member • Posts: 58
Way to go buddy!
