Panasonic Lumix DMC-CM1 update?
Started Feb 28, 2020 | Discussions
zoranT Contributing Member • Posts: 926
Hi fellow CM1owners out there,
some questions:
– is there a way to update the CM1 to newer Android systems than 5?
– Did anyone of you root the device, with what results? Any set-ups that you can recommend?
I am still running OS 5, but some functions are slow or malfunctioning (when I run certain programs I can t pick up the phone or only with delay). The only reason why i won t give up on this is of course the camera. Can t stand overprocessed phone type images, even by flagships.
Anyway, I would appreciate if someone s out there to share some insights or updates or accessoires that I may have missed for this underappreciated camphone. Thanks.
vv50
vv50 Contributing Member • Posts: 904
Re: Panasonic Lumix DMC-CM1 update?
short answer is no.
long answer is no because the manufacturer's not doing it and they can't be forced to adapt their camera-specific software customizations to the newer versions, which are tested to work on the older version.
