Aperture Solenoid Repair
Started Feb 26, 2020 | Discussions
ozdean
ozdean Forum Pro • Posts: 28,665
I can't remember how long ago I bought my K50 but it finally succumbed to the Aperture Block problem.
I sent it to our Australian Distributor CR Kennedy and after all these years they repaired it free of charge and also freighted it back to me at no cost!
I cannot speak too highly of them. I will always buy Pentax and always from them you can't ask for more IMO
Here's the little offender -also returned.
( Not a macro shot just the 16-85 at its limits - sorry )
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Pentax K-50
andrew britten Senior Member • Posts: 1,495
Re: Aperture Solenoid Repair
You do well with CR Kennedy, Dean.
I have to admit, over the years, I've had much the same experience.
I seem to remember them repairing a couple of 645 bodies I had, gratis.
Not as detailed as yours, though.
Cheers
AB
 andrew britten's gear list:andrew britten's gear list
Pentax K10D Pentax K-7 Pentax K-x Pentax K-5 Pentax K-01 +2 more
Benoz
Benoz Veteran Member • Posts: 6,866
You're lucky Dean!
I repaired mine myself! Never asked CR Kennedy though!
 Benoz's gear list:Benoz's gear list
Pentax MX-1 Ricoh GR III Pentax K-5 IIs Pentax KP Pentax smc FA 50mm F1.4 +8 more
ozdean
OP ozdean Forum Pro • Posts: 28,665
Good for you and them Andrew, they are most obliging.
ozdean
Hi Ben they repaired a friends K30 and my sisters K50 - same all free of cost.
M R Padmaraju Veteran Member • Posts: 6,658
Congrats . You are lucky . My K-70 is yet to get the treatment !
Regards ,
mrp .
 M R Padmaraju's gear list:M R Padmaraju's gear list
Fujifilm FinePix F40fd Pentax K-x Pentax K-01 Pentax K-500 Pentax K-S1 +8 more
Massao Senior Member • Posts: 2,580
Good to hear and what a great service that is!!
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
KRG1953
KRG1953 Regular Member • Posts: 307
I Hope they used a white solenoid for the replacement. Normaly the Pentax spare parts have only the same green solenoid. That is the newer production from China. I ordered a used white solenoid via ebay from the US. They are from older camera's and they strip those to get a donor white solenoid.  My K-X has also the white solenoid and that K_X is still running oke after 50K . My K-S2 with the green one died after 30K. Now my K-S2 has a white solenoid too.
 KRG1953's gear list:KRG1953's gear list
Pentax K-S2 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax FA 28-105mm F3.5-5.6 Pentax K-x +7 more
flektogon
flektogon Veteran Member • Posts: 6,226
Dean, if not you personally, but someone from your circle, who has some electronic training could take a closer look at that solenoid and to try to identify what possibly could be wrong with it. Because it looks so cute and innocent...
Peter
ozdean
Is your K70 showing problems mrp? I hadn't heard of too many.
ozdean
Yes very pleased Massao, they have always been great.
ozdean
I hope they did too KRG - thanks for the info.
ozdean
Yes such an nicely made piece - it would make a nice necklace - LOL.
Thank you , Dean . My K-70 has stopped working totally . ` have bought a couple of solenoids . As ` am busy with my wife`s health issues , not given much attention to my photography ! ` am using my K-01 .
Regards ,
mrp .
ozdean
I didn't realize the K70s were having the problem.
I do hope your wife is on the mend mrp glad to hear you are taking good care of her - most important!
All the best.
KRG1953
Regards ,
mrp .
What is the problem with your K-70  ?  The white vs green solenoid things are only helpful when your K-70 is suffering of So called aperture block failure. That problems shows up mostly in this way:  at the start of a couple of pics, the first 2 or 3 are dark, the rest is oke .  At a more severe state the problem gives all the pics are way to dark. Than the solenoid is not able anymore to pull the mechanism that pulls the handle for opening the aperture. So in that case it causes the dark result.
I hope you get my point.
So whan your k-70 does nothing at all, the aperture failure black is not likely to give this result.
I hope you can describe more exactly what is happening. Then may be we can be more helpful.
Thank you , KRG . It is exactly the way you have said . To start with a couple of frames used to go dark . Now it is not able to pull the aperture at all . Almost nine months ago `had reported this in the thread and most of the friends suggested to change to white solenoid / file the edges of the existing one . So far ` have not tried to change or repair the plunger . Other than this K-70 is fine . In a couple of days ( a weeks time ) ` will take it to a friend who is a good camera mechanic , 150 KM away from me , @ Mysuru . `could not get the white one though . Please let me know if there is any other problem with the aperture works ... . (It is happening with KS-1 also ).
https://www.dpreview.com/forums/thread/4375594
https://www.dpreview.com/forums/thread/4383596
Regards ,
mrp .
KRG1953
You can still find a white solenoid vvia eBay. Look for the add from
potmano(780)
Thank you , KRG . ` will try .
Regards ,
mrp .
