Re: Bag for your small kit? Pen Lites?
burritosandbeer wrote:
So, first off I am big into m43 because I like small, light, and fast. That said I do think there are good places for larger bodies. As such I run two kits.
First is the main gear,
Panasonic G7, Panasonic 12-35 f/2.8 II, Panasonic 35-100 F/2.8 II, Panasonic 100-300 f/4-5.6 ii, and Panasonic 42.5 f/1.7 in a thinktank turnstyle v2 10l.
My small/light kit is,
Olympus Epl6 Panasonic 14-42PZ f/3.5-5.6, Panasonic 45-150 F/4-5.6, and a 25 f/1.7.
I usually carry the small light kit in my jacket pockets, or trim it down even more when its not jacket season, but I really want a small light bag for it. Ideally something that can hold it and the two lenses I usually carry for it, ideally on my belt or the like so I can keep my hands free, and have it ready when I use it.
It really is my favorite walking around kit when I want something small and light, without sacrificing the IQ I get from my chosen format and lenses.
Not looking for "Use your phone" suggestions, or suggestions on super zoom compacts, thanks but i really like that kit, just looking for a good bag.
My suggestion is to get a padded insert or zippered lens cases and use any sling bag you like. That way, you can tailor your kit depending on how much or little you want to carry.
I use an array of lens cases… LowePro, Mountainsmith, Pearstone… and several different sized sling bags. It's an extremely flexible system and you can use pretty much any bag you want.
I never put my camera in a bag, unless I'm biking or going through airports.
I just found (and ordered) this Kinesis (F102 Padded Utility Pouch) padded insert that looks perfect.
https://kgear.eogear.com/collections/kinesis-lens-pouches/products/kinesis-f102-small-utility-pouch
Here's a bunch of random lenses with their lens cases and a couple of sling bags I use.
The Mountainsmith Zoom S double lens case on the left Holds 2 lenses, or a camera + pancake lens.
I can put one in the small green bag or 2 in the blue bag. I'll often attach a lens case to the pack strap for quick access… switching between a standard lens and 7-14mm f4, for instance.
2 Medium sized lenses, like Panasonic 14-140mm f3.5-5.6, 45-150mm or Voigtländer Noktons fit in the Mountainsmith cases.
12-40mm and Voigtländer 21mm f4 with LowePro lens cases, Voigtlander 75mm f1.5 with pearsone lens case.
Mountainsmith Zoom S cases, with 2 lenses each.
