How can I remove a bug's wing from a 5D4 focusing screen?
Started Feb 29, 2020 | Questions
sssanti Contributing Member • Posts: 727
When changing lenses with my Canon 5D mark IV, a small bug got into the camera. I saw the bug through the viewfinder when I was taking pictures of some flowers and I thought it would be an interesting combination. However, the bug did not show in the picture. It was actually on the focusing screen, and it was killed by mirror impact.
After this unusual event, my viewfinder shows a piece of the bug's wings on the top, that I would like to clean:
View: original size
I can also see the piece of wing by looking up through the lens mount.
View: original size
I tried using an air blower and a lens brush, but this area has very difficult access. The piece of wing is just behind a vertical tab where the mirror stops while taking a picture. I would need some kind of small soft brush with with a handle at a right angle to be able to reach this without bumping into the mirror.
Do you have any ideas to clean this part of the focusing screen?
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Tweezers
sssanti wrote:
View: original size
Tweezers to grasp and lift the part away. You'll want tweezers that have a very fine tip and perhaps a curved tip, so you can reach there better. After you've gotten it out/loose, a blower should remove any remaining shards.
All that said, OVFs get dusty/dirty. This doesn't hurt anything.
Of course, the whole screen is removable if you want to go that route....
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
OP sssanti Contributing Member • Posts: 727
Re: Tweezers
ProfHankD wrote:
sssanti wrote:
View: original size
Thanks for your reply.
Wildbegonia
Wildbegonia Senior Member • Posts: 1,043
Re: Tweezers
sssanti wrote:
ProfHankD wrote:
sssanti wrote:
View: original size
if the advise above is not sufficient, you may have to compose or frame your photos in a way that you can easily “fulminate” this piece of wing in post processing. 🙄
'Balls! Said the Queen, if I have them, I'll be the King'.
In law a man is guilty when he violates the rights of others. In ethics he is guilty if he only thinks of doing so. Kant
 Wildbegonia's gear list:Wildbegonia's gear list
Pentax K200D
HRC2016 Veteran Member • Posts: 6,874
Re: Tweezers
If you haven't already, try using a very tiny makeup or paint brush. Approach it from the side, as if you were trying to pry it off.
I think tweezers might leave a mark.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
