Do I really need an 135mm f/2L for portraits?
Started Feb 24, 2020 | Questions
EOSSpeedLite Contributing Member • Posts: 640
If you have to ask, then no.
To the OP, if you have to ask, then the answer is no, you do not need this lens.
 EOSSpeedLite's gear list:EOSSpeedLite's gear list
Canon EOS R5 Canon EF 135mm F2L USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III Canon EF 100-400mm F4.5-5.6L IS II +12 more
Steve Balcombe Forum Pro • Posts: 15,582
Re: Do I really need an 135mm f/2L for portraits?
Steve Balcombe wrote:
This is a gear forum - of course you need it
Indeed - you may even be like me - acquire a lot of lenses that you never use. The main purpose is to have them, just in case ...
I do have the 135/2.0, but tend to use the 85/1.8 a lot more
I do have a 70-200/4.0 IS, that I have not used much since getting the 100-400 II
I have a 70-200/4L IS, which I never use since buying a 70-300L, which I never use since buying a 100-400L II.
Which I now never use since buying a 100-500 🙂
I do have a 50/1.4 that I hardly ever use, just waiting for Canon to bring a decent replacement
Dave
Dave Veteran Member • Posts: 6,231
The photography begats?
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
Haha yes I wonder what the next generation will be...
Dave
Cellphones?  â˜šī¸
Cellphones? â˜šī¸
Actually I committed myself to two years of higher payments in order to get a Galaxy S21 Plus, but the 'telephoto' performance is disappointing. I thought I might have something useful in my pocket if I was ever caught out with a long lens subject and no camera, but it's only good for record shots. The macro mode is only slightly better. It's quite good for environment shots though, when I'm out doing wildlife or macro with the proper camera.
Dave
Cellphones? â˜šī¸
My sun bought me a new case for my XR, so I guess I’m committed to keeping it for another year or two.
Scott Larson Veteran Member • Posts: 7,505
Here's a real reason why you might not need it. If you have a 200mm lens that's f2.8 (either the prime lens or one of the zooms) and you don't need the extra stop of light then you can get pretty much the same look as the 135mm f2 wide open with a little more distance from your subject.
The 135mm f2 is one of my most used lens, but the 200mm f2.8 prime is cheaper and it's identical in terms of color, contrast, and sharpness wide open. I've shot with both and honestly I couldn't tell you which shot came from which lens.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
J A C S
J A C S Forum Pro • Posts: 20,544
I think that the 200/2.8 is an underappreciated lens, indeed, but for handholding, the 135/2 is often borderline acceptable in a so-so light while the 200/2.8 needs two more stops (well a bit less than two)...
PicNoir Regular Member • Posts: 129
I sold my 200/2,8 for 70-200/4 L IS, for flexibility. Now really thinking to get 135/2 for my soul, still missing IQ experienced with 200/2,8.
 PicNoir's gear list:PicNoir's gear list
Canon EOS 6D Canon EF 100mm f/2.8 Macro USM Tamron SP AF 17-35mm F/2.8-4 Di LD Aspherical (IF) Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F4L IS USM +1 more
It seems like everyone but me is always shooting in dim light.
