How secure is Android?
Started Mar 9, 2020 | Questions
onlyfreeman
onlyfreeman Senior Member • Posts: 2,498
Just wondering about security features on modern Android phones, from 2017+, running Android 7+ pre-installed.
Does Android have good security, comparable to iOS?
Can thieves brute force a pin / pattern lock to steal data? Could this be dependent on brand / model of phone?
Any security tips for keep data away from thieves?
Thanks for any information.
 onlyfreeman's gear list:onlyfreeman's gear list
FastStone Photo Resizer Paint.net
I2K4
I2K4 Senior Member • Posts: 1,441
Re: How secure is Android?
There's endless discussion of more or less quality about each of these questions, and I suspect anyone can get any answer they want to hear. Using Android without incident since version 2.3, and currently on 8 and 9, my distilled wisdom is:
1. Virtually all reported exploits are from installing malware with bad apps from bad sources. Google's Play Store is about as safe as Apple's App Store, and third party security is not needed if that is the sole source of apps.
2. Android, unlike Apple, permits app install from other sources. If "side loading" apps as APKs or installing from anywhere but Play Store, use a third party security app to scan for and block malware, replicating what the stores do. I currently use BitDefender free for automatic operation at very low resource use, but watch laboratory rankings every year - no brand loyalty is ever deserved.
3. I only really worry about leaving the phone someplace and am much less worried about a hacked Pattern than about never seeing it again. I use a lockscreen message: "REWARD if found: extra-email[at]domain" which is forwarded to my real email. For dead battery, I also keep a small post-it with the Reward message stuck on the back inside the protective case (I worry most of all about dropping the phone, tending to be once or twice a year).
4.  Should make oneself familiar with Google's device finding system.
5. Others differ, but I don't personally like or trust biometric security so don't enable fingerprint or face unlocks.
vv50
vv50 Contributing Member • Posts: 904
https://outline.com/y2ky7x
https://www.esecurityplanet.com/mobile-security/unlocking-smartphones-pins-patterns-or-fingerprints.html
2FA
onlyfreeman
OP onlyfreeman Senior Member • Posts: 2,498
vv50 wrote:
2FA
Thanks for the links.
I'm not too familiar with 2FA, how does that work in every day use for keeping the data on the phone secure?
For example if the phone was in possession of an individual or group, and they were attempting to access the data without any assistance from the owner.
Could 2FA help in this situation and how?
vv50
onlyfreeman wrote:
vv50 wrote:
2FA
it doesn't, it's for securing your online accounts that hold your data.
yes, if you had 2fa enabled, then they can't just use passwords saved in your browser to access your accounts without your U2F key or authenticator app PIN.
if you are on Android 9 or later, Lockdown is the feature that is more fit for the particular situation you describe.
onlyfreeman
That's interesting to know.
I found out that recent Samsung phones have a shutdown prevention feature, this means that a thief could not easily shutdown the phone (when locked) and give more time to the owner to track it.
Are you aware if this is a Samsung only feature or built into Android?
I would really like to know if any other manufacturers offer anything similar.
vv50
as mentioned before, Android 9 and above has Lockdown mode.
onlyfreeman
Thanks I'm aware of lockdown mode, however it does not prevent shutdown as far as I know.
The Samsung feature is not really to protect the data, but to provide extra time to track the thief. As far as I'm aware, only Samsung has this kind of feature, which I like, but I dislike using Samsung phones.
vv50
from a security standpoint, your phone should be disposable, it's less important than safeguarding your data. if your phone gets stolen, you should wipe it out remotely.
if you need the highest levels of security then enroll in advanced protection program.
RedFox88 Forum Pro • Posts: 30,738
Well android issue is the device maker usually is slow to roll out O/S updates to their users and will only do it for a year or 2 unlike Apple who makes iOS and the devices so they get updated without lag and for years
fotografffic Senior Member • Posts: 1,328
Forgive my ignorance (just went from Android 7 to Android 10 on a new phone).
What's a lockdown feature? Never heard of it or 2FA, though I've just now briefly read about the later at Wikipedia. Over my head. Sounds similar, but different, than two-step authentication.
Thank you.
onlyfreeman
Thank you.
I think lockdown is simply something you activate usually from the lock screen. It disables every method of unlocking the phone (like fingerprint) besides the pass/pin/pattern. This means an attacker could not simply forcibly make you look at or touch your phone to unlock it, they'd have to make you reveal the correct code.
