Nice "pop" to this lens
Started Feb 22, 2020 | User reviews
skatr New Member • Posts: 4
12
I've used the version II on both a Panasonic GM5 and now on an Olympus Pen F. One handed shooting is a breeze on each camera due to the minuscule weight of the 14mm pancake. I've alway liked the 28mm focal length on film cameras and this one matches that FOV.
This lens falls off a bit in the extreme corners in low light but shooting at the native 4x3 aspect ratio I always crop like mad anyway so it is not a problem. This lens is super sharp stopped down to f4 and it has a real 3D pop to its rendering undoubtedly because of only having 6 elements. Great lens.
 skatr's gear list:skatr's gear list
Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +1 more
Panasonic Lumix G 14mm F2.5 II ASPH
Prime lens • Micro Four Thirds • H-H014AK
Announced: Sep 15, 2014
skatr's score
4.0
Average community score
4.5
Olympus PEN-F Panasonic Lumix DMC-GM5 Panasonic Lumix G 14mm F2.5 II ASPH
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: Nice "pop" to this lens
This lens gets a bad rap because it is not as good as the 20mm f1.7 and "only" f2.5.
I think it is a fine lens and I still have and use mine even though I bought the 15mm f1.7
Allan
alcelc
alcelc Forum Pro • Posts: 19,004
I have mk-I of this lens for a long time as a merely free kit with GF3, which should be optically the same as mk-II.
It is not bad, but also not outstanding. When comparing to 14~45, 14 does not have any wow factor to me except for the pancake design, light weight or a faster speed of f/2.5 vsf/3.5.
However before GX85/G85 has the finally usable IBIS, the 3~3.5 stops effective stabilisation of lens OIS on a non IBIS Panny body, f/2.5 indeed has no advantage at all. I can shoot with much slower shutter speed with the OIS f/3.5 than non stabilized f/2.5 on G1, GX1 or GX7... So for quite a long time 14 had gathered dust. I use 14 again after upgraded to GX85, but the 2~2.5 stops effective IBIS doesn't make 14 shine.
Now when I need a fast lens I shall pick up the 15 f/1.7 (similar AoV, faster speed, not really much larger and heavier...). 15 also has better IQ than 14. If Panny can produce a 14 f/1.7 in similar size of f/2.5, it could be a far more interesting lens.
Albert
jf_tea Senior Member • Posts: 1,577
I really like mine too. Even if I do not use it often.
It's nicer on the newer 16mpx sensors than it was on the GF2.
-JF
 jf_tea's gear list:jf_tea's gear list
Panasonic Lumix DMC-GX1 Pentax K-01 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Pentax smc DA 15mm F4 ED AL Limited +6 more
Luke Forrest Senior Member • Posts: 1,072
7
IBIS or OIS doesn't help with anything moving. A stop of light does though.
That lens is more than double the price. You pay for what you get.
rashid7
rashid7 Veteran Member • Posts: 7,011
The best (outdoor) environmental portrait I've ever taken was w/ the 14!  =kit lens on GF2
Keep it fun!
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
Does the Pen F correct the Panasonic’s CA?
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
jhunna Senior Member • Posts: 2,738
Unless I need to manually focus the 12-32 gets the nod over the 14.  I don’t see the pop with this lens but will take it out tomorrow to see if I am missing anything.
 jhunna's gear list:jhunna's gear list
Sony a7C Sony E 20mm F2.8 Sony FE 50mm F1.8 Sony FE 85mm F1.8 Sony FE 35mm F1.8 +7 more
Dennis1972 Regular Member • Posts: 481
Same.  I have the 14 and see no pop...
Sharpness is pretty meh too, but then again can't expect too much for the price (pick mine up for ~$100USD), size and weight.
 Dennis1972's gear list:Dennis1972's gear list
Olympus OM-D E-M10 III Canon EOS R Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +2 more
secretworld Senior Member • Posts: 1,734
I sold mine years ago with my GF2. I think it had bad shuttershock. But when not affected it produced nice shots. But here also the 14-45 was better. And f2.5 vs 3.5 is not much difference. For a light pancake I use the 12-32 on a gm5 now. Like this much better.
 secretworld's gear list:secretworld's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
vincentocat Regular Member • Posts: 371
Do you have some 3D pop pictures with this lens to share.
Thanks.
 vincentocat's gear list:vincentocat's gear list
Panasonic S1 Panasonic Lumix DC-GH6 Panasonic Leica 100-400mm F4.0-6.3 ASPH Panasonic Leica DG 25-50mm F1.7 Panasonic GH5 +19 more
Tatouzou
Tatouzou Senior Member • Posts: 2,081
Agreed, and f2.5 is approximatively 1 stop faster than f3.5.
 Tatouzou's gear list:Tatouzou's gear list
Panasonic Lumix DMC-LF1 Pentax K-3 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Pentax smc DA 17-70mm F4.0 AL (IF) SDM +24 more
But with modern (20MP sensor) you can make up for the stop of light with ISO if you can accept a bit of noise.  And for video you can't even tell the difference.  I hate to say it but the 14/2.5 is fairly obsolete, UNLESS you like to manually focus and don't want to deal with the collapsing of the 12-32.
The 28/2.5 is a "pancake" lens.
It's small even when in use.
Of course, the 12-32 goes from 12mm (wider)... to 32mm, and, is more versatile.
Anyway, aren't we lucky that we have all those choices of M4/3 lenses ?
-JF
Henry Richardson Forum Pro • Posts: 21,959
28mm-efl is my most used focal length
7
I like this little lens too. I just checked in Lightroom and 28% (coincidence!) of my m4/3 photos were taken at 14mm (28mm-efl) -- many not with this lens though. By far, it is my most used focal length.
I then checked all of my various APS-C Sony, Canon, Pentax, and Konica Minolta DSLRs and 28mm-efl was my most used focal length with them too.
I then checked my various non-ILC digicams and, again, 28mm-efl was my most used focal length.
Henry Richardson
http://www.bakubo.com
(unknown member) Contributing Member • Posts: 726
Mine is glued to the GM5. Poor man’s Leica Q.
Most people hate this lens and love the 20. I am the opposite. I could not stand the noise from the focus mechanism. My 14 is sharp, quick, quiet and tiny! The 14mm f/2.5 and 42.5mm f/1.7 are a great travel kit with the GM5.
Not sure about that “pop” though.
24thWanderer
24thWanderer Regular Member • Posts: 228
This was the first prime I purchased for the system. I ended up selling it at one point. In natural lighting, this little guy actually did pretty well. Surprised me. I churned out some good citiscapes and paid food photography with this guy. But it really suffered from flare. I shoot a lot of events and mostly concerts. This just did not handle shooting directly in the light well at all. Great little lens but it wasn't for me. I ended up selling it once I got the Oly 12-40 PRO. But it's a nice value can make a nice first or second prime for someone.
 24thWanderer's gear list:24thWanderer's gear list
Canon EOS Rebel T7 Canon EOS RP Canon EF 17-40mm f/4.0L USM Tamron SP 45mm F1.8 Di VC USD Tamron SP 90mm F2.8 Di VC USD Macro +1 more
Dan_168 Forum Pro • Posts: 11,074
I have this lens too and like it pretty good, not because it's optically a good lens but just because it's a pancake style, actually, optically speaking, I really have nothing great to say about this lens, but it fit the main purpose of me getting an OMD 10 II, SMALL and LIGHT and still interchangeable lens, that's the only reason I got this system. so I mainly use Pancake lenses on this system, 12-32, 14-42, 14, 20.and recently added a Sigma 56 for occasionally when I use this for portrait when I am hiking and don't have those bigger camera with me. I like the 12-32 a lot better, at least it's more flexible. the 14 2.5 is a prime without the prime lens's quality, but again, it's so small, so I still keeping it.
rashid7
I disagree.  While maybe subtle, I find it better than the kit zooms!  Especially vs. old Lumix14-42, and even current Oly 14-42's
Keep it fun!
Vermont3133
Vermont3133 Senior Member • Posts: 1,099
5
I know this gets dragged up regularly but it has some interesting results re. the Pana 14...not so good for the PL25!
If we are to believe the guys at LensRentals [I would] the 14 [re.MTF results] eclipses a bagload of zooms and couple of WA primes and pretty well keeps up with the Pana 20 1.7.
This is wide open up to f/4...which is pretty much where it matters.
https://www.lensrentals.com/blog/2012/05/wide-angle-micro-43-imatest-results/
I'm a brand new owner of an older 14 [in very nice condition].
Does it pop?....Not sure about that but I'm pretty happy with what I'm seeing!
 Vermont3133's gear list:Vermont3133's gear list
Olympus E-M5 II Fujifilm X-T2 Olympus E-M1 II Fujifilm X-T4 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +7 more
