Copying mounted chrome slides with the Nikon ES-1 holder
Started Mar 5, 2020 | Discussions
Gerry Siegel
Gerry Siegel Veteran Member • Posts: 3,244
I have been seeking a way to easily copy my collection of stereo chromes.  My latest gadget works with a Lumix GX 8 micro four thirds camera by use of a set of tubes and the Olympus 60 mm macro lens.
Note:  My first test is not processed for enlarged stereo nor greatly color or light corrected.
Sandy left image
Sandy right image
 Gerry Siegel's gear list:Gerry Siegel's gear list
Panasonic ZS100 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 +4 more
Gerry Siegel
OP Gerry Siegel Veteran Member • Posts: 3,244
Re: Copying mounted chrome slides with the Nikon ES-1 holder
Copy kit with Nikon ES-1
Uses reducer from 52mm thread of kit to the 46mm thread of the Olympus micro lens on a micro four thirds camera.  Works and also hits it on the nail in autofocus as here.
bosjohn21
bosjohn21 Forum Pro • Posts: 23,117
i did this with my nikon d610 and the sixty mm macro also nikon.  worked fine, gives a twenty four meg file, if you want a much higer quality scan you get in much closer and take four or six shots and stitch them now yuo  have a huge file and quality as good a some ot of the  best
i used to have a nikon cool scan but it was tedious and slow,
there are some attachments for duping slides from the good old days that would work but i went with  copy stand and an assortment of negative and slide holders  desighned for the omega b22 which coveres all but a few negs I have bigger than 6x6. the most important thing i discovered is my ipad makes an ideal light sourse you just get on line and search for a pure white screen. the the pad is dead even across it surface so you could scan four by five easiy just laying them on the pad as it not hot,
a few years back i posted a bung of pics of the set up,
John aka bosjohn21
Gerry Siegel
If it works for you, John great.
I tried a vertical arrangement with a light box. And then horizontal methods which turned out mor easy to manage ( I hate standing on stools) And a bellows with a slide copier attachment ( a Canon Auto Bellows) and then a stack of wooden laminate sheets and a plastic slide holder I jiggered...and durn it I had to keep light off the thing. Or shoot in the dark. The beauty of the ES-1 and ES-2 is it has tubes that keep all light out.  I have an iPAd and I bet that is a definite idea...the LED costs some, not much, but lo and behold it has lumens controls and some color control which is handy.   And moving it closer can also make your f Stop really large for the purpose of focus....steadiness is eliminated whan the whole deal is a single unit as the one I show above.
That alone is worth the price of the Nikon kits... I got the idea or stole it from Wrotniak the gent who has a micro four thirds blog. He has not posted for months and has not elaborated . Actually I found that it is best to add at least one more tube attachment to get the full slide in the micro four thirds size sensor....if one has a full frame camera of course that is what the rig was designed for....Big praise for this method of slide duping from me.
Gerry Siegel
Sample.  For cross eye viewing.
my big brother.
