Want to go back to a Canon Powershot, which one?
Started Mar 5, 2020 | Questions
Shadowman1 New Member • Posts: 4
Hi there,
Any help and advice with this matter would be much appreciated.
I used to use a Canon a710 IS and it was fantastic, everything I needed and took good quality images. I'm getting sick of all this 'Phonography' and running out of space, data and just having photos on phones of pretty low quality and richness. And the current small digital cameras are amazing I'm sure but just have too many features for me, unnecessarily high image quality for what I need, high price...etc
SO my question...
I would be perfectly happy to go back and buy an a710 IS on eBay for peanuts and use that however I'm interested in maybe upgrading slightly but keeping the same nice compact yet tactile size as the a710(Roughly) and keeping the simplicity and usability of the a710.
I'm looking at these:
The Canon G10, G11 or G15? What are these like? Are they similar in functionality and size, obviously they are much much better cameras.
And the Canon A590 IS?
I'm open to any other suggestions as well.
Essentially if there is anyone out there who knows these Canon compact digital cameras (from around 2007-2011) which camera would you recommend me going back to given what I'm looking for?
Thanks!
Canon PowerShot A590 IS Canon PowerShot A710 IS Canon PowerShot G11 Canon PowerShot G15
oxon1 Regular Member • Posts: 323
Re: Want to go back to a Canon Powershot, which one?
I still have  both of them but use Canon S110.
These photos were taken with each other.
AshleyMC Senior Member • Posts: 2,228
I have a PowerShot S110 and G15, but rarely use them now. They are great P&S cameras with the usual Canon build quality, ease of use and lovely colors.
I also have a PowerShot G7 X Mark II. In many cases, I am pleasantly surprised by the top-notch SOOC JPEG image quality -- the images look so good I tell myself to leave my heavy DLSR cameras at home and bring this little wonder which has a "fast" zoom lens -- f/1. 8-2.8 and equivalent focal range of 24-100mm -- and uses a 20.1MP 1" sensor. (Note that the G15 uses a 1/1.7 inch sensor, so does the S110.)
Now that the Mark III has been released, you can get a G7 X Mark II at lowered price.
Some photos:
OP Shadowman1 New Member • Posts: 4
Thanks for the tips and info.
I quite like the look of the G series, G10, G11, G12, G15...etc As they are similar in size but are a bit more capable and have a much higher resolution. Would a G10 be a good step from the A710? And which G series camera is the best?
I will look into the G7, looks great.
What's the difference between the A710, A720 and A590?
Thanks again, it's a great help.
it seems to be popular opinion that the G12 is the best of the old G series. Certain people preferred the old CCD sensor and were unhappy with Canon's change to CMOS.
I like my G15, the second last of the series, and keep it although I no longer use it much. To me, it has been surpassed by the recent G cameras. (If you want the convenience of SOOC JPEG, the newer DIGIC processors are your friends.)
It might turn out to be what you like.
The A720 IS and A590 IS are identical component-wise. Differences are in the optics:
A720 IS
Focal Range: 5.8 - 34.8mm (35 - 210mm equivalent)
Aperture range: Maximum f/2.8 - 4.8, down to f/8
Focus Range: Normal: 21.6" (55cm) - infinity, macro: 0.4" (1cm) - 21.6" (55cm) wide
A590 IS
Focal Range: 5.8 - 23.2mm (35 - 140mm equivalent)
Aperture Range: Maximum f/2.6 - 5.5, down to f/8
Focus Range: Normal: 18" (45cm) - infinity, macro: 2.0" (5cm) - 18" (45cm) wide
Between those two, I would go with A720.
Smaug01
Smaug01 Veteran Member • Posts: 6,966
The last PowerShot I had that I liked was the S90...
...so I would recommend an S120, or whatever the latest of that line was. Heck or even an S90, S100 or S110. I think they all use the same battery, which will probably be around for a good while. They're pocket sized, too, so what you lose in lens speed, you gain in portability.
While it had a small sensor and not a super-fast lens, its lens was good and sharp. I got in the habit of carrying a table-top tripod, so I could set the sensitivity low and take advantage of the good lens.
I decided to upgrade to a G9X II when I wanted to up the game, reasoning that a larger sensor (1") would make that happen. But I was not really happy with the image sharpness, compared to what I could get with my Olympus XZ-1. (a bit bigger sensor and a markedly better lens)
So I sold that and bought a G7X II. Same thing. Faster lens, but not really sharper. Neither of the above two stood up to my Lumix FZ1000 either, with the same size sensor.
At this point, my only compact fixed lens camera is the Pentax MX-1. (which has the same fantastic lens and sensor from the Olympus XZ-1, but with better style and a more rugged build)
Some day, I'll add a proper pocket camera again. Might be another S-series Canon.
-Jeremy
"Rudeness is the weak man's imitation of strength."
 Smaug01's gear list:Smaug01's gear list
Panasonic Lumix DMC-TS30 Ricoh GR III Olympus OM-D E-M10 III Nikon Z5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +25 more
Agapeman Regular Member • Posts: 107
I still keep my G12 and use it when I simply want an easy camera to grab a photo. It takes great images for its size. I love all the controls, especially the ISO dial. One review I came across that really speaks to the greatness of the G12 is linked below. For me the G12 was the best PowerShot of that series.
https://photographic-central.blogspot.com/2011/04/canon-g12-review.html
 Agapeman's gear list:Agapeman's gear list
Canon PowerShot G12 Canon G3 X Canon EOS 550D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II +1 more
adventurer69
adventurer69 Senior Member • Posts: 1,938
I still have the A590 and it's a fantastic camera .
 adventurer69's gear list:adventurer69's gear list
Canon PowerShot A590 IS Canon PowerShot SD880 IS Canon PowerShot SX50 HS Canon EOS M Canon EOS M50 +11 more
Thanks for the advice everyone. Sounds like the G12 is the one to go for although it looks quite a lot bigger than the A710.
What's the difference between the G10 and G12, is the G12 that much better?
I'd like to stick with the older models, ie not a G7X or the like. Are there any other small Canon cameras from the 2007-2012 era that I haven't looked at that would be worth looking into coming from the A710?
Thanks again
I'm reposting this link to a review where near the bottom he compared the G12 to the G10 and why he liked the G12 better, in case you did not read it earlier.
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
I like all my powershots the SD880 is nice and I still like my Pro1
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
Hachu21 Forum Member • Posts: 77
I owned a A710IS too and I liked it. The form factor was perfect. I upgraded it with a S95 in 2010 and then M series cameras and lenses in 2013.
I fully understand your quest for a compact, simple all-in-one camera.
I you like the A710IS form factor, the G serie is the obvious upgrade. The A710IS was named "Mini G7" at his time.
My Advice would be to aim for a G15 or G16. Why?
- Even if the G have a bit more options, you can use them exactly in the same way as the A710. Even full auto if you want (green mode). So they are not more complicated.
- The handling is similar (few milimeters more in height and width, depth is the same).
- A bit bigger and more recent sensor, a much brighter lense will give you better results in low light (the biggest limit of the A710 IMHO).
- Thanks to a more recent CPU, you get a camera wich is snappier for both autofocus and général opération.
- A lens that is wider : 28 vs. 35mm. Useful for indoor shots or some landscapes.
- The more directly visible upgrade? A much higher resolution screen and a bit bigger. Which is a pleasure to look at.
Canon G spec comparison
A710IS Vs G16 size comparison
- The only downside I see is the shorter lens 140mm vs 210mm.
The G12 is a good G, already better than A710, but it's a bit bigger due to it's articulated screen, and he don't have the brighter lens and faster CPU.
My 2 cents.
Have a good time with your Powershots!
 Hachu21's gear list:Hachu21's gear list
Canon EOS M Canon EOS M6 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Samyang 12mm F2.0 NCS CS +6 more
Ed B
Ed B Forum Pro • Posts: 12,571
Re: The last PowerShot I had that I liked was the S90...
I agree with your comment about the FZ1000. One of the best smaller sensor (one-inch) cameras.
Mike Gezing New Member • Posts: 5
In my opinion the G12 is one great camera.  Bought mine in 2011 and is my go to camera for outings and parties when a DSLR is just too much over kill.  Also being able to shoot RAW and jpeg is a big plus for this camera.
GeraldW Veteran Member • Posts: 8,872
Over time, I've owned and used just about all the cameras mentioned in this thread.  We (my wife and I) still have an A710 IS and an A720 IS.  They are mainly my wife's; but I did carry one around in my car 24/7 so that I always had a camera with me.  That is, until I finally got around to getting a modern phone with a good camera, a Samsung S9.
We are getting pretty old now, so we're not cruising anymore; but back in 2009 we went on a cruise in the Galapagos Islands.  At the time I had a G7, and my wife brought the A710 IS.   The shots from the two cameras look identical if shot in daylight; but the G7 is a little better indoors.
The G7 and G9 both used the same viewfinder, and both have the same design defect.  Since the viewfinder is above the lens, it sees a little different view than the lens.  The G7/G9 finder sees the same view as the lens at about 5-6 feet.  But the A710IS and just about every other Powershot with an eye level finder sees the same view at long distances (beyond 50').   Canon corrected this in the G10 and all later models.  I did eventually get used to the G7 viewfinder and learned to adjust where the viewfinder was pointed to get a properly framed image at different distances.
I missed owning a G10; but had the G11 and G12.  Image quality is virtually the same from those two - the main difference being a second control wheel on the front of the G12.  I found I preferred the feel of the G11.  Both have quite low noise sensors.
I bought a G15 in 2012 and still have one, although the one I have now was bought in late 2018 as I missed having one.  The benefit of the G15 is the fast lens.  The G16 uses a different processor (the DIGIC 6) and I swear it's not as sharp as a result.  That's also true of the S120 versus the older S90 or S95, or the S100 or S110.  Yes, I still have an S95.
I bought a G7X Mk II a while back, and it was supposed to replace both the S95 and G15.  Well, I do use the G7X II the most of all my cameras; but the fact that I still have the S95, and replaced the G15 should tell you something.
If you should decide to stick with the A 710 or A720 IS here's a tip.  Instead of using rechargeable AA cells, we use Energizer lithium.  They are good for around 600 shots in those cameras and don't self discharge in the camera, so it's ready to go when ever you pick it up.  We do carry a spare pair in it's bag.  A set of 4 batteries goes for around $10.  my wife loves that she doesn't have to worry about charge management.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon EOS M5 Canon PowerShot S95 Canon PowerShot G15 Canon G7 X II Sony RX10 IV +1 more
Your thoughts coincide with mine.
I miss the S95 that I sold before purchasing the S110. I still have the G15.
I use the G7 X Mark II most often these days.
The G12 and S95 were the 2 last ccd sensored high-end compact from Canon.
Lot of people prefer the CCD rendering. Cmos sensor seems less sharp, a bit mushy when viewed at 100%. That can be a problem on 12mp cameras...
hBill Regular Member • Posts: 279
Hmmm
Though many newer G series had better low light/high iso capability - when the light is good - gotta appreciate the G10 . . .
https://luminous-landscape.com/kidding/
Though a little bigger the G1X is pretty close but with better low light/high iso performance - reputed to be related to the 7d sensor technology - not " modern " but better .
Its rare to see comparison fotos in dpreview for the G10 but you should be able to pull up the G1x as an option under the image quality tab in their camera reviews .
And its said the G1xii has even better low light/high iso perfromance but a bit less resolution.
Both ( or all three ) are worthy of being the camera to bring when your friends don't want you lugging around a day pack full of gear for a walk around the park .
Hike Pics
Hike Pics Senior Member • Posts: 2,918
As far as the older models go, my A720 still not only impresses me, but sometimes surprises me on a shot that I would swear was not going to be a good one. It's almost like it will NOT let you take a bad photo. And I have had mine since it came out with no problems whatsoever. And if it dies tomorrow, I would get another one the same day.
As far as the G series goes, I don't own but wish I had the G11. Maybe this summer!
...Wes...
NAwlins Contrarian Veteran Member • Posts: 7,964
A720 IS, S110, others
I used to use a Canon a710 IS and it was fantastic, everything I needed and took good quality images. .. And the current small digital cameras are amazing I'm sure but just have too many features for me, unnecessarily high image quality for what I need, high price...etc
SO my question...
My short answer is that the A720 IS (https://www.dpreview.com/products/canon/compacts/canon_a720is) and the second S110 (https://www.dpreview.com/products/canon/compacts/canon_s110, not the first one!) stand out to me as the best overall quality-and-value combinations among older models from somewhat different eras--the S110 obviously being much newer, more capable, and more expensive.
The long answer: I bought an A570 IS, mainly for my wife's use, right around the time our younger son was born, which is right about when it came out. It was a great camera, but eventually died. It was so liked that my parents bought another one (used), and I later bought one used to keep in my car.
And yet, from that era, the A720 IS arguably offered more capability for not much more money. More than once I regretted not getting it instead. But I do go back and forth on that. IIRC the A570 had a couple of advantages.
Also, there was the somewhat uncommon A650 IS, which had a somewhat larger sensor. That should be another step up, if you can find one in good working condition.
Since then we've had a bunch of Canon compacts, including the SX240 HS mostly for my wife, bought new about when our last child was born, an SD4000 IS bought for me as very pocketable option, plus the S95, S110, and very recently S120. We also bought a Canon compact for our older son, the model escapes me at the moment.
At this point I don't tolerate well any camera that doesn't have a raw file option. The S-series models give you that, plus a somewhat larger sensor and somewhat faster lens. The S95 has a CCD sensor and a 28-105mm-equivalent lens. The S100 moved up to a CMOS sensor and 24-120mm-equivalent lens, but by many accounts the lens had bad quality-control issues that harmed optical performance. The S110 was basically an S100 with a corrected lens. It also has a touchscreen, which I like more than I expected, and wifi--I can connect it directly to my phone and wifi over my photos. The S120 keeps all that and moves to a slightly faster 24-120mm-equivalent lens and a slightly better sensor. But my sense is that eBay prices for a good S110 from a reputable seller are a lot lower than comparable S120 prices.
What about the G series? IMO they were always big, clunky, and expensive for what you got. I realize others disagree!
 NAwlins Contrarian's gear list:NAwlins Contrarian's gear list
Nikon Coolpix S30 Canon PowerShot S120 Sony Alpha DSLR-A580 Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-300mm F/4-5.6 Di USD +5 more
