DIY Flash and Umbrella Attachment - Simple and Cheap
Started Mar 15, 2020 | Discussions
KiwiBee Contributing Member • Posts: 519
I didn't like the easily broken normal attachment method using the hot-shoe end of the flash, so have devised my own:
Here is a photo of the actual unit with flash and umbrella attached:
It works perfectly.  Hopefully it might be of interest to those wanting a very cheap, and simple to make portrait accessory.
Cheers
Bruce
KiwiBee
Mark B.
Mark B. Forum Pro • Posts: 29,751
Re: DIY Flash and Umbrella Attachment - Simple and Cheap
Cheers
Bruce
How does it hold the umbrella in place once positioned?
JimResnikoff
JimResnikoff Contributing Member • Posts: 806
Pretty creative!  I suppose a clothes pin would keep the umbrella shaft from sliding.
 JimResnikoff's gear list:JimResnikoff's gear list
Nikon D750 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S 70-200mm F2.8E FL ED VR Phase One Capture One Pro +2 more
OP KiwiBee Contributing Member • Posts: 519
Actually the weight of the umbrella itself seems to hold the stem in place, but a spring paper clip, or a rubber band wound onto the stem and slid down to where the stem enters the hole can more securely hold it in place.
KiwiBee
