A6000 only saves half of frame
Started 7 months ago | Questions
Araldite Contributing Member • Posts: 789
When I look through finder and press shutter camera only records on to SD card left half of picture. Am I accidently setting something wrong as next picture is perfect?
A PICTURE IS WORTH A THOUSAND WORDS
 Araldite's gear list:Araldite's gear list
Panasonic ZS100 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic 12-60mm F3.5-5.6 OIS Panasonic 14-140mm F3.5-5.6 II +3 more
Sony a6000
Sympa Senior Member • Posts: 2,403
Re: A6000 only saves half of frame
Is the other half of the picture black? Does this happen in both jpg and raw? Can you try another memory card?
The only setting I can imagine is 'auto framing' but it crops the image instead of making half of it black.
 Sympa's gear list:Sympa's gear list
Sony RX100 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS Canon EF-S 10-18mm F4.5–5.6 IS STM +2 more
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 4,994
Difficult to diagnose blindly.  Post an example.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
CaliforniaDave Senior Member • Posts: 1,623
Since A PICTURE IS WORTH A THOUSAND WORDS, it would be very useful if you would post one.
Gary3000 Senior Member • Posts: 1,339
..yah, even if it's only worth 500 words.
A few things can be happening..
- messed up camera
- corrupt data
- shooting with a. flash/strobe at higher than recommended sync speed.
 Gary3000's gear list:Gary3000's gear list
Sony RX100 V Canon EOS 5D Mark II Sony a6500 Canon PowerShot G12 Canon PowerShot S110 +14 more
Alex Ethridge
- messed up camera
- corrupt data
30 divided by 1000 = three one-hundreths. Need 970 more words.
- messed up camera
- corrupt data
hah!
actually, delete the part about the flash/strobe, that only occurs when the bottom or top half of the picture is blank sometimes, never the left or right side.
that's def a messed up camera.
or are the photos messed up while viewing in-camera, or just on a computer?
expressivecanvas
expressivecanvas Contributing Member • Posts: 917
Could be a corrupt memory card.  Try to format the card in the camera and see if that resolves the problem.  If not, try a new card.  If new card doesn't fix it, then it is probably time for it to be serviced.  However, considering the cost of the a6000 today, I'd probably buy new/used rather than service the camera.
Patrick
 expressivecanvas's gear list:expressivecanvas's gear list
Sony a7 Sony a6000 Canon EF 400mm f/5.6L USM Canon EF 20-35mm F3.5-4.5 USM Canon EF 70-300mm f/4-5.6 IS USM +12 more
DS in Norcal New Member • Posts: 14
It is likely that the Auto Portrait Framing setting was enabled accidentally. You need to go through the menu system and turn it off.
https://www.nytimes.com/2015/07/04/technology/personaltech/opting-out-of-automatic-portraits-in-sony-cameras.html
 DS in Norcal's gear list:DS in Norcal's gear list
Casio Exilim EX-FH100 Sony a6000 Sigma 30mm F2.8 DN | A +1 more
expressivecanvas
When Auto Portrait Framing is selected, you get two images...  the original image as shot and the auto-cropped image but the cropped image is upscaled automatically to the full 6000x4000 pixels...  no half images.    I never use auto portrait framing but I did just test it on my camera because I thought the above info was incorrect.
It is possible, however, that the original poster didn't explain his problem well enough.  Getting a half image is quite different than getting a cropped and upscaled image.
Patrick
It may be also called Auto Object Framing
MENU →  (Camera Settings1) → [  Auto Object Framing] → desired setting.
OP Araldite Contributing Member • Posts: 789
Re: A6000 only saves half of frame THANKS FOR ALL YOUR HELP
I have come to the conclusion that cameras these days do what they want not what we want. However the auto portrait framing is now switched off and lets hope it behaves itself
AdVeen
AdVeen Senior Member • Posts: 1,312
Had the same thing happen to me on my a6000, but it turned out to be a missing lens-softwareupdate (in my case Touit 32). After updating, the combo worked as it should.
 AdVeen's gear list:AdVeen's gear list
Sony Cyber-shot DSC-HX400V Sony a5000 Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +6 more
