10-25 vs 12-35 mkii?
Started Mar 10, 2020 | Photos
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Re: 10-25 vs 12-35 mkii?
mdubbs90 wrote:
Hey guys , I tried posting this on reddit but I’m purchasing a g9 soon. I used to have a have a 12-35 mki on my trusty g7 and I liked it .The images were sharp to me and I liked how compact it was, but I didn’t love how close I had to get to my subjects for usable bokeh.i found the range pretty decent, sometimes I wished for a little more reach, but I also liked how it challenged me in this regard. I would mainly use the lens for travel, video , and maybe small portrait work at 25mm? Basically I want to Know if The 25 is waaay sharper and if the bokeh is way better . Can you guys please give your thoughts and opinions? Thanks
Neither are meant to be bokeh champs and if you want to do portraits with narrow DOF/bokeh, you should look into the relatively cheap - especially used - Panny 42.5 F1.7 or Oly 45 F1.8. There are also of course the Nocticron or Oly 45 F1.2...
Bokeh / portraits aside, the 12-35 and 10-25 are obviously different beasts. You choice of either will depend on how much you shoot "wider-angle" and how picky you are on res. Also, the 10-25 is a huge and heavy beast, twice the size and weight of the 12-35. You'd better be pretty sure you need that range since it doesn't come cheap...
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
OP mdubbs90 New Member • Posts: 18
here are some pics i took two years ago in Dominican republic with the 12-35. me and my favorite model, my lovely girlfriend . So maybe this will give you guys an idea of what i like to shoot more ? i was also looking at video footage from this trip and was pretty impressed. i haven't seen the photos in a while. i might have to buy the 12-35 again !
Chris Noble
Chris Noble Veteran Member • Posts: 5,191
Thinking
Jianfei WANG wrote:
If weight size and cost are not the issues, go for 10-25 without thinking.
The OP travels and wishes the 12-35 had more reach. And who is indifferent to weight, size and cost? Seems like a bit of thinking is in order. Unless you're a pixel-peeper -- not a lot of thinking is involved in that.
 Chris Noble's gear list:Chris Noble's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +3 more
Re: Thinking
Lol Chris. Yes, it seems I’m a bit all over the place. I believe I want a premium zoom lens good for travel , video, and occasional portraiture.  I believe I’m going with the 12-35 as I’ve found it “good enough” in the past. I could deal with the weight and size of the  10-25 but maybe in the future. I posted some pics and noticed that some of my favorites are at the 33 -35 mm range : I might miss the reach  in the future .  I can see myself buying the 10-25 eventually , but I think my mind is made up. It would take a lot longer to save up the money
generationfourth Regular Member • Posts: 301
with what you said and what you shoot I think you'd be much better off with both the 12-35, and 35-100.
 generationfourth's gear list:generationfourth's gear list
Panasonic Lumix DMC-GF1 Olympus E-M1 III Panasonic Lumix G 20mm F1.7 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +4 more
Jianfei WANG Regular Member • Posts: 136
Re: Thinking
It's OP who asked for the recommendation between 10-25 and 12-35, my answer was totally based on that, I think it's YOU who should first learn how to READ and then think or even judge about anything!
Besides that, what makes you think 10-25 doesn't give more reach WIDELY over 12-35? Think, but do not think in ONLY ONE DIRECTION, OK?
My answer to OP regards to these two lenses was quite clear: IMO, 10-25 is way better than 12-35, except weight size and cost, which are all advantages of 12-35. Again, learn to read before making any judgment, please.
To OP:
If I were you, I would have made a choice between 10-25 and Pana Leica 12-60 according to your needs.
10-25 will give you 10-12 which is a useful addition range for landscape and architecture during travel, plus F/1.7 gives you the ability to work in low light conditions, which is a big advantage if you want a one lens solution for travel to handle more situations. Its IQ is also superior, prime level.
PL 12-60, on the other hand, is clearly more versatile by adding a lot of reach over 12-35. I saw your nice shots with 12-35 and also noticed that you shot quite a lot in 35mm, which I think you just reached the limit of 12-35. With 12-60, you'll be more flexible. Another advantage of 12-60 is its maximum magnification of 0.3x, it's more fun to use to shoot food image for example.
12-35 Mk I is surely a capable lens that you have already known, however, it has its own drawbacks due to its quite old design, besides its range and speed limit. Mark II of 12-35 only add Dual IS 2 and has no other improvement. Newer design of lens gives faster focus speed for example. Considering Mk II's price, I only could recommend it when weight/size is the first consideration.
For your bokeh needs, I agree with all others that you should pick a prime, I would second sigma 56 1.4 suggestion, which is a really bokeh monster in MFT.
 Jianfei WANG's gear list:Jianfei WANG's gear list
Fujifilm X-H2 Sigma 18-35mm F1.8 DC HSM Art Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Lumix DMC-GF1 +9 more
G Dickson
G Dickson Senior Member • Posts: 1,762
Your mention more reach, better bokeh and portraits. And ask if the bokeh is better. All in comparison to the 12-35.
To me the 10-25 is not what you are looking for. I would look at the 12-60. The extra length is going to help subject isolation and reach.
The 10-25 is a bit of a special lens. Video centric or for people that need a variety of wide focal lengths at a fast aperture.
You could buy the 12-60, a fast prime and still have PLENTY left over compared to the 10-25.
 G Dickson's gear list:G Dickson's gear list
Canon 6D Mark II Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
unhappymeal Senior Member • Posts: 2,625
The 10-25 is one of the best lenses I have ever used and has replaced almost all of my primes. It's amazing for both stills and videos. My standard kit now consists of PL 10-25 + PL 50-200 + 60 mm f/2.8. My 12-100 f/4 Pro sits on the shelf gathering dust now that I have this combo.
It's not a particularly light weight or cheap setup, but it's still lighter and cheaper than "full frame" and oh so versatile with fantastic image quality.
Re: Thinking
To OP:
thanks for the detailed reply Jianfei! I will consider 12-60 but variable aperture drives me crazy 😣 unless I treat it as an f4 . And I will look into sigma for sure. Right now I’m caught between 12-60 or 12-35 mkii and prime . I’m looking at 42.5 1.7 but also like your suggestion of the sigma thanks again !
I think I’ll start with either 12-35mkii or 12-60 Leica and a prime . After I buy those two I will buy the 35-100 I hear it’s great and I’ve been wanting it a long time!  Thanks for your suggestion generation fourth !
unhappy 🥘, i think I’m actually going to go with12-60 Leica or 12-35 ii and a prime. After thinking it over, it would take too long for me to save and I think it’s too big . When I started this thread I was all gung ho about 10-25 because iq  and whatnot but I think I enjoyed the compact size of the 12-35 on vacation and found the images good enough for my needs. I think for me , the 10-25 would be my “holy grail” lens , the one I save up for in the future when I have made money off my photos ...or just feel like splurging! One day.... just not now anytime soon 🙁. But I still appreciate Really appreciate everyone’s input this thread ; it helped me realize a lot about my shooting style and specific needs for my photography 👍.
Thanks white beard . I’m going to do a switcharoo and get either 12-35ii or 12-60 Leica  and a prime for now . Either 42.5 1.7 or sigma 56 1.4 . This thread made me realize I think I have to prioritize speed and weight. And cost ! I think the 10-25 is my grail lens . One day I’ll get it ... it’s just not the lens I need right now . Thanks for your input
junk1 Senior Member • Posts: 1,788
Re: Thinking
Why not buy one of the 12-60 lenses?
