R5 and moving the autofocus cursor
Autoxave Regular Member • Posts: 186
Do R5 have the same functionality when moving te autofocus point as the 1D Mark III? There is a button named AF-ON on the new images of R5 which seems bigger and different from the other buttons.
Canon EOS-1D Mark III Ricoh Caplio R5
Dmatrix Photo
Dmatrix Photo Forum Member • Posts: 74
Re: R5 and moving the autofocus cursor
No it doesn't appear so. It has a regular joystick. However I imagine that there would still be the option to touch and drag as well
 Dmatrix Photo's gear list:Dmatrix Photo's gear list
Canon EOS 5D Mark IV Canon EOS R Canon EF 70-200mm F2.8L IS II USM Canon EF 35mm F1.4L II USM Canon 85mm F1.4L IS USM
OP Autoxave Regular Member • Posts: 186
Just seems so more effective with solution that 1D Mark III has. Hopefully it will be introduced in the second version.
tifa3 New Member • Posts: 5
doesn't look like it. maybe they're saving it for the mirrorless version of the 1dx3 and charge $6000
RDM5546 Regular Member • Posts: 310
I think an R1D mirrorless 1DX III will be $7495 because it will be better and the access to great  glass is the key factor along with 1D performance leadship.
 RDM5546's gear list:RDM5546's gear list
Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS R +29 more
Battersea Senior Member • Posts: 1,061
Canon had to leave something off or how could people complain?  That is a nifty focus point selector on the 1DXIII
 Battersea's gear list:Battersea's gear list
Canon PowerShot G16 Canon EOS 7D Canon EOS 6D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +6 more
It is expensive in comparison to a joystick and does the same job.  I want closer to the 5D pricing not the 1DX III pricing.   I will gladly give up an optical mouse for a lower price.
The EOS R has the touch screen point which works very well for me and the mechanical touch bar is icing on the cake I think.
I would rather them put more resources into the EVF high speed performance.   May it will require the RF lenses only I do not know but I was better than EOS R High Speed Viewfinder experience on the R5.  20hz refresh rate would nice if the camera is shooting at 20 fps.   Of course a minimum of display black time too.
I know the 7D and 5D OVF will always be quicker for the faster moving subjects but I do not think that better than the EOS R is too much too ask for the hefty price they will be charging.  Maybe I will even buy the 100-500mm lens with two extenders if the EVF is good enough for high speed shooting for us self proclaim "spray and pray" shooters.
