Loga
Re: Nice "pop" to this lens
Harold66 wrote:
Tatouzou wrote:
Harold66 wrote:
Tatouzou wrote:
Luke Forrest wrote:
Harold66 wrote:
Hello
This is soooo weird . None of the images posted in the last 4 replies seem very sharp. As a matter of fact , I noticed something which is very bad
Unless the images were postprocessed , several images including the one with the mushrooms are only somewhat sharp in the center and everything else is unsharp .
There are many lenses out there which are less sharp in the corners at full aperture , especially the ones which rely a lot on autocorrection for vignetting
but here we are not talking about corners , just off center
Hopefully someone can post better examples because here the pics shown would indicate really poor results for that lens
Harold
There are many review sites which actually test the lens if you're interested in sharpness. According to lenstip, it has excellent centre sharpness but so so corner sharpness. The lens is only 55g and is relatively cheap especially used, about the same price as a used kit lens. It's hard to complain about this lens, it's a budget lens that has decent performance. I'd recommend this over a kit lens for something like street photography. For landscape a 12-32mm might be better.
https://www.lenstip.com/273.4-Lens_review-Panasonic_G_14_mm_f_2.5_ASPH._Image_resolution.html
In regards to 'pop', I'd argue that light is more important than any lens characteristic.
Don't forget the subject, framing and composition.
My GM5 + 14 f2.5 is to me kinda Ricoh GR, with an EVF.:-)
Bonjour Tatouzou
The GR has a MUCH better lens than this 14mm . Not even close . The 14mm has the reputation of being a very average lens and what I have seen on this thread seems definitely to confirm this
H
Maybe, but I value usability over performance. My GM5 + 14 f2.5 fits my requirements for a very small high IQ responsive street camera.
Not sure what you have in mind when you mention usability. The GRII is VERY responsive, from start up to focusing time I would be very surprised if it is not at least as quick, and probably quicker than your combo
I am not sure about the GM5, but my GF2 with 14 f2.5 is on pair with my Ricoh GR II in terms of AF speed.
Startup time of Panasonic cameras is generally very good. Again, I am not sure about the GM5, but my GF2 + 14 is a little bit faster for startup + first image than my GR II. But the difference is not big at all. This is how I feel about it; I did not do any measurements, not to mention a controlled one
(I saw that the GR III is faster in this regard with faster lens extension.)
Still, this kind of usability is better for the GR II IMHO, because it has the snap focus option, and I use that by default. So when I turn on the camera, I don't have to mess with focus, but can focus on how to compose quickly - or just grab the moment by a snap. Even if the Panas have the option of some kind of hyperfocal focus setting (Just turn them on in Manual focus mode, and it will set the lens to that), I prefer the GR implementation here.
My favourite use-case here is to use the GRII with an optical VF while the LCD is off, but the camera is on permanently. No startup time at all - like the old film cameras Of course you can do this with any Panasonic camera too.
But I also agree, that if someone has limited budget and would like to use more than one focal length, then an m43 body + 14mm (or a kit zoom) + let's say, a 45 f1.8 is a better option for about the same price as a GR II costs.
Not to mention the snap mode and the back focus button which are often decisive for street photography
The IQ the 14mm delivers is more than I expected, and I can use it on any of my three M43 bodies.
o,
A GR3 would cost me three times the price of the 14 f2.5 alone (I have the GM5 since 2017), and would not bring more usability.
a brand new gr2 is less than thedouble of your 14mm lens
By the way, not everybody agrees with your low rating of this lens. Check Imaging resource for instance.
I did and i saw the one on opticallimits. The fact is this is a 10 year old lens so-if the lens was reviewed today on a more modern sensor some of the comments would be different
anyway this lens relies heavily on auto correction for chromatic aberrations and distortions
Does the GR's not? I am asking, I don't know the answer.
yes the lens produces good results at f4 but that is not telling much
That being said, depending on owner’s use and expectations that maybe enough for lotsof users
H
