ANOTHER HSS HELP
Started Feb 25, 2020 | Discussions
sinima first
sinima first New Member • Posts: 1
ANOTHER HSS HELP
I am having a difficulty with the setup of settings in my camera (at least I think I am). I am having issues setting HSS on my T7i unless I have the trigger on the hot shoe. Am I doing something wrong or is it because i'm using a Godox speed light? the speed light is Canon compatible and it has HSS but it doesn't do anything over 1/200th. Is there anyone that can help me because I am going to need this in weddings/parties this coming spring. Thank you in advance
 sinima first's gear list:sinima first's gear list
Canon EOS Rebel T7i Canon EF 135mm F2L USM Canon EF 50mm F1.8 STM
Canon EOS Rebel T7i / EOS 800D / Kiss X9i
rmexpress22 Senior Member • Posts: 2,304
Re: ANOTHER HSS HELP
You have to put the flash on HSS mode. Otherwise, it won't let you go over the usual max sync speed.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
sinima first wrote:
I am having a difficulty with the setup of settings in my camera (at least I think I am). I am having issues setting HSS on my T7i unless I have the trigger on the hot shoe. ...
The T7i can do HSS with an HSS-capable speedlite mounted in the hotshoe, or with an HSS-capable "Master" controller in the hotshoe to trigger remote HSS slaves.
If you are wanting the built-in flash of the T7i to control your off-camera speedlite, it can - but only at x-sync (1/200) and longer shutter speeds.  The built-in flash is not capable of HSS, and it cannot control HSS in a slaved remote speedlite(s).
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
