Should I upgrade my GX8 to G9?
Started Feb 26, 2020 | Discussions
OP Pete2 Junior Member • Posts: 42
EVF with glasses
Those of you who are using glasses. How do you find G9's EVF compared to GX8?
I just read a thread where some people are complaining about the G9's EVF and I don't have a opportunity to test it myself without ordering it. G9 should have better EVF but now I'm not so sure anymore.
 Pete2's gear list:Pete2's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 12-35mm F2.8 +3 more
brentbrent Veteran Member • Posts: 5,766
Re: EVF with glasses
I just read athread where some people are complaining about the G9's EVF and I don't have a opportunity to test it myself without ordering it. G9 should have better EVF but now I'm not so sure anymore.
I think most of the "complaints" about the G9's EVF are that it has slight pin-cushion edges.  I never notice it unless I really look for it.
The G9 has a V Mode button near the EVF that lets you select three sizes for the image in the EVF.  My understanding is that the slightly smaller sizes are primarily for people who wear glasses.  All of them are great, IMO, but I don't wear glasses when taking photos.  I don't think you should worry about the EVF.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Gnine Senior Member • Posts: 4,108
I own & use both cameras, I wear glasses, they're both excellent viewfinders. I actually bought the deeper eye cup for the GX8 to see if it helped with eliminating stray light. It did, kind of.
People will complain about anything if they're desperate enough to try & find faults. The old fashioned word for that is called nit picking
add-on eyecups
I like the deeper eyecups on my GX7 and GX8, but I did not like the one for the G9.  Too big, too deep.  I tried cutting it to make it angled (I wish they made one of those for it), but I butchered it.
Brent
rashid7
rashid7 Veteran Member • Posts: 7,011
Re: add-on eyecups
I bought the bigger eye cup for my GX9.  It helps in bright daylight, but makes the camera more clumsy to insert into a nice snug fitting bag!
Keep it fun!
Re: add-on eyecups
Yeah, the G9 is spot on. The GX8 was just a little bit shallow, & quite hard. You can see it sitting on top of the camera in the shot I posted for comparison's sake
Terminal Boy Senior Member • Posts: 1,292
Re: Should I upgrade my GX8 to G9?
alcelc wrote:
If size and weight of G9 will worry you, why not consider the G95?
Or the G85 which is considerably cheaper than the G95 which is still more expensive (though with a lower spec) than the G9?
 Terminal Boy's gear list:Terminal Boy's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
