Blue bar bottom of image. Canon SL2
Started Mar 14, 2020 | Discussions
Dak Ota New Member • Posts: 4
Hello. This bar started to appear on my images last week. Was actually half the size shown here, so it's growing. I searched high and low and can't find anything similar out there
Canon SL2. Doesn't matter if I change lens, inside or outside. Auto or various settings.  It's high shutter count and past warranty so won't be sending it in but would like to know what it is. I've had 10 canons and a million shots and this is a first. Even updated firmware. Thanks!
Canon EOS Rebel SL2 (EOS 200D / Kiss X9)
Ray UK Contributing Member • Posts: 977
Re: Blue bar bottom of image. Canon SL2
Try a new memory card, if that doesn't work then it is probably the sensor or main board at fault.
OP Dak Ota New Member • Posts: 4
Sadly it isn't the card
mdmarqphoto Senior Member • Posts: 1,460
It doesn't look like normal JPG corruption.  It looks like all the red is missing which could be a failed sensor.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
That's a good observation. And I suspect exactly right.
Nikon33
Nikon33 Senior Member • Posts: 2,539
I've had a very similar issue, but with a very high shutter count Nikon body. The problem was actually a memory card slot writing issue, that is the camera no longer wrote things correctly to the memory card. It resulted in a ton of money wasted on repairs (eventually dumped the camera). Since the camera you are having issues with is an SL2, I would just list it on eBay for parts or repair, and get another body. I think you got your money's worth out of it anyway. Good luck!
 Nikon33's gear list:Nikon33's gear list
Nikon Z9 Nikon Z 100-400mm Nikkor Z 600mm F4 TC VR S
Interesting. Yes, it has no value worth any repair. Probably 300k shots easy so got my money's worth. Wonder if that's something worth cracking body open. Again, it has no value so no loss. Curious if it's something worth trying.
Nikon33
Nope, the part was very expensive if I recall and not able to be obtained. Complicated repair, not really user repairable. Just sell it on eBay and get whatever you can out of it.
Karil New Member • Posts: 2
After I changed the shutter kit myself, something similar appeared, but it changes the band size.
Some help?
