BIF tips for T3i?
Started Mar 9, 2020 | Discussions
HRC2016 Veteran Member • Posts: 6,874
BIF tips for T3i?
Are there any credible sources of information on shooting birds with a T3i?
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50) Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
adventurer69
adventurer69 Senior Member • Posts: 1,942
Re: BIF tips for T3i?
I have tried , very low hit rate .
 adventurer69's gear list:adventurer69's gear list
Canon PowerShot A590 IS Canon PowerShot SD880 IS Canon PowerShot SX50 HS Canon EOS M Canon EOS M50 +11 more
Ontarian Veteran Member • Posts: 3,859
I never had much luck with BIF using a T3, but did luck out a couple of times.  With good light and reasonable distance you can get some keepers.  The biggest challenge is the limitation on cropping with the low megapixel sensor.
 Ontarian's gear list:Ontarian's gear list
Sony RX10 IV
Digirame Forum Pro • Posts: 41,857
Occasionally I can take good pictures of BIFs with the Canon T3i (600D) camera.  But with that camera it takes lots of coordination and fast reflexes since I have it set for a single spot autofocus.  I don't take lots of BIFs.  I think it would be easier with the Canon T7i (800D) camera.
FooHead Contributing Member • Posts: 546
I've done it with my 12M T3. You need to be pretty close to your subject as cropping isn't great on my T3. Really good light as well so you can keep the shutter speed up and ISO as low as you dare. I always left mine on center point focus, but using all 9 may work too.
One you know the limitations with your body, patience, practice and technique can be adapted.
 FooHead's gear list:FooHead's gear list
Canon EOS 1100D Canon EOS 80D Canon EF 35mm F2.0 Canon EF 100mm f/2.8 Macro USM Canon EF-S 18-135mm F3.5-5.6 IS STM +2 more
