Raw developer for new fuji cameras
Started 1 month ago | Discussions
MozoAndres Forum Member • Posts: 73
If I want to buy a new fuji camera. There is any free software (or cheaper than US$10/Mo) for develop raw?
Recommendatios?
mozoandres.wordpress.com
 MozoAndres's gear list:MozoAndres's gear list
Fujifilm X-T10 Fujifilm XF 35mm F2 R WR Samyang 12mm F2.0 NCS CS Fujifilm XF 23mm F2 R WR
OP MozoAndres Forum Member • Posts: 73
Re: Raw developer for new fuji cameras
Or maybe some RAW converter to DNG to use in my older LR6?
Works ok?
R_U_Q_R_U
R_U_Q_R_U Contributing Member • Posts: 929
9
FREE: Raw Therapee
FREE: Darktable
CHEAP: Iridient X-Transformer $36
FREE: Capture One Express for Fujifilm
FREE: From Fujifilm: RAW Converter EX
Sometimes the light's all shinin' on me,
Other times I can barely see.
Lately it occurs to me what a long, strange trip it's been.
 R_U_Q_R_U's gear list:R_U_Q_R_U's gear list
Fujifilm XF 56mm F1.2 R Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 50-140mm F2.8 Fujifilm X100V Fujifilm X-T1 +9 more
R_U_Q_R_U wrote:
FREE: Raw Therapee
FREE: Darktable
Thats awesome!! thank you!
lewiedude2
lewiedude2 Senior Member • Posts: 1,771
Yep, those will work just fine. And. You can run a free version of Iridient X Transformer (a watermark will populate in the image) to convert only the RAF files to a DNG file. Check it out and if you like it, it is a one-time purchase of US$30 - I think.
I use IXT and my Adobe suite subscription. It works for me and I know you don’t want the monthly so check out the above and see if/how IxT works as well.
Edit: skipped over the CHEAP line item above. It is IxT. And is apparently now US$36.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
Rightsaidfred Regular Member • Posts: 134
... and Fujifilm X Raw Studio (free) - use the emdedded software of the camera body:
https://www.fujifilm.com/support/digital_cameras/software/application/
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Venus Laowa 9mm F2.8 Venus Laowa 25mm F2.8 2.5-5X Macro +2 more
guitarjeff
guitarjeff Senior Member • Posts: 1,633
Recommendatios?
Many a Fuji shooter loves the free raw therapy program.  In fact, there is a thread here right now about it and the great details you can get out of Fuji raw files.  Just cruise the threads below, you'll see it.
getochkn
getochkn Contributing Member • Posts: 912
And silkypix free from fuji
 getochkn's gear list:getochkn's gear list
Panasonic Lumix DMC-LX3 Canon PowerShot ELPH 360 HS Fujifilm X-T1 Fujifilm X-T30 Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
GossCTP Veteran Member • Posts: 5,151
R_U_Q_R_U wrote:
FREE: Raw Therapee
FREE: Darktable
Do any of those allow lens corrections to be ignored?
"Law and order" is anathema to liberty and justice.
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K-5 II Pentax K20D Pentax 16-85mm F3.5-5.6 WR Pentax smc DA 16-45mm F4 ED AL +7 more
Tom Schum
Tom Schum Veteran Member • Posts: 9,235
GossCTP wrote:
R_U_Q_R_U wrote:
FREE: Raw Therapee
FREE: Darktable
Rawtherapee used to run without lens corrections.
A few years ago RawTherapee did not do lens corrections.
Tom Schum
Copper: Mankind's favorite electrical conductor
Sigma dp0 Quattro Fujifilm X30 Sigma sd Quattro Fujifilm X-E1 Fujifilm X-T3 +12 more
Steven Seventeen Junior Member • Posts: 49
You are in luck!
Fuji users are actually quite lucky from this perspective. Every Fuji X camera comes with two free RAW converters:
  • Fuji SILKYPIX. It's a big sluggish, but the image quality is peerless. Its sharpening and de-noise algorithms are particularly impressive.
  • Capture One Express Fujifilm. Also known as C1. The best user interface and color controls of any RAW converter I've ever seen. Also contains image catalog capabilities similar to Lightroom.
Both RAW converters come from 3rd party companies. Both have a partnership with Fuji. Some people mistakenly claim that SILKYPIX gives you the same result as the in-camera JPEG engine. It's not true, it's an approximation just like C1.
I do not recommend RAW therapee or Darktable. Both feature horrid user experience, steep learning curve and cannot easily deliver Fuji Colors. As an avid Linux user for many years I really, really wanted them to work, but in the end I gave up and installed Windows to run SILKYPIX and C1.
Gwenbeth New Member • Posts: 23
I personally use darktable. For me the biggest consideration is not having to buy some weird proprietary os to run it. Making a noise profile for it for my x-t30 is on my to-do list. using the one for the x-t3 does help.
 Gwenbeth's gear list:Gwenbeth's gear list
Fujifilm X-T30
chaimav
chaimav Senior Member • Posts: 1,131
Tom Schum wrote:
GossCTP wrote:
R_U_Q_R_U wrote:
FREE: Raw Therapee
FREE: Darktable
RawTherapee can use either Lensfun, Adobe LCP, or auto match an embedded jpg profiles. All are optional, and have the ability to toggle individual settings.
http://rawpedia.rawtherapee.com/Lens/Geometry#Profiled_Lens_Correction
There is also a separate defringe function which works very well at removing the purple fringing shown above.
http://rawpedia.rawtherapee.com/Defringe
 chaimav's gear list:chaimav's gear list
Canon PowerShot S100 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
FujiJon
FujiJon Regular Member • Posts: 138
GossCTP wrote:
R_U_Q_R_U wrote:
FREE: Raw Therapee
FREE: Darktable
Darktable: you can either turn it off completely or tweak it if you're not happy with the default settings.  DT uses the lensfun database, so assuming your lens is inthere, it will pick it up.
If at first you do succeed, try not to look surprised.
 FujiJon's gear list:FujiJon's gear list
Fujifilm X-T20 Fujifilm X-H1 Fujifilm 16-50mm F3.5-5.6 II Samyang 12mm F2.0 NCS CS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +1 more
giarc
giarc Contributing Member • Posts: 771
Works ok?
Among the other options mentioned, you can download Adobe's DNG converter and create DNGs to import into older Lightroom versions.
https://helpx.adobe.com/photoshop/using/adobe-dng-converter.html
moimoi
moimoi Veteran Member • Posts: 5,421
Recommendatios?
Capture One is the way to go for Fuji files.
For ultimate control (but I found the interface very cumbersome, and unnecessarily complicated) => RawTherapee
I would advise you to avoid any Adobe Products like ACR/Lightroom for any cameras equipped with X-trans sensors.
Max
Digital: Fujifilm GFX50R / Canon 5Div
Film: Minolta X570, XD5 & XD11 / Canon EOS 3
http://www.maximesiegler.com/
https://www.instagram.com/maxsiegler645/
And back to Analog Photography as well, oh well!
"All we have discovered is that it starts with a single individual - always a child - and then spreads explosively, like the formation of crystals round the first nucleus in a saturated solution." Arthur C. Clarke (Childhood's End, 1953)
 moimoi's gear list:moimoi's gear list
Fujifilm X100T Canon EOS 6D Canon EOS 5D Mark IV Fujifilm GFX 50R Canon EF 70-200mm F2.8L IS II USM +8 more
chaimav
Yes, RT can be very overwhelming at first. One thing to keep in mind is that there is a large overlap in the functionality of many of the tools. The developers are very keen on not breaking backwards compatibility, so old tools tend to remain. There are also some nuanced differences between that are a function of the different algorithms behind the tools. Some of the tools are also extremely powerful yet very complex.
I have my regular set of tools that I have learned to use, and generally just ignore what I haven't figured out yet.
giarc
moimoi wrote:
Recommendatios?
And I'd advise thats not necessary if you are already a happy Lightroom user.
Max
R_U_Q_R_U
Tom Schum wrote:
GossCTP wrote:
R_U_Q_R_U wrote:
FREE: Raw Therapee
FREE: Darktable
These are the lens controls - they can be turned off:
Also, there are many great video tutorials on YouTube. A quick search will find them.
