10-25 vs 12-35 mkii?
Started Mar 10, 2020 | Photos
mdubbs90 New Member • Posts: 18
Hey guys , I tried posting this on reddit but I’m purchasing a g9 soon. I used to have a have a 12-35 mki on my trusty g7 and I liked it .The images were sharp to me and I liked how compact it was, but I didn’t love how close I had to get to my subjects for usable bokeh.i found the range pretty decent, sometimes I wished for a little more reach, but I also liked how it challenged me in this regard. I would mainly use the lens for travel, video , and maybe small portrait work at 25mm? Basically I want to Know if The 25 is waaay sharper and if the bokeh is way better . Can you guys please give your thoughts and opinions? Thanks
Comment & critique:
Panasonic Lumix DC-G9 Panasonic Lumix DMC-G7
James Stirling
James Stirling Veteran Member • Posts: 9,282
Re: 10-25 vs 12-35 mkii?
6
They are very different lenses regarding fov,aperture, size weight and cost. The 10-25mm optically is better across the board
The difference in size and weight is significant and worth thinking about especially as travel is one of your use cases. But it really is a cracker of a lens
Jim Stirling:
It is not reason which is the guide of life, but custom. David Hume
 James Stirling's gear list:James Stirling's gear list
Sony RX100 IV Panasonic Lumix DMC-GX8 Nikon Z7 Olympus E-M5 III Nikon Z7 II +10 more
Jianfei WANG Regular Member • Posts: 136
5
If weight size and cost are not the issues, go for 10-25 without thinking.
 Jianfei WANG's gear list:Jianfei WANG's gear list
Fujifilm X-H2 Sigma 18-35mm F1.8 DC HSM Art Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Lumix DMC-GF1 +9 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
the 10-25 can be a great travel and video lens, but it is not a classic portrait one.   I probably could use this one over a 12-35, but it 10-25 is heavier, and I already have portrait lenses.
If buying 10-25, either have lotsa cash, or found you have the specific need for it.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Harold66
Harold66 Forum Pro • Posts: 12,002
5
Buying the 10-25mm sounds like a bad idea based on what you wrote
with your 12-35mm do you really find that you take a lot of portraits at the 25ml focal length ? Or rather at the longer end of your zoom ?
if you really need 25mm for portraits better off buying the 25mm prime from Panasonic or Olympus
but if I were you for portraits on the G9 I would really go for the 1.7/ 42.5mm from Panasonic. A true gem for portraits and which weights about nothing in your bag
Harold
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
TheDream168
TheDream168 Regular Member • Posts: 155
Yes, I think the 10-25 is certainly noticeably sharper than the 12-35.
But I would caution if you're looking for bokeh. 10-25 is still not really telephoto, so you certainly won't get the bokeh you would get at 42.5mm or further.
Some shots I took using the 10-25 at a motorshow below. You may notice that the bokeh is considerably "creamier" when I zoomed in, but certainly not if a more telephoto lens was used, even if at the same aperture. Most of my shots were taken at f/2.0.
https://microfourthirdssite.blogspot.com/2020/02/micro-four-thirds-at-singapore.html
GCharma Regular Member • Posts: 188
I recently picked up the 10-25, and owned the 12-35 v1. Neither of these will give you huge bokeh for a bunch of reasons, though both could maybe force it for close-up work (10-25mm has a minimum focus distance of 28cm, the 12-35 is 25cm). If bokeh is at all important to you I think the suggestion of using a different (and prime) lens like the 42.5mm f1.7 (or better yet the 75mm f1.8) would be your best option.
So far my experience with the 10-25 is that it's a superb lens for tight work in dark areas - stuff like city/street photos, trade shows, indoor candids at family events, crowds (where the subject is the crowd as opposed to what they're watching), that sort of thing. The additional 2mm on the wide end is very handy in those scenarios, as is the constant and bright aperture. I'm just not sure I'd use either as a dedicated portrait lens, and for the cost of the 10-25 it's an expensive thing to test unless you're really sure.
Good luck!
 GCharma's gear list:GCharma's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Sony a7R IV Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 +10 more
brentbrent Veteran Member • Posts: 5,768
Technically "bokeh" refers to the quality of blurring of out-of-focus elements, and therefore it is distinct from "depth of field." It sounds to me like you want shallower depth of field than you can obtain with the 12-35, without getting closer to your subject.
At a distance of 5" from your subject, the depth of field produced by 35mm at f/2.8 is actually a bit more shallow than depth of field produced by 25mm at f/1.7. So if I understand correctly what you are looking for, the 10-25 appears not to be the solution. You would have to get even closer to your subject to get shallower depth of field.
Now, you would need to get closer to get the same framing as 35mm, so I'm sort of comparing apples and oranges, but I think my comments are accurate given what you wrote.
The Sigma 56mm f/1.4 might be a great choice for you.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Felice62 Veteran Member • Posts: 5,079
10-25 doesn't ring me any bell. I'd be rather happy with a 8-18 AND 12-35.
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
OP mdubbs90 New Member • Posts: 18
Jim, wow I didn’t think the difference would be so huge optically. I did enjoy how compact the 12-35 was when I had it on my vacation to DR Maybe I’ll just get a nice prime for my bokeh fix ! But then again...
I think I could deal with size and weight but I would save for long time . If I get it, it would be my only lens for a long time
Thanks Tim, i might just have to get a prime for my bokeh fix.
Harold
Harold, I’ve heard good things about the 42.5 . I think I’ll stick with a 12-35 and the 42.5 . The 10-25 seems amazing but it would take too long I think to save up. Maybe one day  😆
Thank you for the examples. It give me a better idea of what the lens can do. I guess I won’t get it for the time being , the less I have to save , the sooner I can start shooting😀
(unknown member) Senior Member • Posts: 1,455
A couple of spreadsheet prints. My own homebrew Excel so be used with caution. I notice you do not seem to have crop factor in. Field of view will be less for a specific lens due to the larger circle of confusion.
Adjusted for equal framing
burritosandbeer Regular Member • Posts: 314
FWIW, the 12-35 f/2.8 works well enough for portraits that I usually don't carry my 25f/1.7 anymore.
 burritosandbeer's gear list:burritosandbeer's gear list
Olympus PEN E-PL6 Panasonic Lumix DMC-G7 Panasonic G95 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +7 more
Harold66
Harold
Good idea. If you check my instagram page underneath most of the images you will see are made with that 1.7.42.5 mm lens
www.haroldglit.com
Heh, the DOF app I use is just always set to the 4/3 sensor, as you can see at the top of each screen shot.  My mind more and more relates to the gear I use as it is (MFT exclusively), and therefore I don't think much about crop factors, or about "FF" equivalent focal lengths, etc.   (unless I'm trying to explain my gear to a FF photographer)
But, yeah, my comments and the results from my DOF app were of the "quick and dirty" variety, and I have no doubt that more sophisticated analyses could be provided, as yours probably is.
Cheers.
Brent
Sorry I missed that.
Cheers.
James Stirling
Yep the 10-25mm is a super bit of kit. If I was starting out in m43 again I would seriously consider it as it covers my favourite focal lengths
Another excellent combo would be the Oly 12-100mm with your favourite fast prime for an wide ranging and excellent travel kit it is hard to beat { apart from size }
Jim Stirling:
