Fujifilm's Perfect Lens
Started Feb 13, 2020 | User reviews
(unknown member) Regular Member • Posts: 360
9
I'll keep this short. This is a great lens!
Optically perfect
Awesome bokeh (better than the 56mm)
great minimum focus distance
Extremely sharp! (but not 80mm macro sharp which is good)
I don't use it often but I'm glad I have it for the times when I need it.
Fujifilm XF 90mm F2 R LM WR
Prime lens • Fujifilm X • 16463668
Announced: May 18, 2015
Murdoko's score
5.0
Average community score
5.0
dccberry Senior Member • Posts: 1,239
Re: Fujifilm's Perfect Lens
I agree about the optical quality. I just never bonded with the focal length. Too long for most portrait work, too short for some of the editorial images I make. I wound up selling it and going for the 50-140, which is far more useful for me, and optically very nice.
 dccberry's gear list:dccberry's gear list
Ricoh GR Nikon D810 Nikon D850 Fujifilm X-T3 Fujifilm X-T4 +10 more
Gibbons3D Regular Member • Posts: 111
Was literally about to type exactly what you said, love the lens and 2 of my top 5 shots were with it but i felt i never used it much due to the focal and ended up selling it for the 50-140, I miss it but it just didn't come out enough with me.
mrgooch2008
mrgooch2008 Contributing Member • Posts: 842
Lack of OIS killed this lens!
 mrgooch2008's gear list:mrgooch2008's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
holashobby Senior Member • Posts: 1,663
Optically perfect
As a speciality lens, it's great but I find the 50-140's versatility much more to my liking. You can use it many scenarios where the 90 simply does not work.
 holashobby's gear list:holashobby's gear list
Fujifilm X-T4 Panasonic Lumix DC-S5 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm 15-45mm F3.5-5.6 OIS PZ +4 more
technotic Contributing Member • Posts: 792
That and the 18-55.
OP (unknown member) Regular Member • Posts: 360
Have you used it?
Gaber
Gaber Veteran Member • Posts: 6,365
I decided to buy the 80mm macro for three reasons.
1) I enjoy macro
2) OIS
3)Works with the TC 1.4X to give me a 120mm macro.
I thought 80mm to be slightly short for macro, so when I need more length I can pop on the TC.
 Gaber's gear list:Gaber's gear list
Nikon Coolpix 4500 Olympus Tough TG-2 Nikon 1 J5 Fujifilm X-E3 Nikon AF Nikkor 50mm f/1.4D +14 more
Clive99 Senior Member • Posts: 1,389
One more awesome feature is the fast AF. It is really good for sports. Possibly my most loved (but definitely not most used) lens. It's magic.
 Clive99's gear list:Clive99's gear list
Fujifilm XF10 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 18mm F2 R Samyang 8mm F2.8 UMC Fisheye +16 more
Murdoko wrote:
Have you used it?
Do you really want to shoot this FL handheld in low light on an X-T3
BklynBill Contributing Member • Posts: 753
Love the 90mm but it definitely pairs better with my X-H1 with IBIS than it does with my X-E3.
 BklynBill's gear list:BklynBill's gear list
Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +9 more
Jacaustin Regular Member • Posts: 113
Agree 100%. Great for indoor sports with low light, like basketball. Gonna be even better on my xt-4 with IBIS.
Rod McD Veteran Member • Posts: 8,589
Hi,
I agree - it's an excellent lens in most respects.  The wonderful thing is just how sharp it is at wide apertures.  It's only weakness is flare.
I ended up selling mine - it was a lens that was just heavy enough to leave at home and so didn't get used often enough to warrant the expense.  There are also smaller and cheaper adapted alternatives if you're happy with MF and middle apertures.
The other thing that I found was  that once the light fell, the extra speed didn't offer enough advantage over the lack of OIS - my 55-200 would deliver better results at slow shutter speeds.  No doubt an XH1 would have helped.  Or an XT4 (This was for static subjects.  Both OIS and IBIS deal with camera movement, not subject movement.)
Regards, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
AdrianTWQ Regular Member • Posts: 330
All Fuji lens are perfect, or at least close to perfect, just need to use it for the style of photography it was mean for. Unlike most other companies, Fuji has no bad lens.
 AdrianTWQ's gear list:AdrianTWQ's gear list
Panasonic Lumix DMC-LF1 Fujifilm X-A3 Fujifilm 50-230mm II Fujifilm 15-45mm F3.5-5.6 OIS PZ Fujifilm XF 16-80mm F4 +1 more
Davidov Forum Member • Posts: 56
Love mine too. Not so sure IBIS will help with indoor sports like basketball, dodgeball... too much subject movement not helped by IBIS.
John
Agree, for action photography, you would need fast shutter speed anyway.
True/agree. Should have separated my two thoughts.
1.) love it for indoor sports
2.) it’s also a great portrait lens, etc. and stabilization will make it even better
THese are SOOC JPEGs
tjinsd
tjinsd Regular Member • Posts: 197
What are your thoughts on a potential 70mm being in the works?  I know I haven't seen too many people predict that as one of the three unannounced lenses in the works, but I find it intriguing.  I have a 35 Mitakon and 50 Kaman... both of which I love... and an 85mm Viltrox, which I find a bit long, especially indoors.  I would certainly be interested in a 70mm...
As it is, I'm stuck in a holding pattern.  I would have bought the 56mm already, but for the 50mm 1.0 that's coming.  And want a 23mm 1.4, but am afraid a mk ii is coming.  I wish we had a road map.
 tjinsd's gear list:tjinsd's gear list
Fujifilm X-T3 Fujifilm 50-230mm Fujifilm XF 56mm F1.2 R Samyang 12mm F2.0 NCS CS Fujifilm 16-55mm F2.8R LM WR +2 more
Babu K Forum Member • Posts: 79
Optically perfect
I agree with everything you say. I use it rarely, but when I do, it produces a much higher rate of stunning images than any of my other lenses.
 Babu K's gear list:Babu K's gear list
Fujifilm X100F Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-T2 Fujifilm X-T3 +8 more
