X100v OVF
Started Mar 1, 2020 | Discussions
Jay A Senior Member • Posts: 2,576
X100v OVF
When I first purchased an X100 camera years ago, I felt that the fact that it had an OVF along with an EVF was wonderful. Until recently, I never cared for EVFs as I felt they were very difficult to view through and see all the details in the scene. Nowadays though, they have become pretty good and it has led me to question the usefulness of the OVF in the latest X100 cameras.
A couple of things about the OVF really bother me.
First, while I understand that some like the idea of seeing outside the actual frame, I do think that the frame at least on the OVF in the X100v is too small. The image should be magnified a bit with less outside frame real estate.
Second, a very irritating fact about focusing with the OVF is the fact that if you use the corrected frame option (and you should so that you are positioning the camera correctly in order to compensate for parallax error), you cannot even see a correctly placed corrected frame until you first press down the shutter release to focus. The frame will THEN be positioned correctly. So, unless you already knew where the camera would correctly focus, you must focus a second time where that corrected frame now falls.
Third, the focus frames in the OVF are just too big. When using the OVF, the camera does not always focus correctly. When using the EVF, the focus point frame size can be changed and become more able to pinpoint correctly.
I do understand that one of the biggest draws to these cameras is the ability to switch between EVF and OVF. But I think that at this point with improved EVFs, the OVF has outlived its value. It seems to be more of a gimmick than anything. An effort to make these cameras seem like Leicas.
Comments?
Fujifilm FinePix X100
William Porter
William Porter Senior Member • Posts: 1,877
Re: X100v OVF
Thanks for your post, which interests me very much and makes points that I myself am a bit concerned about. I've ordered an X100V (black) -- probably won't have it for some weeks. It will be my first Fuji camera. My current main cameras are a Sony A7 III and a Sony RX10 IV, both of which have pretty good EVFs and terrific autofocus.
What I like about the idea of the OVF as I understand it's implemented in the X100V is that I'll be able to see more of the scene in front of me than I'm going to capture. That sounds useful.
But I really do not understand how you focus with the X100V and I'm looking forward to learning when I get mine. The autofocus on my current Sony cameras is tremendous so I'm not hoping for the X100V to be better -- but I do hope it's not worse.
Sean Reid's outstanding website https://www.reidreviews.com/ has a number of articles about the X100V, the X-PRO3 and a fantastic old article about the various different types of finders. It's all behind a paywall but very much worth the price of admission. He's extremely fond of Leica rangefinders and so also very keen on certain Fuji cameras like the X100V and the X-PRO3. His article on the varieties of finder is the best thing I've ever read on the subject and very thought-provoking. But it is also a bit, well, "philosophical" might be too strong, so I'll just say abstract. I like this sort of thing. But in the end, it's also the case that I use the camera as a tool to take photos. Reid is fond of the experience of shooting with rangefinder-style OVF. True he thinks it leads to better photos. I'm not so sure but am eager to find out.
William
 William Porter's gear list:William Porter's gear list
Panasonic LX100 Sony RX10 IV Fujifilm X100V Fujifilm X-E3 Sony a7 III +12 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
Re: X100v OVF
Parallax error  is a function of distance. Hence it cannot be calculated until the camera knows the distance which is why you have to focus first.  However, for a fixed focal length lens - it is pretty simple to estimate it just by eyeball.
Comments?
"If you learn only methods, you’ll be tied to your methods, but if you learn principles you can devise your own methods." Ralph Waldo Emerson
___
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Geekapoo
Geekapoo Senior Member • Posts: 2,831
Re: X100v OVF
Owned the XPRO2, thought the OVF/EVF nothing more than a gimmick IMO. YMMV.
William, re the AF, I've not used the XT4 but otherwise do know that nothing Fuji sells matches the AF-C of the RX10 IV or the newer gen A7.
 Geekapoo's gear list:Geekapoo's gear list
Sony RX10 IV Fujifilm X-E3 Sony a7R IV Sony a9 II Sony 35mm F1.4 G +15 more
William Porter
Re: X100v OVF
Richard,
Thanks for the comment. I am going to wait and see. It is quite possible that I'll return the X100V (assuming it ever actually arrives). But of course there's more to shooting than good autofocus.
One of the things I dislike about the Sonys is that -- in my view, anyway -- there are too many options. I am strongly (if inexplicably) attracted to the minimalist exterior of the X100V. I wish I could eliminate about half a dozen of the buttons on the outside of my A7 III. Don't ask me which ones I'd eliminate: I don't know, but this isn't entirely rational. In other respects I love the way the A7 III feels in my hand and it does take good photos.
The other problem I have with the Sonys (the RX10 IV and the A7 III) is that they're too big to carry with me all the time. The RX10 IV is great on vacation but not for, say, taking over to visit my grandchildren or just carrying around in my truck when I'm out and about. Even with the remarkably good Rokinon 35mm pancake lens, the A7 III is definitely not "compact". It's kind of down to the Fuji X100V or the Panasonic LX100 II (with its MFT sensor). We'll see.
William
DarnGoodPhotos Forum Pro • Posts: 11,881
Re: X100v OVF
Something I swear I remember the X100T could do was dynamically update the frame lines.  Maybe it required Pre-AF and AF-C but I can't imagine it wouldn't burn through your battery.
I've always just learned to anticipate where between the two boxes the af point will be depending on how close the subject is. Much like Auto ISO won't pick an ISO without meeting first, it can't display the corrected AF box without your focusing on the subject first.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Geekapoo
Re: X100v OVF
Richard,
William
Yes, there is definitely more to camera appeal than having the best AF..less than the best may suffice.
Overall, I love my Fuji gear for a variety of reasons but have given up on the XPRO series (having owned the first two releases) and have passed on the X100 series as the OVF/EVF has no appeal.
The Panasonic LX100 II might be fun to shoot with but if AF is a critical feature and you want a small camera, the last two gen RX100 cameras might be worth checking out..I own one but don't really like it (it's not worth selling/early gen).
William Porter
focus vs autofocus
Well, saying "less than the best may suffice" seems a bit, well, not the way I'd put it. I do want really good focus. But really good focus is not the same thing as really good autofocus. I used manual focus exclusively for a long time, including shooting weddings and even shooting school sports. As long as I can get the results I want, I'm happy, even if I have to work a little harder.
And to be honest although Sony A7 III autofocus is supposed to be pretty close to the gold standard, from my perspective, there are so many options that it almost seems a bit misleading to call it "auto" focus. I mean, it feels like I need to spend fifteen minutes before a session programming the pages and pages of autofocus options. It's so easy it's become hard!
I sometimes wonder how we ever managed to take photos back when I got started. No menus and almost no options on the cameras -- aperture, shutter speed, ASA/ISO, manual focus and perhaps futzing with a filter.
Yes, I've considered the RX100 vii. I reviewed the original RX100 many years ago very favorably. But the RX100 vii is, to be honest, almost TOO compact for my big hands. I know, I'm hard to please. Plus I already have the RX10 iv which is basically a ginormous version of the RX100 vii with an even better zoom. At least the X100V or the LX100 ii would give me something different to play with.
I know, I'm impossible to please.
William
radialMelt Forum Member • Posts: 70
Re: focus vs autofocus
To play Devil's advocate, there's nothing stopping you from approaching the Fuji in this way. The options are as they are called: options. Although I will concede the focus-by-wire is not entirely pleasant to use in regards to manual focusing.
 radialMelt's gear list:radialMelt's gear list
Fujifilm X100V Fujifilm X-H1 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR
Mikeywcu
Mikeywcu Senior Member • Posts: 1,055
Re: X100v OVF
William,
As an A7iii shooter, I also wanted something smaller. I grabbed the X-E3 and 27mm 2.8, and it’s put a bug in me. Now I’m considering moving away from Sony altogether.
Richard,
William
 Mikeywcu's gear list:Mikeywcu's gear list
Fujifilm X-H2S Tokina AT-X Pro 100mm f/2.8 Macro Leica Summarit-M 75mm f/2.5 Carl Zeiss C Biogon T* 2,8/35 ZM Carl Zeiss Planar T* 2/50 ZM +11 more
PentaxNick Senior Member • Posts: 1,831
Re: X100v OVF
The wide view outside the 35mm framelines matches the 28mm view when the WCL is fitted. The framelines then disappear.
Nick
 PentaxNick's gear list:PentaxNick's gear list
Ricoh GR Fujifilm X100T Olympus Tough TG-4 Ricoh GR III Olympus PEN-F +12 more
jjcha Regular Member • Posts: 216
Re: X100v OVF
This is really interesting - you move around the AF point when using the OVF? I've never really considered this style of acquiring focus -- I only use center point with the OVF. I guess I'm just curious as to the advantages of using the OVF + moving around the AF?
For me, as a street photographer, the main benefit of the OVF is speed and not wanting to use the AF joystick. It's faster for me to center focus and recompose than move the AF around. Once you're moving the AF point around, the speed advantage of the OVF is kinda lost, at least for me, so I'm curious as to what it does for you?
From your thoughts, I wonder if the Leica Q isn't for you. I hear you though on wanting to see outside the framelines, which is an advantage of an OVF over nearly every EVF, with the exception of the Leica Q.
If you're really into that and want the EVF, I can recommend shooting 35mm on a Leica Q2, as the sensor and EVF still "sees" the 28mm view, but captures a jpg with the 35mm crop or records a 28mm RAW with a default crop of 35mm.
William Porter
Re: X100v OVF
What's different about the Leica Q? And (I'm a bit confused) what is the Leica different from? Are you saying that it's a unique OVF or a unique EVF?
Well, for myself, I think I'd go for the Leica if I could justify the price, but it's hard for me. I could do it, but I'd feel guilty about it -- and selling all my Sony stuff to end up with a single fixed prime lens camera seems, well, just a tad crazy, even by my standards.
William
OP Jay A Senior Member • Posts: 2,576
Re: X100v OVF
William
If you like the idea of seeing outside the frame the OVF makes sense.
I'd say that manually focusing with the Fuji is a similar experience as the Sonys. You have focus assist options like you do with a Sony.
Re: X100v OVF
Comments?
I suppose you may be able to estimate where the corrected focus frame will appear, but with the EVF you don't have to. The current EVF is pretty good. You can see highlights much better than you could with the EVF in the original  X100. I am just saying that I am not sure the current OVF makes much sense anymore unless you want to see outside the frame lines.
Re: X100v OVF
Richard,
William
The Fuji may not have as many buttons as a Sony but it actually has as much if not more menu options. It's daunting.
Re: X100v OVF
Hmmm. Maybe it does require pre-af. Not something I want to have though as yes it will use a lot of battery all the time.
Re: X100v OVF
When you turn on the "corrected focus frame" option, you see 2 sets of frame lines for the focus point. One is the one you have set to have the camera use as its focus point, and another (showing only the edges of the frame) shows where the camera will actually focus due to parallax error. It moves depending on how close or far you are from the subject that you are focusing on. So say, you focus on a subject 10 feet away, you will see both focus frames. If you then refocus on something 6 feet away, the corrected frame will have moved slightly. So again, this second frame is telling you exactly where the camera will focus which is not necessarily behind the frame you have chosen to use.
The problem is that this corrected frame does not adjust for parallax error until you actually press the shutter release half way (or the back focus button if you use that instead). So to see it in its correct spot, you have to do this, and THEN do it again to focus using that exact frame. So focusing then become a 2 step process (unless you estimate where the frame will appear, as has been suggested). On the other hand, focusing using the EVF is always a 1 step process. Press half way and it focuses where your focus point is. Nothing needs to be calculated because there won't be any parallax error when using the EVF.
Being that the EVFs have gotten much better over the years, it seems that there really is much less need for the OVF at all. When I owned the X100 I preferred using it as the view through EVFs in those days was just not very good.
If I could afford a Leica Q2, I wouldn't be in this forum.
Re: X100v OVF
May have just been an X100T thing since my X-Pro2 doesn't do it.
chris__n Junior Member • Posts: 31
Re: X100v OVF
when i had my T, it would do this if you were in manual focus mode. hopefully the V does this as well! i only use manual focus mode!
 chris__n's gear list:chris__n's gear list
Ricoh GR Fujifilm X100V Canon EOS 5D Fujifilm X-T2
