Updating Firmware on my DP2m
Started 9 months ago | Questions
Juss4Phun New Member • Posts: 6
Hello all,
I am new to posting on this site, but I am hitting a wall with respect to feedback from Sigma. I recently purchased a rather well maintained dp2m from eBay. When I received the camera, I noticed that it has never been updated from firmware 1.00. I went about downloading the latest (v1.05, I think?) from Sigma's website, copied it to the root directory of my SDXC media card, and placed it into my camera. The camera does not recognize the firmware on the card. I think that I may need to first update to an older firmware release, but I cannot find any working links to older firmware.
Please help if you have any suggestions.
Thanks,
Mark
Sigma DP2 Merrill
MOD rick decker Forum Pro • Posts: 17,107
Re: Updating Firmware on my DP2m
OK just edited again...you do not need 1.04 before updating to 1.05. I just checked.  I am not sure if 1.00 is a production or pre-production. firmware. That could be an exception to the rule.
Joe Hanson Junior Member • Posts: 47
Did you download both files for version 1.05?
"This firmware update requires two files; DP2M_105.bin and DP2MV105.bin."
 Joe Hanson's gear list:Joe Hanson's gear list
Olympus TG-5 Canon PowerShot SX70 Sigma SD15 Sigma sd Quattro Canon EOS M6 II +4 more
OP Juss4Phun New Member • Posts: 6
Hi Joe,
Yes, I did. One of the forum mods mentioned to me that v1.05 requires that I first install v1.04, but I need to find someone with a copy of that; and potentially 1.03, etc.
Thank you,
Mark
Thank you, Rick, I will try that.
-Mark
Oops, just saw your edit. Do you think it would be worthwhile to ask for earlier firmware versions, or do you think I am stuck if it turns out to be pre-production firmware?
Thanks again,
Mark
docmaas
docmaas Veteran Member • Posts: 6,853
If you didn't first format the card in the camera do so now.  Not sure it will help but it can't hurt.
Juss4Phun wrote:
Hello all,
Thanks,
Mark
"Laoma shitu" "An old horse knows the road" Chinese Proverb                                        "Dao ke dao, fei chang dao. Ming ke ming, fei chang ming" Laozi
"At every crossroads on the path that leads to the future, tradition has placed 10,000 men to guard the past."
Maurice Maeterlinck
allineedislight Contributing Member • Posts: 761
Have you checked carefully that the filenames have not been altered during download?
Some browsers add further file name extensions, or numbers (to distinguish consecutive downloads of the same file) at the end of the file name.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Canon EOS Rebel SL1 Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 24mm F2.8 STM +1 more
Shawn67 Senior Member • Posts: 2,283
Juss4Phun wrote:
Hi Joe,
Thank you,
Mark
Mark,
The firmware update directions have different directions depending upon what version of firmware you are upgrading from. From that it doesn't sound like v1.04 is required at all.
http://www.sigma-dp.com/download/dp2m-firmware.html
What error are you getting after step 5?
Try
1) Formatting the card in the camera.
2) Download the two files directly onto the SD card in your computer. Make sure they are in the root directory. Make sure they haven't been renamed to include a number if you have downloaded the two files multiple times.
3) Fully charge a battery and put it in the camera and then try to procedure again.
Good luck,
Shawn
Ceistinne Senior Member • Posts: 2,364
Juss4Phun wrote:
Hello all,
Thanks,
Mark
Mark,
You do not need to install any other Firmware before installing Ver 1.05 as the in between ones are contained in it.
1.05 includes two updates as follows: This firmware update requires two files; DP2M_105.bin and DP2MV105.bin.  Download both of them to the root directory of a freshly formatted SDxx card. Important Do not put them into DCIM or the camera will not see them.  If that does not work try a SDHC card instead.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
I have tried to be meticulous with my checking of the naming of the files, and the location, but I will definitely try to use an older SD card and see if that makes any difference. I will say that I am disappointed in Sigma, as they have chosen to offer no help. I contacted them in NY and they tell me the camera is too old and no longer supported, but I am only asking for access to older firmware versions! I will keep trying, as I really enjoy using this camera. Many thanks to all who have responded in this thread!
-Mark
you can find the old version at https://web.archive.org
Just look for old version of the firmware download page http://www.sigma-dp.com/download/dp2m-firmware.html
For example, the page featuring firmware 1.01 is here:
https://web.archive.org/web/20121005133350/http://www.sigma-dp.com/download/dp2m-firmware.html
and you can download the firmware from this link here:
https://web.archive.org/web/20121005133350/http://www.sigma-dp.com/data/DP2m_data/DP2M_101.bin
Hope this helps!
Here is a list of all DP2M firmwares, with links to the binaries, description of changes (PDF) and installation instructions (web page):
#1.05 (2013.06.14) 2 firmware files !!
http://www.sigma-dp.com/data/DP2m_data/DP2M_105.bin
http://www.sigma-dp.com/data/DP2m_data/DP2MV105.bin
http://www.sigma-dp.com/data/DP2m_data/DP2M_FW_1.05_EN.pdf
#1.04 (2013.03.09) 2 firmware files !!
https://web.archive.org/web/20130315041103/http://www.sigma-dp.com/download/dp2m-firmware.html
https://web.archive.org/web/20130615003612/http://www.sigma-dp.com/data/DP2m_data/DP2M_104.bin
https://web.archive.org/web/20130618144518/http://www.sigma-dp.com/data/DP2m_data/DP2MV104.bin
http://www.sigma-dp.com/data/DP2m_data/DP2M_FW_1.04_EN.pdf
1.03 (2012.11.21)
https://web.archive.org/web/20121213193705/http://www.sigma-dp.com/download/dp2m-firmware.html
https://web.archive.org/web/20121213193705/http://www.sigma-dp.com/data/DP2m_data/DP2M_103.bin
1.02 (2012.10.27)
https://web.archive.org/web/20121029112357/http://sigma-dp.com/download/dp2m-firmware.html
https://web.archive.org/web/20130615002216/http://sigma-dp.com/data/DP2m_data/DP2M_102.bin
http://www.sigma-dp.com/data/DP2m_data/DP2M_FW_1.02_EN.pdf
1.01 (2012.09.13)
http://www.sigma-dp.com/data/DP2m_data/DP2M_FW_1.01_EN.pdf
your are welcome
This is fantastic! Thank you, thank you!
-Mark
