Powershot Lens Filters
Started Feb 26, 2020 | Questions
Mtcpa New Member • Posts: 1
I have a SX500 IS and trying to find a way to add a adapter for 55mm lens filters.
The camera has no threads for a filter
Canon PowerShot SX500 IS
Chaplain Mark
Chaplain Mark Veteran Member • Posts: 6,539
Re: Powershot Lens Filters
Welcome to the Forums...!!
The camera has no filter threads on the lens assembly because the camera is not designed to accept the addition of any weight at all to the lens.
The lens zoom/focus gear assembly is quite fragile as regards the load it can bear in operation, which does not include the extra loading of a filter adapter and/or filter.
To burden the lens with the additional weight of accessories is to greatly increase the likelihood of lens gearmotor failure.
Thank You,
Chaplain Mark
'Tis better to have a camera and not need one than to need a camera and not have one.
In pursuit of photographic excellence.
 Chaplain Mark's gear list:Chaplain Mark's gear list
Canon G3 X Canon PowerShot G5 X Sony a7R III Sony a7C Sony FE 135mm F1.8 GM +3 more
Charlie BRM
Charlie BRM Regular Member • Posts: 183
You can be inexpensive push-on filter adapters. The one I have is from GOJA (58mm) for a SX50 HS and I just saw one this morning on Amazon.
Anything I write here is from my SX50 perspective.
The face of the camera lens has a plastic ring with 2 gaps in the "lip". The adapter goes on with tabs into those gaps. You gently push the adapter in and then give it a quarter turn to set it. The outside face of the adapter has your "new" female threads.
If you don't crank down the filter threads too hard you shouldn't have any trouble un-screwing the filter later and the adapter stays on the camera. Mine is plastic for this very reason. Some people bought metal ones and they seized on to the filter threads. The other scenario is the adapter and filter come off the camera together and you deal with separating them off camera. Just remember it is a low force quarter turn and with handling it might work its way off the camera while you're handling it. No bueno.
 Charlie BRM's gear list:Charlie BRM's gear list
Canon PowerShot SX50 HS Sony a7 III +5 more
(unknown member) Senior Member • Posts: 1,455
The SX50 is an entirely different camera which is designed to take filters via a bayonet adapter. I doubt this applies to the SX500 but am happy to be corrected if it is.
I2K4
I2K4 Senior Member • Posts: 1,441
Don't own it but third party adapters are available: presumably you want 55mm for filters you have, but I don't see that available, so might mean purchasing to fit.
Canon Powershot SX500 is Filter Adapter
https://www.amazon.com/Canon-Powershot-SX500-Filter-Adapter/dp/B074CVD54N
Amazon also offers a big kit of 67mm adds including telephoto lens with an adapter for U$129, though badly rated:
https://amzn.to/395TOip
I'd say the tiny weight of this kind of adapter and a CPL or ND filter isn't going to burden the mechanism - certainly doesn't on my SX10.   A lens would be a different matter.
Charlie BRM
I think in this instance, AllFlawed is correct, and thus not "All Flawed" at all
There seem to be models designated SX5## that do have the lips a push and turn (bayonet) adapter would mount to, but zooming in on what I could find online, the 500 does not.
I ran into this teeth gritting myself with a Canon Vixia camcorder. They manufacture a long series of almost identical models in the same period but you miss one detail and you wind up without some feature they could have included on all of them for pennies extra.
GeraldW Veteran Member • Posts: 8,872
Chaplain Mark,
I have had quite good luck using 42 mm Magfilters on a couple of my smaller cameras, including a G15, G7X II, SX220, and several others from Canon, Olympus, and Panasonic.  The adapter is a very thin adhesive backed ring that has practically no weight.  The CPL filter itself is very light, and held in place magnetically, so it's easy and convenient to mount and dismount.  None of the cameras I use the Magfilter on will fit back in their cases with the filter in place, so usage is limited to just a very short time to minimize wear and tear on the lens' zoom drive system.  Discipline is key.
You are correct in that if the camera lens has no provision for mounting a filter or even a hood, trying to make it use one is a recipe for future problems.  Further, the torque used to mount bayonet style hoods and filter adapters has caused problems for me with a Panasonic FZ200 where it screwed up the AF and OIS in the lens when mounting or dismounting the hood with the lens extended.  I learned the hard way to only mount or dismount the hood with the lens fully retracted and the camera powered off.  That's another story; but it does reinforce the fragility of the internal components.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon EOS M5 Canon PowerShot S95 Canon PowerShot G15 Canon G7 X II Sony RX10 IV +1 more
Chaplain Mark
GeraldW wrote:
Chaplain Mark,
Jerry,
I appreciate the information, and most likely I will continue to refrain from attaching any non-Canon accessories to my PowerShot cameras.
Having had two PowerShots with lens errors, just not willing to chance it...
Thank You,
Chaplain Mark
